Hi Don -- I just now found your build log, and am impressed with your progress.  I'll be looking forward to reading the Adventures of Another Swan Builder.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks Martin, glad to have you on board
  • 4 months later...
Good Morning All, I trust and hope you all had happy holidays and are now back to the reality of life once again.
 I took the last five days off of my Trabaccolo build to do a little work on my neglected Pegasus, she was very happy to be in the shipyard once again.
First up was fairing the hull, sorry no pictures, then was to install the plywood gun deck. Before doing this supports were required as per so many other logs such as Mike's(Landlubber Mike). So you can see in the pictures how I accomplished this using some 3 x 3mm posts and 1.5 x 5 mm planks.
post-20628-0-64901700-1483964081_thumb.jpgpost-20628-0-91717300-1483964103_thumb.jpgpost-20628-0-38690800-1483964126_thumb.jpg
Next was the infamous plywood gunport pieces, I had little problems with these which still worries me :huh: . I soaked them for about an hour then bent them using a curling iron. I needed to move them approx 5mm forward as one of the oar holes was being blocked by a bulkhead, but other than that it went smoothly.
While waiting for glue and paint to dry I thought I would put together the cannon carriages. Many have complained about the Amati carriages , mostly about the quality of the plywood. I am thinking they must have changed their stock as I found these ones to be quite durable and easy to work with, you can be the judge as to how they look. Amati does include 18 carriages and 16 cannons, I'm thinking these extra carriages will work fine as stocking stuffers next Christmas or even mount some chocolate in them and they could be a Easter bunny thing, at any rate they will not go to waste.
A point to note is Do Not paint the bulkheads black above the deck if you wish to paint red later :angry:  :P . Mine took a minimum of ten coats to cover then I just quit.
Here I am using the mill with the sensitive drilling attachment to drill the axles for the pins that hold the trucks on, then it was on to assembling.
post-20628-0-76342300-1483964162_thumb.jpgpost-20628-0-80000200-1483964191_thumb.jpgpost-20628-0-22759200-1483964212_thumb.jpg
A little out of order but here you can see the result of moving the gun port sides ahead by 5 mm. The stem post and bowsprit are not glued in place, looks so good I feel like making the real bowsprit now.
post-20628-0-74907400-1483964232_thumb.jpgpost-20628-0-13670800-1483964258_thumb.jpgpost-20628-0-46933200-1483964294_thumb.jpg
And here she is ready for a battle, well kind of, and loaded up for next stage of deck planking
Here the planking has started using the kit supplied planks. I decided on a four plank shift using 120 mm planks. I built the aft bits as they are noted for not fitting properly mine required minor adjustments and fit perfectly. So with the gunport sides causing no problems and now the bits fitting good I am really getting concerned about my usual not so good luck. :)  :)
 In my excitement to start planking I forgot I should have built the hatches first, I don't think this will pose too much of a problem, I will carry on as is and see what happens later with the hatches.
Have a Good Day
Edited by donrobinson
Hi Don -- That's quite a bit of progress you've made!  Well done.  The gunport strip looks good to me -- the test lies with seeing whether or not the guns sit in the ports at a consistent height, and yours certainly look right.
I think if my Fly had come with wooden carriages I'd have been tempted to use them, but they were ugly brass things, that even the Easter Bunny would turn away from.
Can't wait to see more!
Martin
Thanks for stopping in and for your comment Martin. I will have to check out the gun carriages a little closer and see how they are fitting.
Thanks Dave, I had a quick look at that site and it looks pretty good. I am going to have a closer look and maybe take some notes.
Solid start Don.  The patterns look fantastic - you got a really nice curve along the bulkhead extensions which will make for a nice curvy lady.
If I remember correctly, I don't think there are any tricky things to be aware of at this stage.  The wale was tricky for me to line up, but wasn't too bad.  I found, like the TFFM series, that as the wale approaches the stem in an upward curve, it flattens out right around the last bulkhead or two.
I think I mentioned earlier that if you look at the NMM plans, the kit's plans deviate on some of the hatch locations and sizes.  I think the rear-most bitt actually extends through the hatch behind it, and I believe the cross bar (I'm not sure if that is the proper term) is on the opposite side of where the NMM plans show it should be (aft rather than fore).  These are all very minor variances though and in many cases, won't be noticeable if you decide to go with the kit plans.
Thanks Mike, I have looked over your log concerning the hatch and bit location and I will have to give that some thought. I do not have any of the TFFM books, my hope for my Pegasus is to have one that pleases my eye so that may not include all the historically correct additions or changes. I love what you have done with yours and really enjoy watching you work on her, I'm afraid my talents are not up to yours so I will not be attempting some of the changes you have masterfully completed. Maybe on my next Pegasus ;)  :) . I sincerely appreciate you looking in and helping me out, if it wasn't for you and your log (which I have used lots) my progress to date would have been a lot more difficult.
Thanks Again
Don, I think you give me way too much credit.  I'm actually learning a lot from you in your builds.  Some of the stuff I've been doing I think is some kind of subconscious desire to torture myself :)
I went over the NMM plans very carefully, and the Amati plans are incredibly close to them.  I think in a few minor areas there are deviations, mostly intended to simplify certain aspects of the build (for example, that one bitts I mentioned earlier).  The NMM plans are not necessarily how the actual ship came out either, particularly on the more decorative elements from what I gather.
The TFFM books are not necessary.  They are a nice educational resource for sure.  When I originally bought the kit, I was intending to just build it from the box as a more advanced kit to learn from.  When I got the books, I ended up getting the tools and the wood and now the build has morphed into a close to scratch build.  I've enjoyed learning the woodworking and modeling techniques, but there are times when I think about "what if" I had just build the model from the box.  The kit is so great that frankly, I'm wondering if there would have been any meaningful difference in outcome had I just build her straight from the kit.
That is funny Mike, when I bought the kit I was real new to this hobby and I to promised myself I would not change anything. Heck I even said I was going to leave the photo etch plain and not paint or blacken it, well I'm very certain I will break this part of the promise to myself :) . As for the rest I'll see how things go ;)  :D
  • 3 months later...
Hey howya goin Don mate, waiting for more on this build mate I'll be following along, great job so far.   :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
Yet another one of Don's projects that I somehow missed.  He is building them faster than I can read the build logs.  Great work as usual.  I will just sit here and wait for updates.
Mike Shanks
Thanks guys, updates coming soon. Deck planking is complete and hatches are next up on the menu. In the meantime help yourself to the refreshment fridge, it is fully stocked:cheers::)
  • 6 months later...
Hi Don,  I too would love to take a seat if there are any left(If not I will sit on the floor - no problem)   looking forward to seeing more of your  work, she is coming along really nicely.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hello Jason and OC now that I have finished my Trabakul build it is my full intention to pay more time to this girl and make some progress. Thanks for the push to get things going!!
