After approximately three months I'm about to finish the Bluejacket Portland hull. I have temporarily placed the
small portholes in the bow with a press fit. I would like to have glazing in them but have been unsuccessful
in trying a few mediums. The inside ID is just 1/8" so acetate is not being considered. Have tried Envirotex
and 5 minute epoxy with no success. Any ideas?
John Elwood
Have used both of those products on dozens of model railroad structures kees. Works fine but doesn't
dry hard. However, I'll test the kristal-clear since the diameter is so small. Might be just the trick on this application.
Thanks, John
John. Not sure if THIS will help with your problem ...
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Hi John,
 you mentioned request for 1/8" ID porthole "glassing"
I would choose cut off bits of transparent round line with 3mm OD, for example from this source, resp. appropriate source in CT
https://www.modulor.de/pvc-weich-rundschnur-farblos.html
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice  to hear from you Nils and jhearl. After experimenting with several products, I
went with Gallery Glass. It's a viscous white liquid that looks like Elmer's glue. Wiped a
thin film across the back of the porthole and let it dry till it was crystal clear. Then installed
each one with a tiny drop of Canopy Glue for adhesive. Had to see it in the photo but it's
there. You can see a slight reflection in the first porthole.
John
