Here are a few pictures of the deck and bulwark planking.
I also varnish the hull for an second time
I'm now going to plank the keel and stem and then I can make 4 canons before I can plank the last 4 decks...
Otherwise there is no room for placing the canons.
Have planking the keel on one side
I have listen to Anja and Børge.
I put varnish over it, so you see a difference between
the hull and the keel.
It turns out better then I thought.
I finished the planking of the Stem and the Keel.
4 more decks to go.
But before I started with that I want to do something else.
So I gonna assemble the rudder.
Otherwise I can not see a plank anymore!
2 pictures of the finished Stem and Keel.
I finished the rudder.
I make pictures of each stage.....
I don't know if I can attach him now or later because there is also a balcony on the stern..
At the plans it is coming after the balcony but I found out that sometimes it is better to do it another way.
It looks like if the stairs are not straight but that's an angle off the camera.
When I see the pictures I run upstairs to watch it.
The railing with the balusters are in place.
Also the catheads,
On the manuel they tell me I place them later and I have to cut out a little piece of wood because they go straight on the deck.
I think that this is the easy way.
I wanted to assemble the balcony, but found that the plastic parts where the railings will be placed are not connected / joined as shown in picture #1
To mount the balcony on the ship, it first has to be assembled and then pushed into a slot at the stern between frames 18 and 19. in the drawing, this slot is not specified (#2)
How deep the slot should be and how far the balcony should be pushed in, is also not specified.
In the 1:1 drawing you see that the balcony is pushed into the slot (#3).
I removed one plank from the stern where the slot supposed to be (#4). But as you can see in picture #5, if I cut out the slot accordingly, I will also have to cut away part of the keel. I can not assess if
I'm getting problems with placing the rudder
There also should have been openings in the stern for gun ports. but for that purpose there are no guns supplied. I will only place the shutters for the gun ports
On the Italian forum http://www.modellismo.net I have found another buildlog of Le Mirage.
This builder has, instead of making a slot for the balcony, placed the balcony around the hull with two support bars placed at the bottom of the balcony.
Personally I think that that is the best option to mount the balcony, without having to cut away part of the stern and the keel to make a slot.
On picture one you see the slots.
I have drilled a few holes and then sand it out with a wood file.
Then we have make from cardboard an example how the floor of the balcony goes.
Dry fit into the slot and I must say, I'm pleased!
The next step is cut out the wood ,so the floor of the balcony can go inside.
I have behind the stern place to glue the balcony.
Before everything goes inside, I finished the hole balcony, and then in one piece, it goes inside.
The balcony is varnished and I have put some windows on it.
There is another balcony coming above it, but that's for later.
I know it looks just not level but the ship is also not standing level.
The railing are in place and also the spiral stairs.
The pictures are not very clear because it is an dark and rainy day.
But you can see what I have done.
I was drilling hole into the bulwark for the deck cannons, and it goes wrong with one hole.
It looks like an egg now.......
I have to fix that.
Have take a picture from the wrong side
Here are the good side.
I'm not totally happy and have to see what I'm doing with it.
Maybe sanding or cut a little piece away.
Hi Sjors,
You seem to have done just as good a job this time around as the first! ;)
Cheers,
Grant
Thanks for taking the time to get Mirage back up, Sjors.  She's a real beauty.  I'll be following!!!!!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
You are more then welcome Sherry and Augie,
It's good to be back!
I filled the refrigerator with all kind of stuff.
So take what you wants…..
Sjors
Glad to see Le Mirage back - she is looking mighty fine!   Think I'll pull up a seat here in the corner and grab a cold beverage from your refrigerator!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Looking forward to the continuation. Quietly watching, as usual, but letting you know!
Tony
Very glad you are back in the saddle with your logs Sjors, now we need to see how the balance of power shifts for the sjorsian wars again! Lol
Ben
See...it's NOT me who fans Sjors flames.  It's Ben and Frank!!!!! :10_1_10:
Augie
Previous Builds :
