Thanks, Lou!  But in truth...the jury is still out on whether I use my scratch collars or the ones I just got online. But at least I can say I can come close to making them!
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
They look more than close from this end of the pictures!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Executive decision. Remaking the closed heart collars. The open hearts are as good as I can get them but the closed hearts are actually too small. The detail isn’t the problem...the gap that the rigging will need to fit into is too small and is more rounded than it is triangular. So will increase the size by 1mm and take another stab at them.
Funny...I thought the closed hearts would be hardest.
So...taking a step back.
Order of attack:
1. Remake the closed hearts
2. Build the boom rest!  (Think I finally got the process down to make a full wrap around boom rest)
3a.  Finish up building/pre-rigging the bowsprit
3b. Finish up building/painting/pre-rigging the fore and main masts
4. Stepping the Masts Day!!!
5. Drink a stiff scotch before beginning the adventure of rigging my first wooden model ship!!
Breakthrough!!!!  I finally got my technique down for making a decent boom rest (wrap around) for the main mast!
In truth, the process is easy...just needed to step back and rethink it. Used a compass and a 1/32” basswood sheet. Cut the inside out, then filed to fit the mast, followed by trimming and rounding the outside edge. Eureka!!!!
:dancetl6:
AB8810B4-85FF-45F5-B74E-EBFD058E44CE.jpeg.4d862f8c715af141fe728a563c319ccb.jpegBE414C66-8257-44E3-BCA6-BFCAA497D407.jpeg.c7bf78a6854e49ab825e924b271b5ae4.jpeg71649D62-3746-46CF-811B-00653737301B.jpeg.897d668a124437a2fb42889f107b8d12.jpeg
Edited by Overworked724
Not a bad bit of progress today. Step by step. Got the foremast chuck in place.
C79FD9C0-9141-4EA6-9B00-44A37069ADAF.jpeg.c6203c6828390a0cc2f729eaedd5663f.jpeg555A17A7-C250-4E1C-B29D-63E8358E2558.jpeg.14e363e25151ce2a43e16f0d558cf7c0.jpeg
Also got the boom rest seated on the main mast along with the boom rest supports.
In a pique of curiosity, I decided to try the mast hoops on both masts to ensure things lined up. As neither mast is stained, the effect is kind of vanilla...but I wanted a test fit. Glad I did as the ring bolt I made for the main boom was interfering with the settling of the mast hoops!
Minor thing but noticeable. Since I still had the option, replaced with a smaller eyebolt. Resolved the issue handily!
C885FF78-49C7-4600-BF10-9E8B4EA03FBD.jpeg.1e68678ad2ab5e3a2a679ee93f8f59d6.jpegOk...moving on!!
Impressive progress Patrick.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thank you, Lou!  Damn the torpedos!
:pirate41:
Created some new closed heart collars. You can see the photos below...the ones I originally made (left) were too small. You can see the original trial size on the right which is slightly too big. The one in the middle represents my target size. 4mm in a side. (Sounds like a Goldilocks episode)
The photo below shows my open hearts and closed hearts vs the laser cut ones. My hand made ones are certainly more crude...but screw it. I spent a while trying to get the technique down. I’m using them on the ship. 😁  They represent a lot of effort. 👍🏽
Moving on....
Too large, too small, aah just right. More like X rated Goldilocks episode.
I can't blame you for using your own they really are pretty good especially when you consider the tiny size.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Got the crosstrees painted. Working on the collars. Loaded up my special dowels with the appropriate rigging widths.
Getting ready....rigging spiders are crawling out of the woodwork already.
:omg:
Trestle trees painted. As are the bases of my main and foremast. Glued on the cleats at the base of each. Aligned by simply marking a piece of masking tape...taaadaa!
8238AAE0-A27F-4EC4-A49C-B0BED7B68F2B.jpeg.0881a888b72d5bc14cb2584339b99a7c.jpeg2BFCBD23-86D7-43B5-8C14-812AD5D31B74.jpeg.b2c4f89d6edb2bf91be9603dd5b0fd7f.jpeg
Moving on!...
...by the way...the paper wrapped around the shaft of the masts is there to prevent oil from my hands getting all over the masts.
(I was a messy baby, too.)
:D As long as you don't drool on the deck, all is OK!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
  • 3 months later...
Well, tales of my demise are still exaggerated!!
I painted the open and closed hearts I made. Have the Syren spares if needed but pressing on.
One bit of progress was noodling over the thimbles. Chuck made his out of thin rigging line. I decided to try and hollow out a tiny deadeye.  Was tricky but it worked - so I made a few. These will be fastened to the eye bolts on either side of the fore mast to secure the lanyards for the mast stays.
I think these are small enough, so I’ll give it a go...no painting these guys. Was a trial to get them made so I’ll let them stand out from the black rigging line.
Moving on!  Merry Christmas and Happy Holidays!!!
Well...I’m off to Japan for the Holidays with the Admiral. Wishing you all a joyful Christmas and Happy New Year!
Will be eager to finish the rigging on my return!  :champagne:
Really nice job on drilling the deadeyes.
Have fun on your trip to the Admiral's family, and a merry Christmas and Happy New Year to you as well.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Okay. Happy New Year!
Made a bit of slow progress. Although I can make some nice round bullseyes (closed collars) for the bowsprit, decided to use the closed hearts I made. It was my first attempt at seizing and they turned out nicely.
Tied them onto the sprit in front of the chocks as Chuck does in the practicum.
E5E3F9C6-50B5-4D15-A661-338F2AF0CF8E.thumb.jpeg.22d739565424d05f792ebed29183a72d.jpegD53A3A9D-770D-46B2-BA6D-48446E07BE9C.thumb.jpeg.3ce18705b330862008cff78d689e6c28.jpeg959C2913-96FD-47D2-9512-B11E038971DE.thumb.jpeg.954544e570050ef4dc36f3f19f91878f.jpeg54CFB481-EAE9-43ED-B652-03BBC677373C.thumb.jpeg.5561f6dfbe7bb839a415478d9fd01ca7.jpeg0AF0B9B4-C77C-4D0D-94DC-D2805B1EA434.thumb.jpeg.bc42b0ddc025132d44308b553681aa6d.jpeg
Not bad. Maybe oversized but I was focusing on doing a clean job. Also took time to stain some blocks for later. The stain really helps weather them and adds depth.
C36C3CBA-9C5A-4D1C-86C6-E9314D01168B.thumb.jpeg.800a8b1adda727fcb4600bb04ebbd212.jpegC92B8164-6774-4DE8-8796-2588C0136979.thumb.jpeg.e1647367724ab12796b0d9d4c0f6b37a.jpeg
Deep breaths...deep breaths...DEEeeeep breeeeaths...now for the open hearts.
Moving on...
The work so far looks great but i would spend some time preparing and sanding the blocks. You have spent so much effort putting in all that fantastic work into the model, that you do not want to short change the finial look with square unfinished looking blocks. Tom Laurier has two excellent videos on YouTube. I suggest you look at these befor you start installing. I was able to get the kit supplied blocks to look great. It just took a few TV shows, some fine sand paper and some time.
Best regards
kevin
Question for the forum.
I’m trying to find simple knots/techniques for the following:
1. Lanyards:  where does it start and how does it end. Pics just show symmetric wraps between two hearts.  Does someone have a technique?
2. Tying a line to a hook or an eyebolt: I see no simple instruction to do this.
3. Simplest knot to terminate an single loose end: the gammoning has no clear termination point.
Any links to good material would be appreciated!
Cheers!
Closed hearts are done and ready to put on the bowsprit. I can’t say they are perfect. But...I made them, and they turned out better than I’d hoped!
3FDC4777-1FCD-4AEF-AF62-978E34D09A75.thumb.jpeg.00546ad97d07510fed996560188c9ea1.jpeg4280B09D-2F1C-4F24-9B16-1FF2EE1E2752.thumb.jpeg.47145bc79efa0b92256bb20a3da51960.jpeg798C20A0-BB23-4426-998B-2DCDEC1886E9.thumb.jpeg.4147e7ee9b6c5d5b498a4a2f24eab3de.jpeg
Taking some trial swings at the gammoning before I try on the Sultana.
Moving on...
1 hour ago, Overworked724 said:
But...I made them
That all by itself makes them perfect. Nice work Patrick.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
just thought I’d share...trying to tie the siezing around each leg of the open heart with my big fingers was tough!  Figures a workaround using a straw!  Then just pushed the wrapping off the straw onto the leg of the open heart with tweezers, cinched it up, and a touch of CA on the inside. Not a bad result.
I call it...the Straw Jig!:dancetl6:
Nothing like working in the shiproom during a Midwest snowstorm!
Today I decided to fiddle with ball trucks and the closed heart collars.
The plans call for blocks below the ball trucks (topmast caps). Chuck mentioned that to put a hole in them for the flag halliards would split the wood. I took a few swings at bat with a #37 drill bit in my little dremel and found I could drill them out. However, decided to put them in the top masts as he did...same process with no problem.  Glued the little guys on top of the masts but made a little depression to hold some glue and align them in the mast tops.  The ball trucks were made by cutting small cross sections from a dowel of appropriate size.
AFA8F014-7865-4793-9EA7-59BFA7CAC05E.thumb.jpeg.bb8503e21657dc8e5dfaa805b9202489.jpeg3F4FF449-1DB6-42B9-9B50-4DBCEFC8480F.thumb.jpeg.d7a948b30231dd80fde095ce3100033f.jpegF665B343-D153-435F-A751-3672ABF2C4BD.thumb.jpeg.0a559b499e421b72307221f264c9102a.jpegDBE7EA96-A980-4DF7-BD6F-88DCC283155D.thumb.jpeg.d78c1dca24ac5e4a5028e2a52bc06a30.jpeg
Attaching the jib boom to the bowsprit took some thinking. No novice level references out there with step by step directions I could find...so others may find my pics helpful. As Chuck advises in the practicum, 0.018” thread used to attach the jib boom. Glued the jib boom to the wooden saddle first. Then used a tiny touch of CA glue applied to the rigging line to secure the thread on the bottom of the bowsprit on each successive wrap. ‘Hiding’ the terminating ends of the rigging was done using a threader as shown. Made sure the length of remaining rigging would be buried under the wrapping and not hang out the other side once I pulled it through.  I have to say...it turned out looking pretty clean. I buried one hanging end on either side of the jib boom.
B10C1363-C526-4105-A366-D90B6BE49848.thumb.jpeg.4822d4751cd25ba36009a05ceda20547.jpeg25326902-7FB4-49B9-B434-1086072981B2.thumb.jpeg.3da3d189f5da190396ac7da0123711eb.jpeg7B9E9192-C8F5-4D4B-BE60-8976436AC3A1.thumb.jpeg.b141634819aed2d510f13f30d3946245.jpegDFA31412-F382-4877-BEBA-9DBD1E82D900.thumb.jpeg.b7ff6c0e226521a54906a2d5ee243412.jpeg130E96F5-1FA5-41E3-886D-DC7F674CB23E.thumb.jpeg.4507a89bb2e41ece74f4366a7c5cc8c2.jpeg
Next was the closed heart collars. Two were made for the bowsprit using Chuck’s ‘easy’ way of tiring them off...CA glue touched to a simple slip knot. Pics are self explanatory. I made the closed loops off the bowsprit and slid them on once they were finished.
8F54006A-0E26-40E7-ABE3-D3D1812C9287.thumb.jpeg.4343f802fcf5b4804004e498de86b0e4.jpegC5B2070B-FE44-474E-A2FA-E0B69ADEE393.thumb.jpeg.7a61e79a1d2c634d7747749085a7f5d6.jpeg47FAE308-56A7-480D-AACF-84290FDB9C35.thumb.jpeg.24bf88642c23b419e3ffb6c53f48d842.jpeg
Not a bad day’s work. Step by step.  Moving on!!!
:cheers:
Agreed
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Celebrated too soon.  I was practicing my repeated half hitches (used in the bowsprit gammoning...was practicing on a toothpick to simulate my rigging bundle which forms between the sprit and the stem)...when I realized....
...that I put my bloody JIB-Boom on sideways!!!  Yep...I looked down as I was dry fitting the bowsprit and realized I’d botched the job...the shreaves at the tip of the boom were pointing sideways. :default_wallbash: But wood is forgiving...wood glue even more so. Luckily I used CA glue very modestly in setting up the wrapping around the boom and bowsprit.
Was able to completely unwrap, unglue, reglue, and rewrap the boom with the right orientation. This time I ended up with both the leading and trailing end terminating on one side.
F1B3619E-F7BE-4FB1-9C32-EBA8D1C85DAD.thumb.jpeg.13bef73ce8c1805faa01ea93d4975c73.jpegF8C17798-10B7-4A1D-9678-B138AB91B0B9.thumb.jpeg.94e1b99c489e2f82fb7774647e8ba209.jpeg
sigh...Moving on...
In a pique of incredible courage...screaming “Damn the TORPEDOES!” (And scaring the Admiral in the process)...I decided to mount the bowsprit. Turned out pretty decent!
I am deciding to deviate from the plans and not include the wooden boarder (toe stubber) where the bowsprit intersects the deck. I like the seamless way it looks as it merges with the deck planking.
See you all all next weekend...busy workload the next week.
 393BC2A8-F13D-421C-B531-F942355FD1C7.thumb.jpeg.3f0842f6a9c49ecb02fb87a842d72928.jpegE6A3D955-8D33-4875-8539-DB50F77DE864.thumb.jpeg.d826a95ec806840efa2012e7e0451db0.jpeg
Moving on...:pirate41:
Had some time this evening to practice some knots to lash blocks to spars. My initial attempts turned out decent. Finished rigging up the fore and main top masts. Just a single block on each end of each spar...but a good result for a newbie like me. 32592B48-F79E-475F-9AEE-0B10F68D0EB3.thumb.jpeg.acfaefdbd087d80c7322686173f4ff4f.jpeg
Was going to try to attack the gammoning when I realized I missed something.  The footropes which lead from either side of the bowsprit cap connect to an eyebolt at either side of the bow near the haus holes (anchor rope holes).  Only problem is I forgot to drill the holes for those eyebolts!
Amazing enough...the bowsprit wasn’t glued on as tightly as I’d expected, and I accidentally knocked it off!  No damage but glad this happened because it could have popped off when I was tying the gammoning!!
So...I had some extra room and drilled the foot rope eye bolt holes, then reattached the bowsprit...and it’s pretty solid now!
C03C0290-6589-43CA-BBC4-D91D4C7C642A.thumb.jpeg.2e3488c65df30eadb583b93dda6277c0.jpegB164096E-0738-4B12-8814-49ADB5765624.thumb.jpeg.4aae270aba2e33525fe9ea5d3cab44a1.jpeg
Moving on!!!
