I am starting this hobby again after a false start 25 years ago.
I would really like to get an understanding on what glues are used. I know that CA seems to be the primary glue used or is it? I see that CA comes in Super Thin all the way to Extra Thick. Can someone shed some light on how these differnt viscosities are used?
Thanks
Scott
Good day Scott and welcome back to the hobby.
There will be variations on the opinions but I use wood glue 95% of the time... titebond II and their new transparent that dries clear. This allows for a slow set time usually with the need to clamp the parts in some fashion. Serves my needs quite well.
I use thin CA for immediate attachment and for me is my least favorite because it can run due to it's super low viscosity. When I use it almost every time I end up with some on me somewhere. :(
Thicker CA's set a bit slower and allow a few more moments for adjustment or placement and I prefer that feature.
They all have their place and sit back and wait for it, I'm just the first to respond... my guess is this will be a popular thread... you came to the right place to get educated. :)
Randy
Hi Scott...and welcome aboard MSW.
You'll get a lot of opinions on adhesives.  Many here don't use CA and prefer PVA wood glues. I use both but I'll confine my comments to your CA question.
IN GENERAL, the thicker the CA the longer it takes to set.  Thin is the fastest but it can really get all over the place (including you).  Medium is a little more versatile.  Also, the thicker it is, the stronger the bond.  The CA's are debonded with acetone ---keep that in mind if you glue your fingers together.
None of them sand very well and you always run the risk of sanding away your wooden part and the offending CA is still there.  They can also leave a 'shine' so have some 'Dullcoat' flat lacquer handy if you need to cover that.
As if it doesn't set fast enough, they sell accelerator.  This can actually be useful with the thicker grades.
Some folks report they are allergic to the fumes so be careful if your working inside a confined space (like inside the hull) and you have your face right in it.
If you try and use it on a painted part, it will grab the paint and not the part.  Any force will take the paint and part off.  What I do there is roughen the painted surface before I glue it.  Or even poke tiny holes in it to allow the CA to penetrate.
Hope this gives you some ideas.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Ahoy Scott :D
Welcome to MSW
I like the Titebond Original Wood Glue http://www.titebond.com/product.aspx?id=d4d28015-603f-4dfc-a7d9-f684acc71207
Drying time is not as fast as CA but I find this beneficial for this hobby
Almost no odor and because it is not waterproof mistakes are easily removed using a 50/50 solution of water and 99% isopropyl alcohol and some heat (RC heat gun)
Water clean up
I rarely use CA.
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hi Scott,
I guess it also depends on your dexterity... I have not built much yet but I use PVA as much as possible: with my few CA attempts (I don't know which type of CA exactly) I ended up with fingers glued together or to the ship! And PVA can actually be removed with water which comes in handy when some mistake happens...
This being said, it's just my two cents'...
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Welcome, Scott.   Good luck your new "start".
I'm personally not a big fan of CA.  I used it for parts that wood glue wouldn't work on for my first model, but currently, for metal, plastic parts, I'm finding I like epoxy better than CA.  For all porous materials, wood, paper, etc., I greatly prefer PVA (I use Elmer's regular white glue).
Ron
Hi Scott, my thoughts as a newbie as well.  I thought I would prefer to use CA glue as it seemed much more convenient, but echoing the sentiments of others I've found the PVA to be much more pleasurable to work with and resort to CA only when necessary.  I saw a comment recently which I loved which was that CA glue seems to set much to fast when you don't need it, and way too slow when you do.
DanVad in included a good tip which I really appreciated and found helpful which was to coat both surfaces (not using too much!), you can get a good bond surprisingly quickly (nowhere near as fast as CA) although its worth leaving to dry fully to be safe.
Cheers,
Jason
In the shipyard:
I also prefer PVA (Gorilla or Elmer’s Tight bond is common locally) for general building.  Easy to clean up, no odors or fumes that burn the eyes, much less expensive, and can be diluted with water or isopropyl alcohol and ran through a syringe to get into really tight areas.  I use CA when I need a really fast, strong joint made. And two part epoxy for high stress joints.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
I tried weldbond and didn't really like it.
As to the CA question, one other thing to consider with choosing between viscosity of those glues is what you are going to be bonding together. If you are putting two metal pieces together and there will be no clearance then you are maybe ok to use super thin, but if you are gluing two pieces of wood together you want to use a thicker one since there is more space between the grains and so you need to fill the "gaps" or you won't have good hold...
I will echo what many other people said....when I have the ability to use wood glue (my favorite is gorilla) I use that over CA every time.
-Sarah
Krabbenkutter CUX-87
Harriet Lane
Fishcutter GO-38
In the Wings:
Corel Victory Cross section
Completed Build:
USS Missouri minimissouri.jpgHMS Bounty's Jolly Boat thumbnail.jpg Peterboro Canoe tiny.jpg
Speaking of glue I have a question for you guys. I have read Donald McNarry's books and he never fails to mention a glue called Secotine. I THINK its a fish glue. Anyone here ever get their hands on any of it? I think Secotine is a brand name and maybe its available in the U.S. under a different name? Anyone ever use any sort of fish glue?
Quote
 Niagara USS Constitution
I have used meduim CA almost exclusively on my Bluenose. Recently, I have developed a sensitivity to it (not an allergy, I am a pro at those) so my next build will switch to PVA (Titebond).  Thin CA is good for hardening basswood for carving or making small parts, especially when basswood is all you have to work with. I still use it sparingly when parts are hard to clpam or align and need to set quickly.
Current build: HMS Pegasus, English Pinnace (on hold)
Completed build: MS BluenoseSkippercraft
What is preferred for gluing brass to wood?
Hope
(I've used CA "gap filling" it works OK but make sure your brass is not greasy from your fingers and maybe even roughed a bit so that the glue has something to bite into)
-Sarah
Harriet Lane
Fishcutter GO-38
In the Wings:
Completed Build:
Hi.
As a of a month ago I used cascamite glue. Started my build and changed to a much bigger list.
For any timber I use Aliphatic sandable glue and Everbuild 502 wood adhesive.
I use CA glue on small pieces that require little bonding and speed glueing( not often used ).
I use a two part 30 minute set for strong bonds.
And I have a small contact adhesive for ?? Not used yet. But I like this stuff to do jobs where other glues will not work.
I also use varnish ( of the right colour ) to glue gratings.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hope
Thanks Sarah.  That's a bit scary.  Would some type of epoxy be better?
Robert
Current Build: HMS Mars
The 'roughing up' of the metal surface is the key no matter what kind of adhesive you use Robert.  Sarah has the right idea.
Augie
Previous Builds :
My local art supply store sells dry Rabbit Skin glue flakes. Apparently you have to whip it up in a double boiler when you want to use it. I understand its the traditional glue of violin makers. This fact alone encourages me to give it a try one day event though it sounds like it could be smelly and nasty to prepare- its made of real rabbits after all. Has anyone given this glue a try and have some observations?
Quote
Thanks Augie.  I should be installing some eyebolts in the not too distant future, and really don't want them pulling out during rigging. :o
Robert
Does CA glue have a ‘shelf life’?  Specifically, AFTER the bottle has been opened?
Reason I ask, is for the past few months, I’ve been using a bottle of ‘Mercury Adhesives M300M’, orange label, medium viscosity, 2 ounce bottle.  Starting yesterday, this glue will not ‘set up’ and 'do its job.'  Today, I squirted some on to a piece of cardboard and two hours later, it was still sticky and ‘gloopy’ (a technical term.)  There’s about 15% left in the bottle (bottom of the label.)  I’m positive I did not contaminate the glue and always keep the cap on the bottle.
With just 15% left in the bottle, is there too much air in the bottle?
The obvious fix is going forward I’ll stick with the one ounce bottles.  But I’m just curious why this happened.  ……Yes, I know what ‘they’ say about the curious cat.
It sounds like I use a lot of CA, but I don’t.  When I do use it, I squirt some onto cardboard and then apply with the tip of a bamboo skewer.  More than half of what goes onto the cardboard is still on the cardboard, no cross contamination as one side is for CA and the other for Elmer’s and separate bamboo skewers for each.
Thanks
Dee Dee
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
I don't know if any formal studies were ever run but I've seen CA do what you have described if it's been around for a long while after opening.  It will even change in a sealed container after a very long while.  Some folks keep their unopened bottles in the fridge and claim this helps.  Never tried that myself.
If you must use the batch that's giving you trouble, CA accelerator will make it set.  But I wouldn't trust it for high stress applications.
Augie
Previous Builds :
Thanks Augie.
The obvious is my bottle of CA is older than I thought!  Lesson learned!  Going forward, I’ll stick with one ounce bottles, purchase from vendors/stores that should have a high inventory turnover ratio and write the date on the bottle when opened.
Thanks again!
Dee Dee
(Edited to correct spelling ect.)
Edited by Dee_Dee
Current Build
 - Glad Tidings -MS
Completed Builds
On the Shelf
Ahoy Dee Dee :D
I do not use CA glues very much on my ship models but use the accelerator anytime I use thick CA and highly recommend it. In my opinion, it is the only reason to use the thick CA. Set your part, one positioned introduce the accelerator and your parts are bonded. If I am looking for maximum strength, I use epoxy. No reason to rush, PVA glues. I even use it with the thin CA (just not all the time) if I am not getting the bond I want such as when tacking something being glued with PVA where I cannot maintain pressure.
The problem is most people do not know how to use it. Only apply the accelerator directly to the CA in extreme circumstances, the reaction is too strong. Apply the accelerator to a Q-tip and then bring it near the glue joint preferably underneath it. Do not make contact the fumes will cure the glue. If you can not get under the joint waft some air directing the fumes towards the joint (don't blow) This is all that is needed.
Edited by JPett
  J.Pett
Ahoy Dee Dee :D
My original question asked why CA glue goes bad and Augie responded – It happens!
I’m addicted to breathing without a respirator for the rest of my natural born life.
Thanks, but NO THANKS to using CA accelerators.  Keep your fumes to yourself.  :D
Current Build
 - Glad Tidings -MS
Completed Builds
On the Shelf
Ahoy MSW
I have reposted my original reply and addressed it to the community to whom much of its content was also directed. My hope is to restart the conversation in this thread that I enjoyed up to its abrupt and might I add “rude” interruption.
Ahoy MSW :D
(Don’t blow) That is all that is needed.
  J.Pett
If you want to build models in the one-line mode, use СA, but only it is correct, according to recommendations. I constructed already some models with application of СA and is very happy with this glue.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Was just cruising through when I noticed that a brief comment I made about the use of CA accelerator seemed to have sparked a conflict of sorts.  Or perhaps I've read too much into it.  Either way, we are all free to use, or not, any of the products or techniques discussed on MSW using the safety measures we each establish for ourselves.  Sometimes an otherwise well meaning or humorous statement can be misconstrued.
Hopefully we have  returned to our usual friendly dismeanor.  :)
Augie
Previous Builds :
Especially I like the slow (two-minute) СА glue PT 30 shown on a photo for a tree.
Best regards,
Garward
Ahoy Garward :D
How do you handle mistakes. This is one of my larger concerns
It also seems that you treat the wood first then glue it. Is this correct. Issues with staining CA bonded wood was another problem I had. Perhaps I was doing it backwards :P
  J.Pett
