Fantastic work.....oh so clean.  I'm working on the same thing on the GR.  Magin....that!
Your moving along nicely.  It will be a beautiful model.
Rob
Current build:
Finished build:
Current build(On hold):
18 hours ago, MrBlueJacket said:
So now the 3 gaffs and the boom are installed. This is the fun stuff.
Oh, she is looking magnificent.  wonderful work on the boom and gaffs.
Will she be getting sails.....?
Rob
Current build:
Finished build:
Rob
Thanks, Rob. I'm thinking about a couple of furled sails on the lower yards, and maybe a jib sail. Plenty of time to ponder that............
Here's what I did on the Charles Notman:
Over the weekend, I spent another 4 1/2 hours to get the yard to the stage you see below. I built out the squared ends and yes, there is a sheave inside. There's also 10 eyebolts, 4 wires for the stunsail irons, and of course the truss. Still need to add the footropes. The jackstay supports are .020" thread tied around them.
Nicely done......
Current build:
Finished build:
Looking good...….nice touch on the foot ropes.
Rob
Current build:
Finished build:
Great work...do you know how long  the main yard on the Red Jacket was?
Rob
Current build:
Finished build:
Very nice looking clipper ship. Clean and neat. Hope you are feeling well.
        Bob Porter
Guest clipper randy
to jaager -  where did you get the sea gull plans and is crothers the  designer of all sea gull plans ?
Randy,
http://www.taubmansonline.com/
plans
Historic ship plans
Red Jacket
The parent is Loyalhanna Dockyard.
As far as I know William Crothers was Sea Gull plans and he developed all of them.   If you have CD 1 of NRJ  you can see the add for Sea Gull Plans as he was an advertiser.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Each mast will be differently raked. If they are parallel (with the same rake) they don't look right. Mast rake normally increases as you move aft in a ship for both aesthetic reasons but also because if you splay them by increasing the rake from forward to aft as is normally done, you allow more space between the masts at the top which means you can carry more sail without overlapping them too much. I'm not sure what the variation is on Red Jacket but I seem to recall Cutty Sark's masts were raked 1 degree more from fore mast to main and another degree for the main to the mizzen. I can't recall the exact rake but it was in the high 80s, maybe 87 degrees or so for the main but don't quote me on that number.
How we coming along Nic.....haven't seen any new posts?
You must have some yards mounted.
Rob
Current build:
Finished build:
Super job...love it all coming together.  Do you have a chain sling under the *hounds* fixed to the yard?   Those little boogers can be quite a handful to get just right so the yard is parallel to the deck and the truss is perpendicular to the mast.
Love it.....looks so clean.
Rob
Edited by rwiederrich
Current build:
Finished build:
Oh....on the Red Jacket the sling went through the tops and over the mast cap, or through the tops and around the main mast doubling instead of bolted to the mast between the mast cheeks?  Interesting.  I knew many designs were incorporated, but not so sure they were incorporated on clippers.
Great job.
Rob
Current build:
Finished build:
Interesting configuration.
Rob
Current build:
Finished build:
