Thanks for all the comments and the likes!
I’ve been busy today.  I painted the head and touched up the rest of the model.
I remade the rudder, and painted and coppered it.  I also made hinge straps.  I had a little accident involving superglue, so some of the hull got another layer of copper.  I made a tiller and attached it.
 I made some trim, following the Smithsonian’s model.  I also made the bottom part of the deckhouse, it’s not glued down yet.
All in all, I’m making decent progress and am happy with the results.
Building:
I am working on the aft deckhouse which is now glued down.
I made the skylight out of card and the plastic from my X-Acto blister.
Tip for those making lanterns and windows: blister packs are a great source of clear plastic.  I use them frequently.
 I accidentally used too much glue when I attached the skylight to the deckhouse which means I get to do some paint work tomorrow.
Building:
The gratings are made, but not glued down.  The galley funnel is also made, but not glued down.  I will glue them down after I paint them.
 I have 2 winches, 1 mast base, 2 pumps, 2 bitts and a deckhouse remaining for deck furniture.  I still need to make the catheads, the bitts on the cap rail, the channels, the anchors and some fife rails, so that I have belaying points.  I also need to make a platform, above where the bowsprit will be mounted, and a figurehead.
After that I need to make some decisions about the guns.
 I think that I am going to use continental guns (French) and gun tackle because the Prince de Neufchatel was fitted out for privateer service in Cherbourg.  I am going to have most of the gunports open.
 I also need to make the ship’s boats.  The Smithsonian’s model has 3.  I think that I will do likewise.  They will be the last things that I make before making the masts.
Building:
The majority of the deck fittings are made and installed now.
The next step will be to make the bulwark fittings and the bowsprit.  I am going to temp install the bowsprit so I know where to place the platform, that sits on top of it.
Edited by GrandpaPhil
Building:
Phil,
Since you don't have a lathe, improvise.  You'd be surprised what you can chuck into an electric drill or even a Dremel and then shape with files, sanding sticks, etc.  I must say that you did a nice job without a lathe.
11 hours ago, mtaylor said:
Phil,
Thank you!
I’m going to try to chuck a dowel rod into my drill for my cannons, and deadeyes.
Building:
I painted the stern bitts.
 I have also made the forward channels.
In the Endymion’s action report, the Captain states that Prince de Neufchatel didn’t have channels.  I made them really narrow (1/8” wide) to go with this.
Building:
Channels are attached.  I added extra glue to give more strength.
 I made proof of concept rigging blocks.  I think that they turned out okay.
I’m pretty happy with my progress so far, and how the model is turning out.
I’m learning a lot.
Building:
The original figurehead of the Prince de Neufchatel was described as a “Coronal” figurehead.  It was unshipped at sea when the British captured the Prince de Neufchatel.  I believe that’s a polite way of saying that the British commander threw it overboard.
 The Prince de Neufchatel was named after Napoleon’s Chief of Staff Louis-Alexandre Berthier.  I believe that the figurehead was in the likeness of the Monsieur Berthier.  Given the state of things at the time, I wouldn’t necessarily have blamed the British commander for tossing it overboard.
By the way, to give credit, I learned all of this on this forum.
 I would like to build the Prince de Neufchatel as I believe she would have appeared while an American Privateer, so I am going to make the figurehead in the likeness of the Prince de Neufchatel, Louis-Alexandre Berthier.
I’m not the greatest artist (or carver), but here goes:
Building:
One figurehead.  It’s not perfect, but I think that it will look okay on the model.  It’s carved in basswood (because I have lots of it).  I already dry fitted it, and it fits perfectly.
This is my first three dimensional carving.
 The rest of my carvings have been flats, like stern carvings.  I did a bunch of those during a recent business trip.  I just carved pieces from random ships.
Note: this will be painted before being attached to the model.
Building:
I did a little bit of work on the figurehead.  I reshaped the lower part of the torso to follow the shape of the breakwater.
 I sealed the figurehead in preparation for painting.
Building:
This is my impression of the Prince de Neufchatel, Louis-Alexandre Berthier.  I do not know if it is correct because there is no actual historical record of the original figurehead, but I think that it is a decent rendition and it will do quite nicely for this model. 😀
Building:
The figurehead is attached.  I’m happy with it.
I’m working on making a nice collection of rigging fittings (blocks, deadeyes, etc.).
I’m waiting on the “Search for Speed Under Sail” by Howard Chapelle before I arm and rig the Prince de Neufchatel.  I’ve  been trying to get a copy of it since December 10.  I’ve ordered it twice now, lol.  I didn’t get the first one (I got my money back).  The second order has ended up on a truck on the wrong side of the country.  I’m waiting to see if I actually get it.
If I don’t, I’m going to use the rigging plan in “American Sailing Ships”, which is 1/320 scale (half of this model has been guesswork anyway), and arm it with 4 x 9 pound long guns, 2 x 12 pound long guns and 12 x 12 pound carronades.
Zu Monfeld has some nice drawings of Continental gun carriages that I will use to make the carriages.  I have plans of 9 and 12 pound long guns and an older style 12 pound carronade in my Anatomy of the Ship books.
I still have to make the ships boats anyway.  I’m using the plans in the Victory’s Anatomy of the Ship book.  I’m going to make a male mold out of wood and build them like Zu Monfeld demonstrates (only out of card).
I need the scale molds anyway, because I plan on building many more models.  I very much enjoy the hobby.
Building:
I’ve been making single-sheave blocks and deadeyes.
I’ve been making the blocks out of 1/8” stock.  I measured them off 13/64” intervals.  I made a cross cut there on all four sides.  I then drill the hole for the line and make a longitudinal line on all four sides.  Then I cut the blocks free.  I’ve been making 12 at a time.
Building:
To make deadeyes I’ve been using dowel rods.  I started by cutting the grooves with a knife.  Make sure when cutting the groove you make the first cut from the outside-in, otherwise the wood will split.   Next, I cut the deadeyes off.  Then I drill the holes and sand the deadeyes smooth.
I started out predilling the holes in the dowel rod, but that caused alignment problems.
 I used an Excel hobby knife with a #11 X-Acto blade and a pinvise.
Building:
