Test fit on the boat..   My rope is more of a hemp color as seen in the pictures previously..   Phone camera wants to make it lighter..
I will be blackening the bolts on the tackle fittings..
― Jimmy Buffett
On Hold:    Rattlesnake
Been a while since an update, but I have been slowly going forward with rigging..
A lot of hooks blocks and tackles.  Not really tying anything off at this point.  Yards are made, but not ready for prime time yet.
― Jimmy Buffett
  • 2 months later...
Thanks for dropping in.  Makes me feel amiss in not updating more often, but   work progresses slowly.
I have completed most of the standing rigging and the running rigging is coming along.
I used the laser to cut the spars.  I make them with two parts that I finish individually then join together.
For me it makes for easier handling than one long piece..
Ready to be hoisted.
332646142_Pennant1.thumb.jpg.435743fbc147c37db531caf36b6e53c8.jpg\
A pennant that will fly from the top of the topmast that still needs to be completed.
Setting up the shrouds...
There is quite a bit of other rigging completed..   I just need to take the time to make some pictures that I am ready to share..
― Jimmy Buffett
I’m not to the rigging portion of my build yet, but I’m going to follow yours because you are doing a fabulous job of photographing your rigging work! Looks great! Thank you! 👍
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Thanks Glenn and Dave.
Glenn, your build log of Cheerful is my source of inspiration for many rigging details.  Your close up photography is priceless.
@Dave
Quote
  I'll try to provide some more detail and a chance for you  to avoid my mistakes..  😃
I mentioned earlier that I have the Cheerful plans, which I am following fairly closely.
Make sure you check some of the Cheerful builds..   They are my go-to for Cutter rigging.  Particularly Glenn's which I mentioned above.
I'm having to deviate from a pure cutter rig because this model has a bowsprit plus a jib boom.  I will be improvising and deviating from actual practice in some respects.
Edited by Gregory
― Jimmy Buffett
Updating with a few rigging details..  Here are the shrouds tied off.
The backstays.
The mast head
I'm using these hooks from Crafty Sailor.
The Main Stay.
The ensign.
Thanks for stopping by..
― Jimmy Buffett
I’m very glad it is of help, that is my primary goal for my logs - to help others as I’ve been helped.
Regards,
Glenn
Current Build: HM Flirt
  • 2 years later...
Well, hard to believe it's been almost three years since I worked on Resolution.
I was in the home stretch with rigging when the cat decided all that 'string' looked like something that needed special attention only a cat can give.
The mast snapped right below the trestle trees, and fortunately nothing else actually came apart or broke.
I feel pretty sure I can get the mast back in position and repaired without having to actually  re-do any of the rigging that was already in place.  I had just started the ratlines so I hope to be able to continue with that in the near future.
Edited by Gregory
― Jimmy Buffett
  • 3 months later...
Hope you still like the cat, and hopefully you can get it all back together without to much trouble.  I have dogs and they can do some damage as well if they get ruff housing around.  Luckily, nothing has broken yet.
Look forward to seeing it all repaired and in another post you told me you did some laser cutting for this model.  Makes me wonder if I should have a laser for my miniatures.  Still on the fence on that one.  Like to have one or a cnc router, but $$$ right now is tight so both will have to wait awhile.
