FINISHED -- F3F-1 and F3F-2 by Landlubber Mike - Accurate Miniatures 1/48 with aftermarket
I don't want to take over Mike's fantastic builds with my get well stuff but thank you all just the same. Definitely DO NOT slow down on my account Mike. Your daughters will run all over you and we will miss some very fine modeling skills if you do! NOT a good thing.
Getting a little more mobile every day and most of the drug haze is fading away. Hopefully will see what I can do in a few more weeks when all the dust settles. Not expecting a spring chicken at my age but who knows?
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Share on other sites
Glad to hear you're coming along Lou - hopefully the dust settles sooner rather than later.  Hang in there my friend!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
I'm a latecomer to this log, there has been wonderful work undertaken to these little planes.
I noted your issues with masking, there was an interesting article  in the Journal by Kurt Van Dahm (Vol 64, pages 282 to 284) and one thing that was recommended in addition to burnishing was  spraying a light coat of the original /base colour along the edges of the masks at 90 degrees to the surface to seal the edges and prevent bleed under the tape. Obviously you need to be careful with coverage so as to not to cause a raised edge.
I haven't tried it myself but it seems quite logical.
Current Builds
Mikasa by I Love Kit - 1:200 - Plastic
HMS Beagle by Occre - 1:48 - Wood
Link to comment
Thanks very much!
I've read similar tips, as well as spraying a bit of clear coat to seal the edge.  My guess is you have to be careful as you say not to spray too much and get a raised edge.  One thing I personally need to be better about is spraying multiple thin coats rather than try to get the paint down in one go because I've gotten raised edges from putting too much paint down.  Better to spray a light coat, and then come back if you need it.  In the long run, saves much more time over having to fix raised lines, bleeding, etc.
Mike
Link to comment
I use a dual action airbrush and its something you get use to - after while your finger sort of automatically knows how far back to the pull the trigger. I also use quick drying paints (Tamiya or Mr Colour) plus I live in the tropics so you can paint the next coat almost immediately, so there no need to be impatient.  Also I don't lay anything paint or varnish that hasn't been thinned to at least 50/50. Primers even less.
It didn't mention it specifically in the article but maybe you could thin your paint further for any bleed protection activities, I suppose it all comes down to trial and error.
Current Builds
Link to comment
the planes look fantastic Mike!   the rigging looks superb....... :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thinning sounds like a good idea.  I've been mostly using Vallejo, which you can shoot straight from the bottle.  I've found, however, that some of their products (like the Metal Varnish) greatly improve with a little Vallejo thinner added.  Some of their primers are a bit thick too, so I might try thinning them a tad as well.  In any event, now that I'm a little more familiar with various paints and the airbrush, I'll probably resort to thinning even Vallejo.
Mike
Link to comment
Just catching back up Mike. They finished up great. Nicely done!
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Link to comment
Thanks Joe, really appreciate it!
Mike
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
