I bought one some time ago when it was on sale.  Here's the current webpage: http://www.harborfreight.com/power-tools/cut-off-saws/bench-top-cut-off-saw-42307.html
This is similar to the one MicroMark sells for roughly twice the price.
It's a good tool but not a great one.  Once the miter guage is calibrated, it cuts crisply and cleanly with no blade wobble. The vise holds the wood firmly.  However, the miter gauge will need to be checked anytime it's moved to a new setting due to the slop in the mechanism.  Also, use a piece of wood about 1/16" (1 mm) or so behind the workpiece to move it forward otherwise the wood is not completely cut.
Below is a pic of mine with an attachment so can see where the blade is actually cutting. It also provides a precise method ot put a small ruler to get repeatable cuts.
Would I buy another one? Yes. For the money, it's a pretty good deal as long as you're aware of it's limitations
Hi Mark,
I have also used one for some time, and as you say, very useful within its limitations - Even with a mitre box I find it difficult to get nice straight cuts for planks.  This link takes you to an article in the MSD which shows some interesting modifcations.
cheers
Pat
Hi Pat,
I saw that and added my mod based on it.  I forgot to check the MSD when I was posting to see if the article was back.  My bad..... :blush:
  • 5 years later...
Could one of you update your opinion of this saw now that it is five years later?
still have it? Still working?
Thanks.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
Hmm, for this tool and other operations, a Wixey digital protractor could be very useful.
http://wixey.com/products.html
In the old days, I calculated the angles trigonometrically and then used a 12" hundredths' ruler to lay out the angles and cut lines. This was tedious at times.  The precision required for a larger object, e.g. a kitchen cabinet door, is likely greater than for a smaller object such as the parts of a model (since the greater the distance, the greater the inaccuracy (error)).
But for starters, this item might be ok:
http://wixey.com/digitalprotractor/index.html#rule
Hi, I still have this saw and it performs well.  The only issue I experienced was when changing blades I did not put the support flange washers on correctly and it wobbled.  Other than that does a grand job of cutting straight - sharp blades are essential as with any saw.
Note this saw does 90 degree cuts only if modified as I have.
cheers
Pat
Edited by BANYAN
I too have one and it does the job for me, but as Mike said, one has to be aware of its limitations.  For me, I added an adjustable stop on the starboard side which allows repetitive cuts of the same length.  Plus the real benefit is cutting brass and aluminum tubing.  For $33, it is a decent tool.    Duff
Steve bought mine in 2013, 2 extra blades and ordered 2 fine tooth blades on-line. Works as good as when it was purchased. When I posted the saw way back it was met with a little disdain, and numerous suggestions of better saws available which were more expensive.
Love it, will soon by there scroll saw, and mini table saw and combo belt and disc sander. which will leave me a lot of cash to purchase other materials. I can hear the groans now  why these machines are cheap and aren't precise and etc.
Fact is I am 70 will not be building scratch models of museum quality that take years to construct am happy with Harbor Freights cheap tools that serve my purpose and saves a lot of money. Would recommend everything they sell for people that do not have deep pockets. I am a Happy Camper. :D
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
I'm not particularly hung up on name brands.  Often a less expensive tool can be very useful with minor modifications.  That said, I think that I would certainly compare HF with Grizzly before buying.  Grizzly sells tools with a full range of features,  for hobbyists and industrial manufacturers.  They also stock a full line of replacement parts and their customer support is excellent.  Most of their machinery is probably from Taiwan, and their quality control is quite good.
I would thoroughly check customer reviews on both companies.
John Allen
On deck
Finished
Steve.
I gave mine away as I realized I wasn't using it that much.   Shortage of bench space and having to set it up wasn't worth the time to me as right next to where I would use it was my mini table saw.  More functionality with the table saw (for me) and less hassle all around.
Thanks for the info. I picked one up this afternoon. I’ll be playing with modifications tomorrow.
Steve
-- Jack Aubrey
Builds:
  • 1 year later...
I just picked up one at Harbor freight  yesterday and been playing around with it. It seems to be a good one, but time will tell. I have a 12 inch chop saw which I use as much as my table saw so figure that this little chop saw should fit in really nice. Now all I have to do is figure out how to make it a little higher so I can see what am cutting. Maybe a table on top of the table. . Gary
A Wixey digital protractor (for setting the miter gauge) would be a modestly priced ($12USD) and useful addition to your shop. Resolution to 0.3 degrees
Edited by Bob Blarney
