That looks great Rob, the rigging is really coming to life now.  I really like the shroud fairleads; they sit perfectly and look the real deal - take a bow :)
cheers
Pat
4 hours ago, druxey said:
Looking fabulous. Belaying those lines must be tricky in those confined spaces.
Indeed, that is why I use foot long tweezers and good agility.  Still it takes a steady hand.
Rob
Current build:
Finished build:
Current build(On hold):
Very impressive rigging work!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
cheers
Pat
Yeah……those fair leads are smaller then a 1/16” and with 3 leads through them that thread like needles.     Tiny stuff.   I had to add two more belay pins at the rail to accommodate all the additional lines coming in from the mizzenmast yards.
Calculating the sequence of line install takes as much thought at actually installing the lines……so I have no mishaps with tangling and crisscrossing.
Thank for the confidence.
Rob
Current build:
Finished build:
Thanks Elijah.   Quite time consuming.
Rob
Current build:
Finished build:
Rob,
For Vladimir's sake, I really hope you're keeping meticulous records of your impressive rigging scheme. It's nothing short of amazing!
Added a few rope coils to the rail
Current build:
Finished build:
Rob,
Addition of those rope coils to the belaying points is an ultimate touch of miniature realism. When she's complete, your Glory of the Seas Clipper Ship with such devout attention to detail will blow people away.
These little guys(No more then a 1/4" long) are problematic in their installation.  But they have to go in pretty much as the line gets belayed....because of space restrictions.  I can spend an hour just planning out the next series of installs.  Do I run the mizzen yard pennants and their braces down to their main mast blocks and then down to their belay pins......or do I do the same for the main mast yard pennants and their braces down to the mizzen mast blocks and down to their belay pins.........or lastly...do I run all the haulyards and their purchases for the main mast yards first?
This mental process takes time....but really what is happening, is I'm trying to devise the easiest systematic process for install of all these elements, in the easiest sequence.
For my mental stability's sake.    I chose to run the main mast haulyards first....because, I had to reach deep within the build to add the deck eye bolts for the haulyard origin and the return blocks on the opposite side, mounted on the pin rail cap.  8 holes drilled for 4 eyebolts and 4 blocks-n-eyebolts.    Thank the Lord I have small 90deg drill heads for my dental hand pieces......Or I would never have been able to successfully drill the holes for all those eyebolts.   Foot long sharp tip tweezers are essential.
One final note.  I'm not sure if I  will  be adding the stay sail rigging....most of the time, these sails and their rigging where un bent and brought down while the vessel was in port.   I'm still thinking about it.
All of this before I install the backstays
Rob
Current build:
Finished build:
I opted to add the Down haul and lift rigging for the stays.   Simple but appropriate.
Rob
Edited by rwiederrich
Current build:
Finished build:
Next I added the main yard down hauls and their purchases.
Next will be the mizzenmast braces.
Rob
Current build:
Finished build:
Beautiful Rob.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks everyone for the fine compliments.
I spent time running the rest of the main mast haul yards as well as the starboard mizzenmast braces. All these internal lines must be rigged before the back stays.  I opted to work this side as much before I flip her around…….since that is becoming a real task.  While I was thinking, chose to drill out the hull fairleads for the main upper and lower topsail yard braces.
Here is a few pics of what I have done thus far.
Rob
Current build:
Finished build:
Now I’m ready to begin the starboard backstays.
Rob
Current build:
Finished build:
All starboard back stays installed.
Now it’s time to add the main mast yard braces…………man what a spider web.
Current build:
Finished build:
Finished the top gallant, royal and sky sail yard braces for this side.  I’m not addressing the topsails till I mount the main.   Makes working around it easier.
Rob
Current build:
Finished build:
7 minutes ago, BANYAN said:
Phew, your rollicking along now Rob; that rigging looks good.
cheers
Pat
My goal is to get the main mast rigging all done on the starboard side today.   I did a lot of work……about 8 hours of work.
Rob
Current build:
Finished build:
Turned her around and am setting up to do it all over again.   Some close ups too.
Rob
Current build:
Finished build:
Rob,
Unless someone has stood on the deck of a tall ship and stared straight up at the apparently bewildering latticework of complex blocks, tackles and practically limitless lines, they cannot fully comprehend how incredibly faithful to an actual sailing ship your work is. Looking intently at these images brings me back several years to when I was standing on the deck of the venerable Frigate USS Constitution "Old Ironsides." I remember craning my neck backwards as I stood behind the main mast. There's something just so relaxing to view those lofty masts and powerful yardarms. I get that exact same feeling now as I review your  pictures. Well done indeed.
Rob
Qq
Thanks Rich.  Still have the top yards and the entire main yard rigging.   It will be a great contribution to the gossamer web of lines.
After the rigging is finished on the main mast, I will add the Davit’s and their gear.
Then one more mast and I’ll be through.
yeah……….
Rob
Current build:
Finished build:
9 hours ago, druxey said:
Every post make the model appear more and more impressive!
Thanks Druxey.  The more  lines that go in...the more and more I need to be diligent not to tangle or cross them.(I almost get crossed eyed).  Praise God, I have had only one line I had to remove and re rig due to slight crossing, and that was a main topgallant brace...I failed to recognize it had to have a greater range of motion, because the yard is hauled down.  When she is raised the brace would interfere with the brace from the mizzen counterpart.
All is well.  I think my plan is being fruitful...by doing all the internal work first...to include braces, downhauls and any stay work....and leaving the backstays for near last.  Once I figured out the sequence...even though it appeared to work against what seamed to be the logical next step, things move along quite nicely.
The real work will come when I need to introduce all the rope coils at all the belay points....using ft long tweezers......:default_wallbash:
Rob
Current build:
Finished build:
Rob, just a dumb process question. Can't you put in rope coils after you secure lines, at least some of them? That way, wouldn't it relieve you of some of that challenging, I've got to imagine tricky 1 ft tweezer work? Or, does doing it that way slow down your process even more than they way your doing it now?
Actually,  I try to add rope coils pretty quickly, but sometimes the process requires me to wait till a segment is finished.  I tell you it’s a juggle.   But it’s all worth the effort.
Rob
Current build:
Finished build:
Rob,
Having been on several tall ships, I've been able to see these rope coils first hand. Believe me, the realism you're portraying is first rate. Your replica would look odd and unfinished without them. And it's a tribute to your meticulous attention to all the little details.
2 hours ago, Sailor1234567890 said:
How about a wide view of her whole self?
Sailor……..I don’t have any good full views of her…… but  some like this on the bench.
Rob
Current build:
Finished build:
