Started upper planking and lining waist gun ports prior to fixing upper gun deck cannon.
There are ten cannon in view on this deck and I want to fix the carriages whilst I can still get in there
and before the gangways are fixed.  Just the carriages fixed and rigged at this stage.
I can add the barrels much later.  The cap squares will need to be painted on before fitting the carriages.
Hopefully they will be partly hidden.
Not impressed with all four wheels being the same diameter but as all the decks on this kit are
flat and not cambered they probably thought different sizes weren't necessary.
Will not be fitting the dummy barrels on this deck  -  having closed gunport lids instead.
Thinking of the same for the lower gun deck.
Photo shows bits required for one carriage before assembly and painting.IMG_0633.thumb.jpeg.160f6c0d7c6f313bd3d375cc0bb26a07.jpeg
Started assembly of 10 cannons  -  waist of upper gun deck.
Fitted new scalpel blades and broke out a new razor saw to cut out the carriage parts.
Assembled all the bits and then took stock.
Bits missing from the plywood parts due to delamination. these will need several coats of paint to cover the plywood
so decided to make good. Be as careful as you like  -  these bits will break.
Trunnions pre-fitted to barrels and about half were deformed and needed straightening.
Broke off three spoiling two barrels before throwing them all in the bin (not even the spares box !!).
Replaced with barrels from spares box.
Assembled basic carcase,  applied first of many coats of paint and fixed axles.
Axles are far too small for wheels provided  -  photo attached.  Will be replaced with wooden cocktail sticks.
Not looking forward to removing twenty axles without damaging the ply carriages.
One step forward,  two back.  Can't find replacement carriages of the correct period or I would have
binned this lot days ago.
Should have taken more notice of Mark's postings ref. armament on this kit.IMG_0646.thumb.jpeg.26b248abada6787e02e10268c9eb1531.jpeg
Turning into an interesting build.
After several disastrous efforts at fixing gun tackles and not being able to source double blocks
small enough not to look stupid I gave in.
Final solution is a blatant lift from  -
Superdetailing the Cutter Sherbourne  by  George Bandurek.
Carriages end up fixed in the "stowed position".
0.75mm line is coiled twice around a wire armature then trimmed to 1mm long
and fixed in position.IMG_0659.thumb.jpeg.63fa2134095e5bf2ea9961dd6eaacabf.jpegIMG_0660.thumb.jpeg.648e1fbb7be27dd1a20eb2044f10479d.jpegIMG_0666.thumb.jpeg.b276aa5aa9ee80c18571a7d61b2b1bbe.jpegIMG_0667.thumb.jpeg.97c17c2e1f7385bc3afa7cbc2e1e57ec.jpeg
Not what I intended but the best I could come up with.
Sam.
Upper gun deck finished for now and waist gangway beams fixed.
Read Mark Tiedens post ref the gangway supports and, the instruction book supplied.
Agree 100% on the columns. (Replacements on order).
Will not be following the supplied instructions but will also go for one continuous beam
which will also cover the edge of the false gangway and the edge plank.
Occre's approach is to provide plywood where ever possible and, where seen  -  paint it red.
I'm trying for a more natural look.   Mark's paint job is superb but I can't re-create this quality
hence my reliance on stain and varnish.
Cannon barrels will be removed, blackened and stored for later.
Thanks for the kind words:).  You are doing a fine job with this kit - I was able to cover much of the plywood edges with gobs of paint,but even with that it would have been nice to have plywood that didn`t fall apart just by looking at it!
current build - HMS Vanguard - Model Shipways
Thanks for the comments Mark and, everyone for the likes.
This kit is turning into a sturdy well designed build but treat the instructions as a guide only.
Compared with some previous kits the main framing needed very little work
but Oh, that plywood is still a problem with me.
Your build and Sferoida's show the end result is worth the hassle and extra work.
Sam
Gangway blanks fitted and edges trimmed.  These will be reduced in height to suit the deck planking
after planks are fixed.   So lots of work over Christmas.
Second photo shows replacement columns.
Supplied by Cornwall Model Boats.   Ordered on line early afternoon and delivered the following morning
slightly more IMG_0671.thumb.jpeg.5056ea63e100cc8c075a810023b3553d.jpegIMG_0673.thumb.jpeg.5201bfe00681127d81d1dcf317ce2db4.jpegthan 20 hours later.  It helps that they are just up the road from me but still impressive.
The next build stages should go more quickly,  will be using kit parts and stock items.
Sam.
Thanks for the likes.
Attached is progress on upper deck planking.
Next will be the cabin walls.  The dreaded ply again.
I have already decided to plank them.
Also to be planked will be the inner bulwarks but I will use the ply pieces supplied as templates.
Happy New Year,
Sam.IMG_0683.thumb.jpeg.4baf492df67dbc5b798547469064e736.jpegIMG_0684.thumb.jpeg.9f50806fd4a05aec44763206991aec0c.jpeg
Steering gear assembled and rigged.  Dry fitted for photo's.
Permanent fix before poop deck fixed due to limited access.
Instructions seem to be written to suit supply of parts in stages.
Probably explains why the kit arrived in six boxes.
Spending a fair amount of time moving back and forth through the instructions.
Getting it correct most of the time.
Sam.
IMG_0706.thumb.jpeg.876fde4663a3388e97c71bf0c6e30495.jpegIMG_0707.thumb.jpeg.257b8a3dc38fd427bf7d71fd03a0831b.jpeg
It's interesting that you received it in six boxes. They have the kit in a single box at Ages of Sail.
You somehow received the kit from their supply of "Packs" or part kits, but I think the instructions are the same as the ones in the full kit.
This is the only kit I'm aware of where OcCre actually broke down the instructions into six stages to match the part kits. I have the Montañes as a part kit and you just build until you don't have enough pieces to go on, which now that I think about it, is going to be pretty weird.
Your NS del Pilar is looking great!
Thanks for the likes and, your comments Catopower.
Post one of this thread shows how the kit arrived.
Six boxes of various sizes all assembled into a stout cardboard sleeve. This was plain, no markings.
This was placed inside a thin highly decorated cardboard sleeve.
You are right Catopower, I have found a website  (D'Agostini) who sell all sorts of kits
especially the full Occre range.   You can buy these in stages or, as a full kit.
I bought my kit from Cornwall model Boats (as a complete kit) during the pandemic.
Now I realise that this can be bought in stages the instruction book makes more sense in it's layout.
First thing I did on receipt was unpack to make sure it was all there and then stored it all
in one box, AL's HMAT  Bounty kit box (which luckily I didn't throw away).
Thanks for the imput.
Sam.
Hi Sam,
I was interested in the N.S. del Pilar kit, but I initially got turned off because of the oddness of the poop deck in the kit. The edge of the upper-most deck is oddly exposed, extending out past the bulwarks. This didn't seem right to me.
But, hen, I ran across some plans of the ship and saw photos of older models of the ship, and they all show this rather unusual feature. Readin a little about her history, and about how she was rebuilt in 1750, I'm guessing that the poop deck might have been extended to increase the number of cabins or cabin space on the quarterdeck below.
I any case, I now find her a very interesting ship, and am enjoying following your build.
Hi Catopower,
Thanks for the info and interest shown.
Before starting this kit the earliest build I attempted was HMAT Bounty,  1783.
Before this I kept to the 1790  -  1815 era.
So I assumed the odd difference was due to advancements in building technique
between 1733 and 1750 when she sank and later building practice and design.
I have already deviated from the plans provided and intend to treat the poop deck
very differently also.   This build will end up as a generic model and will be un-named.
Also, should you be on the poop deck puzzling over the weird arrangement and,
someone shouts  "dinners ready"  don't rush down the ladders to the upper deck
because someone left a cannon at the bottom of the stairs.  Looking at the height of this cannon port
above the deck it could only be used against low flying aircraft and would probably be stored elsewhere.
I used the ply piece supplied in the kit to locate this port and now wish I hadn't.IMG_0708.thumb.jpeg.8c80ba282363384cdaaabd49450d1663.jpeg
After all that, I am enjoying this build and it will end up an impressive piece.
Regards,
Sam.
Haven't posted for a while  -  been fixing the first planking. There is a lot of it.
For light relief have been working on the stern piece.
Attached photo's show cabin rear walls. Extra coat of yellow ocre needed
Next is the balustrading and lower stern piece.
Also the hull planking. Starting to question the wisdom of double planking.
There is so much of it.
Sam.IMG_0712.thumb.jpeg.aa0e73617ccbbeb916685b0376add9ea.jpegIMG_0717.thumb.jpeg.91d7a7095a95b7a85ddab0b4752415e7.jpegIMG_0719.thumb.jpeg.a8849e3af6f05e0f99f10b48a0e0ad7f.jpeg
Very nice!
The stern piece looks great.😉
Edited by Edwardkenway
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
