Hi Richard,
Here's the instructions on how to upload photos:
My take on porthole construction:
1. I like the approach of previous posts that used templates for the construction of framing about the portholes (see photo)
2. First I cut the sill slots on one frame only.
3. I trim the next frame (base of sill using the template to determine where to cut.
4. Temporarily setting the outside frame against the sill base, I mark the cut positions, remove the frame and perform the sill cuts.
5. I set and glue one frame spacer into position and clamp (see photo).
6. After the glue is set in step 5, I glue the short frame upright over the middle of the sill  and the final spacer into position. I use home made clamps fabricated as described on p.44 of "The Anatomy of Nelson's Ships" by Longridge. I find these clamps to be the most versatile.
There is some conflict with the frame positions on the building board, but I chose to use the positioning dictated by the templates which conform to the NMM plans.
