27 minutes ago, Tim Moore said:
Well done Dave! Congrats on pushing through all that rigging.
Thank you Tim for all your help, especially with the rigging
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
41 minutes ago, Gregory said:
A Very nice Bounty!
I think you may have set a record for completing a kit, not counting James H. and his Vanguard prototypes..
Thank you Gregory for all your help and keeping an eye on my progress. Best regards Dave
1 hour ago, Gregory said:
Any plans for your next ship?
Yes I have been looking at the Endeavour by Caldercraft due to local interest. However I understand it is quite a difficult model to build for a beginner. I won,t be starting my next model until October/November when the autumn begins to settle in.
Who's a beginner?
I think your experience with the Bounty should move you up a notch or two..
― Jimmy Buffett
Slow crawl:    Rattlesnake
37 minutes ago, Gregory said:
Who's a beginner?
Agreed! I think you will be able to build an excellent Endeavour 👍
Well done on your Bounty build! 👏
Looking forward to your build..
You have several months to ask questions and prepare.. Don't wait till the build starts..
I wish more members would ask questions like you have during your Bounty build..
― Jimmy Buffett
Funny you should mention that. I already have a few questions and I haven't seen the kit yet!.
22 minutes ago, Gregory said:
Just start a topic in the General Ship Model Kit Discussions
I already did a few days ago.
I will of coarse add any question I may have, as they arise. I will eventually start another blog once I have purchased the Endeavour kit  which should be sometime next month. I am also planning on buying either a drill press or even a milling m/c at some stage before I start building in the hope of producing better elements of the model . I also have a thread running on this subject too.
Edited by DaveBaxt
I will be watching..  I Don't have any experience with Caldercraft, but I think they are a cut above some kits i have worked on.
I like the look of walnut, but you will find it's detractors among some ' purists '..
I wonder how it responds to " Chuck's edge bending method " ?
― Jimmy Buffett
I've been using Chuck's method on my Bounty build. Considering that I'm working with 5mm X 2mm walnut and in some cases 10mm X 2mm, it works well but it does take a little extra time.
It takes about 20-30 minutes to soak a piece long enough to bend it and you may need to bend it twice to keep it from snapping!
I use almost an exact set-up to Chucks except I use a sealing iron for heat.
Check out my build log for more details and pictures if you're interested.
BTW, Dave, your build is beautiful!
 Well done! The Endeavor is on my short list too... I'll be watching for your log!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Thank you Lyle for your input. I did exactly the same for the Bounty using a heating Iron and Chucks method of marking off and bending edge ways and as you say takes a bit more time but turned out quite good in the end. I will take a look at your log and compare notes haha. For the record the Bounty's first layer of planking is also Walnut where as the Endeavour is lime. The Bounty's first layer was also 6mm wide x 1.5mm thick which wasn,t without issue but I ended up soaking overnight as this seemed to be the only way to bend the planks on their edge. I did not need to do this with the second planking as it was only 0.5mm thick.The Endeavour's second planking 1mm thick so I might have to soak this too for sometime.  Bestregards Dave
I used Chucks method of bending edgeways on the Bounty using 6 mm x 1.5 mm Walnut strips. and was not without its problemms. I ended up soaking the strips overnight , enough for the next day and this worked fine .At the time I was informed that there was minimum shrinkage with Walnut but I did use a heating Iron as well . The second layer was much easier although also Walnut was only 0.5mm thick and 4 mm wide. The Endeavours first planking is lime so hoping it will be easier to work with.
9 minutes ago, Trond said:
Grats for finish the Bounty. You've done a marvelous job Dave. It really look nice.
Looking forward to follow your next project.
Thanks Trond. I am still popping in to have a look at your  progress from time to time
I definately like your version of the Bounty with the open decks. It is a credit to the hobby. Hopefully one day I will return to the Bounty once again and have a go at the Artesinia Bounty once I have honed my skills a bit more.
I think your skill level is great!
Good luck with your next build and stop by my log once in a while! Always appreciate feedback!
Lyle
Completed Builds:
In progress:
Very nice!
Lyle
Completed Builds:
In progress:
  • 2 months later...
