As a change from repetitive gun work, I made some further parts for the centre line of the upper gun deck.
The bowsprit step and manger boards were quite straightforward and although not seen, I wanted to include them. The only slight difficulty was setting the step at the correct angle and getting the hole for the bowsprit in the correct position and at the correct angle. I cut the heel tenon in a piece of 10mm birch dowel that serves as a temporary bowsprit to check alignment. The step is temporarily fitted in place with 1mm brass pins.
Chain Pumps
I looked at the birch ply parts provided in the kit and thought that although they match the sizes given in the AotS Diana, I could probably improve upon them. Using the AotS as a guide, I made up the cistern from 6x2mm boxwood strip and the hood from some boxwood sheet laminated to make up 5mm thickness.
The bearings are made from some brass eyelets that I bought along with the hooks from HiS Model. When blackened and cut down, I think that they look the part.
I know that I am flitting about here but I next decided to tackle the channels. I couldn’t use the walnut ply channels provided in the kit as they wouldn’t have sat well against the rest of the hull.
I am again indebted to Robdurant for providing the plans that he drew up and for suggesting the use of the laminated 6x2mm strip. The backstay stools are thinner and I cut these from 1.5mm sheet. Rob’s drawings were cut out and pasted onto the boxwood pieces using a glue stick. Sawing curves has never been my strong point (one of many) but I roughly cut them out and had to spend a lot of time sanding them back to the line of template.
 The channel positions were marked on the hull using the plans and the AotS drawings. A final check was made by putting temporary masts in place and using thread to make sure that the shrouds would not interfere with the gun ports.
All was well until I came to the mizzen channels and realised that one of the shrouds would be right in the firing line of a carronade on the quarter deck.
This will mean removing the bulwark planking and realigning the gun port. I’m not sure yet whether I will have to move just the one or whether this will make all the other gun ports look wrong.
For the moment the channels are temporarily fixed in place using 1mm brass pins, 3 for the main and fore channels and 2 for the mizzen.
I am wondering how to finish the edges with a moulding piece. I don’t think that for me scraping a shape will be the answer, although I will have a go. Alternatively I might cut them out of more 6x2 strip. A bit more thinking  and trialing required.
David
Previous Builds
HM Cutter Hunter Mamoli 1:74
Baltic Ketch Scotland - Corel 1:64
HMS Fly - Swan Class ship sloop - Victory models 1:64
HMS Diana - Artois Class Heavy Frigate - Caldercraft - 1:64
HM Cutter Trial 1790 - Vanguard Models - 1:64
18th Century Merchantman Half Hull - NRG-1:48
HMS Speedy 1782 2023 Edition - Vanguard Models - 1:64
Current Build
HMS Harpy 1796 - Vanguard Models - 1:64
Chain Pumps
The laminated 6x2mm sounds like a great idea for the channels. What sort of wood are you using and I will be interested to know how you solve the Carronade guns  and the mizzen shrouds. Looking forward to your progress and your level of detail is impressive even when you cannot see some of it.
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
Thanks for all the likes and Dave I'm afraid I can't claim credit for the laminated 6x2, Robdurant was there long before me. The wood, like much of the visible wood on the ship, is boxwood.
I have now replaced the quarterdeck bulwarks where the gunports were wrongly positioned.
The surrounding hull and deck were protected with wide masking tape.
I only needed to remove the planks from the last carronade port and the next two gun ports. The glue was attacked from the back with a small swab of cotton wool soaked with IPA. The joints came apart quite easily and were then cleaned up and sanded.
It was then a simple matter to replace the planks. With the mizzen channel pinned in place, and a temporary mast to align the shrouds, The boxwood planking needs finishing but I have marked the positions of the two gunports and will cut them out at a later stage.
David
Previous Builds
Current Build
Hi David.
She's looking fantastic! I didn't register I'd changed the gaps with the channels - perhaps because I'd reworked the quarter deck for the lower bulwarks... but it looks like you've worked out a great solution, and I'm sure the captain will be much happier with the shot passing well clear of the shrouds.
Looking back on my build, this is one of the few things I would definitely have done differently. Trying to glue in a bunch of blocks to fill the gaps where the chain plates went through was fiddly and annoying, and I should have followed Jason's @Beef Wellington example in retrospect. I would strongly advise having a strip along the outside of the grooves that the chain plates fit into if you can.
Here's the post where Jason talks about what he did...
Rob
Hi Rob,
Thanks for your kind comment and your link to Jason's log. I was going to add a strip across the front of the slots and somehow blend it in to the sides but letting a strip into the channel is a much neater solution which I will definitely be adopting.
Like Jason, I feel that I have a confession to make as I have noticed an error that I don't think that I can correct easily so may just have to find a work-around....
David
Previous Builds
Current Build
Thank you to everyone for the likes on, they are much appreciated previous posts
Head Rails
Looking at the drawings of the head rails in the AotS and the photos in Robert Gardiner’s The Sailing Frigate, both upper and lower cheeks in the kit look too short. I believe that the cheeks should extend almost to the line of the cathead and so I have scratched some from 3mm boxwood sheet.
Comparison of Upper & Lower Cheeks
The quality of the rails in the kit were thin and of very poor quality, so again I have made them from boxwood sheet.
Comparison of Upper Rails
I cut some shaping into the rails, firstly using a pen from my father’s old drawing set, which creates a nice clean line parallel to the edge, and then gradually opened them out with files and a sanding stick.
Now for the confession.
Starting on the filling piece, I suddenly realised that I was in deep trouble. The filling piece, which should be about 8mm deep, on my model is nearer 10mm. Checking all the relevant measurements, I realised that the wale is 2mm too low at the bow. Everywhere else along the side is fine but the sweep up to the bow is wrong.
The space between the tapes shows where the wale should be.
After a lot of swearing and telling myself how stupid I’ve been, I’ve resisted the urge to turn the whole thing to matchwood but am left with the dilemma of how to proceed.
I don't think that replacing the wale is feasible at this stage of the build because the planking above and below follows the same line and that would mean taking apart the front half of the ship.
As I see it, I have two options. I can carry on with the lower cheek sitting on top of the wale and making the filling piece deeper than it should be or I can sit the lower cheek above the wale and restore the distance between lower and upper cheeks to the correct spacing.
Option 1
Option 2
Neither is ideal but my inclination is for option 2 as the least worst: to sit the lower cheek above the wale which although wrong, I think the relationship between the various elements would be more balanced than if I make the filling piece deeper.
 Having spent a lot of time upgrading and scratching various parts, having to make such a compromise is really annoying.
David
David
Previous Builds
Current Build
EUREKA!!
 Thanks for the likes but really there was little to like in my last post.
I made all the parts from the lower cheek up to the level of the bolster. Before finally accepting that I had made such a fundamental error with the position of the wale, I wanted to make a final check on all the measurements related to its position.
It was only then I found that the real problem was with the stem, which I had scratched from 7mm boxwood sheet. When I transferred the tracing from a scaled-up version of the drawing in the AotS Diana to the boxwood sheet, the tracing must have moved. This is the only explanation I have for the difference in profile along the top edge which was 2mm out at its junction with the stem.
It was a great relief to find that the solution was a relatively simple matter of reducing the stem to match the correct profile. However it meant that I had to remake the trailboard and because I had (stupidly) already cut the hawse holes, quite a bit of work replacing bow planks, plugging the holes and cutting new holes in the correct position.
Having made sure that all the components lined up, I have now fixed them in place.
Initially I placed all the hunting dogs and scrollwork on the trailboard but because of the addition of the filling piece that isn’t part of the kit, it looked overcrowded and out of balance …
so I removed both dogs and just went with the single ‘running’ dog which I think looks more balanced
I’m glad to have got this stage sorted out. Looking at the photos in close-up, I will try to improve on the paintwork but overall, and at normal viewing distances, I am quite pleased with the results.
The gammoning knee supplied is the wrong shape compared to the drawing in the AotS so I have made a new piece. Initially I cut it out from a piece of 7mm boxwood cut back to 5mm but it was too prone to splitting when it came to cutting out the slots for the head timbers. Since it is being painted, I decided to go with a new piece cut from the ply provided. When I drilled the hole for the mainstay collar, I realised that the first head timber (the stem timber?) would cover it so I guess that the head timbers will also have to be modified down the line.
DSC08200_600.JPG.bf1628ee9bc893ed8d4386729e3a66c4.JPG0
The failures are on the left with the kit part and my final effort on the right
I’m looking at the wash cant in the AotS and wondering about the best way to make this up. It seems to have quite a complex curve. Perhaps a series of reducing triangular pieces laminated together and then shaped to the curves might be the best approach.
David
Previous Builds
Current Build
Thanks to AJohnson for the like
Scuppers
Continuing work on the outer hull, I have fitted the scuppers.
These were made from electrical connectors, not sure of the proper name, bought from ebay for HMS Fly.
Some scuppers are very close to the deadeye links so their positions were marked using a length of cord set at mast-top height and led through the appropriate slot in the channel.
In the photo the black covered ones are 2mm and the blue 1.5: just right for 5 and 4” scuppers respectively. The plastic sheath is cut off and the inside painted with Tamiya Dark Iron.
.The length is also just right for the width of the bulwarks to meet the waterway
I think that it’s time to leave the hull and finish fitting out the upper deck.
David
Previous Builds
Current Build
You're a braver man than I, David. Those scuppers look like you've got their position perfectly. Did you drill straight through from the outside?
Glad to hear you managed to find the solution for the level of the wales and how it all fits together at the prow, too!
She's looking very smart indeed.
Thanks for the likes and Rob for your kind comments.
Originally I didn't intend to drill straight through but when I drilled the outer hull, I found that by applying slight pressure, I could feel from the inside where the drill was so I tentatively continued with the first scupper which worked out OK, and then pressed on with the others.
David
David
Previous Builds
Current Build
I wanted to use slow setting epoxy for fixing the guns to give me time to adjust them. While I was waiting for it to arrive, I decided to have a bash at the wash cants. They are formed from a number of complex curves and I wasn’t sure how to go about it. I decided to take it a step at a time by building them up from layers of 6x2mm pear strip. I built up the first a strip at a time measuring it against the curve of the hull and of the lower cheek. In the end they were three strips deep by two thick. The section along the stem was made up separately to a rough finish and then fixed to the hull section with epoxy to provide enough strength for filling and finishing.
Having completed the first, I was able to go a little quicker with the other side and glued and roughly shaped the back three strips as one piece. The front three strips were also roughly shaped before glueing to the other half for final shaping.
It took three afternoons of cutting filing, and sanding to complete both pieces.
Not easy to photograph an all black subject but here the wash cants are fitted to the hull.
While waiting for epoxy and filler to set at various stages, I was able to start fixing the guns.
I had already mentioned that I had fixed 1mm brass posts into the carriages and drilled corresponding holes in the upper deck. I also slightly flattened the trucks to give better contact with the deck. The guns were then fitted by applying the slow setting epoxy to the holes in the deck and aliphatic glue to the trucks.
The port side fixed and the starboard side in place ready to be glued down
The port side breeching is  fixed but the ropes need tidying and setting in position.
And that’s all I’ll have time for as my work room has to be dismantled – my table is needed for Christmas lunch.
A Merry Christmas to all
David
David
Previous Builds
Current Build
Many thanks for all the likes.
All the guns on the upper deck have now been firmly fixed in position using epoxy to fix brass posts into the both the gun carriage and deck and aliphatic glue on the flattened trucks.
I tried to set the breeching ropes in position by simply wetting them out and holding them in place until dry but the cord being mostly synthetic, didn’t respond well. The only way was to fix them using glue in discrete spots at appropriate points.
The port tackles were prepared some time ago with the falls frapped around the tackle which made it a simple matter to hook them onto gun carriage and bulwark and fix with a dab of CA.
Unfortunately I have forgotten to take a photo of the upper deck now all the centre, visible guns are rigged with port tackles but they can be seen in the shots around the main mast area.
Having fitted the guns, I have moved on to the fittings along the central line.
Starting from aft, the partitions for the captain’s quarters have been fixed in place
The chain pump housings I have covered previously and these were now fitted using the kit supplied PE brass brakes, which although not great, I decided were acceptable. The provided walnut stanchions were given a bit more shape before being painted, pinned and glued in place.
The deck beams are not glued in place yet
I couldn’t live with the supplied parts for the elm tree pumps and ordered some from Jotika. Rather than used Jotika's dowel, I made the cylinder from 5mm square section boxwood filed and sanded into an octagon. The brass brake looked too short and flimsy so I added a boxwood extension.
The area around the main mast is now complete and looks pretty crowded. The elm tree pumps aren’t glued and I will not fix them until the last moment as they look vulnerable to damage.
I want to show the anchor cables feeding into the main hatchway but there is insufficient cable supplied in the kit to do this and anyway it looks a too bright and white. I was prompted by a member of this forum (and I’m sorry but I can’t remember who) to look at Ropes of Scale. The nearest cable they have is 2.1mm, slightly under-size but as close as the 2.5mm supplied is over so I have ordered some of there beige cable and a couple of other items to try with a view to replacing some of the kit rigging thread..
I don’t want to fit the forward bitts and other items until the cable and deck stoppers are in place.
While waiting for the cable to arrive, I thought that I would fix the channels and brackets but as others have commented, only 22 brackets are supplied when 26 are shown on the plans. I have emailed Jotika asking for some extra parts and in the meantime have checked the security of the guns and worked on the deck beams and skid beams which will be for the next update.
David
David
Previous Builds
Current Build
I think the 2.1mm is much closer to the actual dimension than the kit supplied stuff which is much more in line with a first rate.  I remember BE had put the formula(s) somewhere in his excellent Pegasus log.  I used similar size rope from Syren as Ropes of Scale wasn't around when I ordered.
Cheers,
Jason
In the shipyard:
Jason,
I've been trying to find the reference that I used but somewhere I read that the circumference of the cable is 0.6 x main mast diameter. and at 27.75" this equates to a scale 2.1mm diameter for the anchor cable.
David
David
Previous Builds
Current Build
Thanks for the likes  everyone
Deck Beams and Skid Beams
While waiting for cable from Ropes of Scale, I have spent some time test fitting the quarter deck and forecastle, checking it for any odd lumps and bumps. The plywood beams have been fixed from aft forwards as far as the capstan. The next will be fixed aft of the bulkhead extensions to keep it clear of the scuttles. I’m wondering in hindsight if I could cut away beam 13a where it crosses the hatch and brace it from beam 12a.
I have replaced the walnut skid beams with pearwood. I only have 6x2mm strip so they have been made up with 2 lengths of 6x2 glued together and shaped using one of the walnut pieces as a template. According to the photos in Gardiner, the skid beams sit below the level of the gangways but I like the approach that Beef Wellington has taken to raise their level to be flush with the planked gangways. I have taken up this idea by adding another piece of 6x2 pearwood on top of the skid beam and sanding it back flush with the sides.
David
Edited by dunnock
David
Previous Builds
Current Build
Quarter Deck Hatches
The local post is very erratic so I’m still waiting for my delivery from Ropes of Scale even though they shipped my order within 24 hours. In the meantime I’ve started on the quarter deck coamings, which like the upper deck, are made from 6x2mm boxwood, and the gratings.
According to AotS Diana the openings for the hatches and ladderway are larger and slightly differ in their positions compared with the ply deck supplied.
I have marked up the new openings and made the coamings and gratings accordingly. The main quarter deck hatch, being tapered, took a few attempts to get even close but I am reasonably happy with the final result – I don’t think I could improve upon it anyway. I have rounded the corners and added strips for the gratings to sit on. The other hatch coamings and gratings are made up too but all require shaping.
I didn’t have enough pieces to make gratings for the forecastle, probably because I made the aft hatch on the upper deck which isn’t part of the kit, so I am now also waiting for some grating kits from Jotika. If things don’t arrive soon, work on Diana will have to slow down and the shipyard will be going on short time.
David
UPDATE:
The gratings have just arrived so work continues..
Edited by dunnock
David
Previous Builds
Current Build
Some fantastic looking deck fittings and hatch covers etc. I hope I can build a Dianna in the future half as good as yours. I do sometimes wonder how accurate the AOTS book is. I am another owner of such a book as I managed to pick this up on the cheap. This is one of the reasons why I am thinking of building the Diana but as I say I do wonder how accurate the position of deck fitting and sizes of various items and wonder where Caldercraft get there information from and wonder what your thoughts are on this. I do hope I am not distracting you too much from your progress. Best regards Dave
The package should come this week. I've been watching all of my mail and anything going to the UK seems to be terribly slow, 2-3 weeks for Airmail.
Thanks for your kind words Dave but looking at your Endeavour,  I'm sure that you would make a fine job of Diana. I am using AotS Diana as if it's pretty much spot on. I believe that it is certainly better than the Caldercraft plans and parts, who after all want to sell their kits to a wide range of modellers at an acceptable price. As I understand it, the kit is one of their earliest offerings and although some parts have been changed (the 18 pounder barrels for instance) much of the kit is as it was.
I think the only way to check the AotS for accuracy would be to buy whatever plans are available from NMM.
Perhaps others better qualified would like to comment too.
David
David
Previous Builds
Current Build
Hi Ben,
Good news, my ropes arrived today and they look great. The anchor cable is very close to what I would expect and the other two items I ordered just to see, I'm also very pleased with. Now I'm thinking about whether to replace all the thread supplied in the kit.
David
David
Previous Builds
Current Build
The quarter deck hatches are now finished, rounding off the profiles of coamings and gratings and giving several of coats of dilute matt varnish.
Looking at the scuttles and gratings on the forecastle, the photos of the admiralty models show only one grating forward of the stove chimney. Beef Wellington, in his blog, talks about flush scuttles rather than the raised coamings shown in the kit plan but I’m not sure what this means. There are clearly openings shown in the AotS plans on page 46 but not in the models. Are they just planked coverings?
Meanwhile, I have been able to continue with the fittings of the upper deck. The anchor cables are now in place. I made up 3 bitt stoppers aside and then used the deck rings in place for training tackles as deck stoppers.
And with all the upper deck fittings now in place, this brings to an end a major stage in the build but before putting the skid beams in place and finally closing the lid on the upper deck, I hope that you won't mind if I indulge in a few photos.
DSC08276_600.JPG.8d9354fd51ae189958cd7d5b7f9d816a.JPGDSC08274_600.JPG.6a2a454a2cadcdbb5fad5c8a3f3840b9.JPG
And finally with skid beams in place
I've had no response from Caldercraft regarding extra channel supports so I will just go ahead and make the extra number required from brass strip
David
Edited by dunnock
David
Previous Builds
Current Build
I’ve been making some corrections to the position of the sheer rail and mizzen channels.
The scrolls for the drift rails supplied in the kit made from walnut didn’t look right so I scratched them from 1.5mm boxwood sheet but when placing them, they didn’t seem to sit right in relation to the sheer rail and plansheer. This prompted me to look more closely at the original plans for Diana on the NMM website and the photographs in the Sailing Frigate. As I plan to build Diana without the built-up quarter deck bulwarks, I realised that the mizzen channel should be on the same level as the main and forward channels rather than in-line with quarter deck drift rail. I also realised that I had placed the sheer rail slightly too high. All this resulted in a few days’ work removing the rails, filling the holes for the pins of the mizzen channel and some repainting.
I have made new mizzen channels because the Diana plans and photographs of ship models showed that originally, in my understanding, the mizzen channel carried only the shrouds and standing backstays and that the mizzen and royal backstays ran to a separate stool. The two additional stools will be made from 1.5mm boxwood sheet as before.
The sheer rail and mizzen channel are now in what I believe are their correct positions. I have used 15 brackets each side, three on the mizzen and six each on the main and fore channels. I have assumed that on the fore channel, there are brackets not seen on the plans which are hidden both behind the anchor stock and the anchor lining. Only 22 parts are supplied in the kit so a further 8 have been made from the brass strip that remains when the PE parts are removed.
These shots also show the boxwood drift rail scrolls in place. I'm waiting until I have a better idea of the placement of the quarter deck guns before finishing the rail
All the channels are now placed with their brackets but I have yet to drill and fix the pins which is the next thing to doDSC08291_600.JPG.b149bc994c7c6eeb1210702a4e6eb185.JPG
David
Previous Builds
Current Build
Hi David, the trials and tribulations of the channel placement is shared by everyone so you're in good company!  I would suggest taking another look at your hancing scroll, to my eye it looks a little on the small side, and possibly a little low, but its always hard to judge from photos.  Been looking at this a lot recently, and it seem common practice for the radius of the scroll to extend above the sheer of the deck to transition to the quarterdeck bulwark, so that the rail sits above the level of the deck in the waist.  The original plans suggest that this should be around 6mm in diameter at 1:64, which is pretty consistent with the kit supplied part.  Unfortunately I lost the plans from the kit in my flood so can't refer to that.  Of course, please feel free to ignore me!
Cheers,
Jason
In the shipyard:
Hi Jason, Thanks for your comments on the scroll and following your suggestion, I have been taking a closer look at its size and position. I was imagining that the top of the scroll runs level with the top of the gunwale. I have taped a piece of 2mm thick pearwood to check this alignment and it seems about right as in the photo below.
But I think that you are saying that it should sit higher than it does. The kit version of the scroll is 8.2mm whereas mine is 6.0 If I use the dimension of the kit piece it would sit like this...
If this is more like the correct position, it also seems that I will have to increase the height of the quarterdeck walls..
It would be good to hear your further views on this because I am struggling to interpret the various plans and photographs of versions with and without the built up quarterdeck rails.
David
David
Previous Builds
Current Build
The second photo with the kit part looks much more with how I'm reading the various profiles and how I will be approaching things.  Of course, I'm just as liable to be mistaken as he next man 🙂
Cheers,
Jason
In the shipyard:
 Thanks Jason, I'm going to follow your advice and have a go at re-cutting the scrolls to 8mm.  The line plan on NMM website does show only a small area above the rail. I'm wishing that I had splashed out on a set of drawings from NMM now which might have saved me a lot of confusion.
Thanks to others for all the likes and encouragement so far too
David
David
Previous Builds
Current Build
Always happy to receive constructive criticism, I have followed Jason’s suggestion and after several attempts, have made the hance scrolls larger so that they sit above the line of the gangway.
I was moving on to the deadeyes and links but I couldn’t get on with the 5mm deadeye strap so have ordered some replacements from CMB. I also have some doubts about the sizes of deadeyes supplied. In the kit are 5 and 3mm versions but looking at the AOTS and the NMM drawing, there appear to be three different sizes with the royal backstays running down to scale 2.5mm deadeyes. I have some of this size left over from HMS Fly that I can use
In the meantime, I have finished off the stern by fixing the rudder coat and chains. The rudder coat was made from some non-woven lens cleaning cloth cut to shape and painted with Tamiya Nato Brown.
The chains are kit supplied and blackened with Birchwood Casey Brass Black in the usual way.
I believe that there should also be a cable (pendant?) attached to the end of the chains that leads back to the mizzen channels as shown in this photo of the starboard quarter of Victory taken back in 2020 but I want to look into this more before deciding what diameter this should be.
The quarterdeck and forecastle decks are now glued in place, covering most of the work that went into the upper deck (much to my wife’s consternation) but before doing so, I filled in the two top-tackle scuttles that don’t appear on the NMM models and plans for Diana.
Thanks for looking in.
David
David
Previous Builds
Current Build
 Thanks to everyone for all the likes.
The 5mm deadeye strops arrived from CMB, so rather than start planking the quarter deck, I have been working on the channels chains and links.
Quite a fiddly task and I wish that I had followed Jason's lead in completing them before fitting the upper deck guns but I think that I have now got a system that works without incurring too much frustration and loss of little bits and pieces.
First all the pins, strops, links and preventers were blackened. The line of the chains was determined by clamping a ruler to a stub mast and then clamping a line to the rule at the appropriate height - 265mm in the case of the fore mast – and running it down through the slot in the channel.
This is the set up for the main mast having forgotten to take one for the fore.
I made a pencil mark and then measured up 2.5mm from the black strake and marked the position of the hole for drilling. The preventer link was pinned in place and then using the line through the slot in the channel to achieve the correct angle, a second hole was marked and drilled and the preventer and lower link pinned in place. Carefully removing the lower pin, without disturbing the upper pin, this could now be glued with a drop of thin CA.
The deadeyes are placed in the channel slots and the upper link connected. I tried using the 0.5mm brass rod that Caldercraft suggest but found that I could achieve a satisfactory result more easily using Gutterman black linen thread which is 0.4mm diameter tied off at the strop. Once the deadeye and links were connected, the top pin on the preventer link could be carefully removed and fixed with a drop of CA.
Sorry if all this is a bit obvious but it's as much as a reminder to myself for future builds as for the benefit of any readers.
A 2.5mm deadeye was used for the royal backstay on the fore channel and a strop made from the same linen thread as the upper link. I think that this gives a nice differential in size as drawn in the AotS.
The channel slots are covered by a strip of 2.5 mm boxwood and finished with 1x1mm boxwood stringing.
I think it must be the angle at which the shot was taken that seems to throw out the angles of the first two chains but they are almost vertical in reality.
Both port and starboard fore channels are completed and I’m part way through fixing the starboard main channel.
There will be quite a bit of touching up to do of the blackened parts when I’ve finished and some tidying up where I drilled a hole in the wrong place.
David
Previous Builds
Current Build
Thank you everyone  for the likes
All the deadeyes and chains are in place on channels and stools and the blackened parts touched in with matt black where necessary.
I’ve moved on to the quarterdeck and completed some preliminary work prior to beginning planking. Firstly before fixing them in place, I sanded down the hatch coamings to 3mm high because I had made them to the same pattern as the upper deck and then realised that they should be shallower. I debated whether to use the hatches that I had made for the scuttles, which do not appear on the NMM ship model of Diana but are in the AotS drawings. I have decided to use them, even though it makes planking more difficult and adds yet another variation to my intention to build Diana largely as originally built.
Finally, again although not shown in the AotS, I added a plank across the stern to tidy up that area and then painted the inner bulwark red ochre.
I have placed the first few planks on the quarterdeck, one each side of the centre line and 3 across on the starboard side. The planks are 1mm maple, planed and sanded using a jig to shape 10 planks at a time to achieve a consistent taper from 2.3mm at the stern to 3.8mm amidships. Before fixing, one edge of the plank is painted black with archival ink using a Pigma Brush - easier and I think, a better result than other methods that I've tried.
This is the first time that I have tried using tapered planks and cutting them up to the fixed hatches so I will be taking it slowly and regularly rechecking the measurements and adjusting the taper if necessary.
David
David
Previous Builds
Current Build
On 9/26/2021 at 7:00 AM, dunnock said:
Copper plating the rudder was challenging because of the changing angles and cut-outs but any small gaps I have covered with Tamiya copper paint.
 The pintles and gudgeons are made from 3x3 boxwood planed down to 2x2. The pintles proved relatively straight forward with holes for the pins drilled before cutting the strip down to size. I made the spectacle plate from leftover stanchions from HMS Fly cut down and twisted into the right shape. The position and sizing of the gudgeons needed more care, each being placed separately and alignment with the rudder checked. The top three gudgeons I pinned in place but the lower four are just ca’d.
The first two gudgeons fitted
 Completed and rudder mounted
The photo-etched straps were too thick to allow free movement of the rudder and anyway were not sized correctly for my boxwood version so I used black card cut into 2mm strips following the pattern given in AotS.
I will add the cloak (not sure of the proper term) that seals off the rudder from the sea and the chains at a later date.
I think the next stage will be to work on the lower/gun deck. The stern was complicated enough and judging from other logs, the head looks more so, therefore I’m putting off work on this area to another time in the hope of tackling something simpler.
David
Very nice work. The "coat" that seals the rudder post is called the "rudder trunk." It was typically made of leather and therefore flexible, yet kept a following sea from flooding the officer's cabins!
Ron
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
