17 minutes ago, Canute said:
Looks like a nice bit of gear. Now, go get 'em, tiger! :D
Need to wait till it stops raining  outside  so I can prime/paint the spues   - then I can start  building,  so tempted to  have a go at modeling the interior  but  "Boy"  is it complex   -
OC.
Pic off the net.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
You could be in for a long wait😔
Ken's right it does look a great piece of kit.... the lamp and the tank!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Tell me about it,   I should have invested in some of that there  waterproof  paint😀   but the lamp is  perfic,   so I guess I could do some more figures  -  can't have enough figures.
OC.
Current builds
Completed works.
Think I can start this regardless of the rain -  I could build the sub-assemblies   like the bottom tub with all its bits and pieces,  the top hull  and  turret, I will then  be able to support them from underneath  to prime/paint them, then attach them when thoroughly dry.
OC.
Current builds
Completed works.
I'm waiting impatiently ;)
Just dug the instruction manual out the box............😲    its like a library  in a manual   - but very well laid out and written, looks like my  sub builds with it should work   starting with the bottom tub.
OC.
Current builds
Completed works.
So it starts  -  first was the belly addional armour plate to help defend against IED's, this has to be bent slightly at the front to follow the slope of the bottom,  this was then glued  down,  next came the Two sides  - these simply followed some lugs and glued, then the rear plate was glued in place.
Next will be all the Thousands of parts including some PE  to go on the back plate.
OC.
Current builds
Completed works.
Evening all.  more progress  - Three hours on the bench  but what seems like next to nothing done  just a few tiny fittings.
OC.
Current builds
Completed works.
41 minutes ago, Canute said:
You crossed eyed yet? Added a bunch of "greeblies".
Thanks Ken,    its actualy a pleasure to work on at this scale  - never used to be that way  back in the day of less light and no magnifaction,    I actualy feel like I'm working on a Giant  - its really relaxing  work tbh.
OC.
Current builds
Completed works.
Evening all,    thank you for all the likes and replies,     a bit more progress  this evening  -  next  was the rear indicator  units, these come as a base  that has Two transparencies on each and cage over each.
OC.
Current builds
Completed works.
Just thinking ahead  (as you do)   should I get these figures to go with my Chally?    would give it a bit more interest I guess.
OC.
Current builds
Completed works.
Well according to the reviews on the various forums I could find them, they are current British Armor crew, So you have to decide if you want to do today's crew or say the crews of the '80's-90's cause there is a set for those as well..... Generic and they say that they can be used on any british armor so they are not specific to the Challenger.....
Then there is this set....
https://www.scalemates.com/kits/valkyrie-miniature-vm35031-british-army-tank-crew-70-s-80-s-era--1160740
Which is British tank crew, but from the 70's to 80's....
Direct link to their website...
http://www.valkyrie.co.kr/
Not much out there brother...
Edited by Egilman
Quote:
7 hours ago, Backer said:
I do more WWII modeling then  modern .
so, no idea if they are  correct 😳
Thank you kindly Patrick.
OC.
Current builds
Completed works.
Do you know  - I think I will get them,   they will give the build a bit of an extra lift.     do love me dio's  me do.😁
OC.
Current builds
Completed works.
Right,   figures on the way  - couldn't resist.😊
OC.
Current builds
Completed works.
Evening all,   A bit more progress  with the rear section  - its fast becoming very congested with all the various fittings and brackets, keeping me busy and mind occupied.
OC.
Current builds
Completed works.
Evening all,   more progress this eve,    "Yep bendy metal paper  thickness thingy time" we call  PE😁   these are Two cages  that after doing the normal origami  - were glued in place with Gorilla Super glue  (how fantastic is that stuff)      so after attaching Two of these cages  I then  made the Fuel can frame  and glued it in place.
OC.
Current builds
Completed works.
Evening all,    a bit more progress this evening,  more details were added to the rear panel,  then I moved to the front where I attached the front gearbox units  and the various tie down lugs  aswel as some details along the bottom.
OC.
Current builds
Completed works.
I have a little supprise  - I want to try my hand at doing a part internal  simulation   - way to hard to scratch and nothing available as an update or super detail kit,    so  what I have found is another modern AFV  kit that includes a Full intenal detail set  -  its the  Rye Field Model 1:35 M1A1 / A2  Abrams, I know they are different tanks but I am sure with having the basics for the intenal parts there I can re-work them a bit to get close to the Chally's  interior.
The other bonus I will then have the M1 kit I can build latter and in that I could show the Engine compartment as its included in the kit.
Two for One situation,😉
https://www.how-amps.org/ryefield-model-rm5007-135-m1a1a2-abrams-wfull-interior-2-in-1
Current builds
Completed works.
Just brought some Ammo  to go with Chally  -  got the rather excellent  set by Accurate Armour.
OC.
Edited by Old Collingwood
Current builds
Completed works.
2 hours ago, Canute said:
Looks like sabot and high explosive rounds. Cool.
Yep  Challenger 2's   can fire  out of thier riffled barrels   -  APFSDS, HESH   and White Phosphorus  Rounds.
OC.
Current builds
Completed works.
very nice progress!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 hours ago, popeye the sailor said:
very nice progress!
Thank you kindly Denis.
OC.
Current builds
Completed works.
Hi All,   some more progress on the tub  -  firstly I fitted the rest of the iddlers/got them level and let them set, next  was the  skirt armour plate supports - same principle with these glued and ligned up.
I put it aside for an hour or so then I turned my attention to the Gas strut units  - Six on each side   these needed dressing before gluing in place, after Two units were glued inplace towards the front.
OC.
Current builds
Completed works.
Here's the plan  (hope your sitting comfortably)  -
When I have finished the bottom hull (tub)  and weather permitting  - I will be able to venture into the garden  (how you can call a 8ft  x 12ft  a garden)  anyway  I will be able to hold tub from the inside  and using my Tamiya Surface primer rattle can, I will be able to give it a coat, it will then be put in my storage box  and locked away to de-gass.
I will then start on the details on the main top plate - this should give me some time working on this stage  before in a few days I can  take the tub out (examine it)  then if all is ok  - and if the weather gods play ball  - back outside for a coat or Two of Nato Green  (again Tamiya rattle can).
This will be my process for most of the build  - building then painting in stages.
Right  - here's my thinking  for the inside , bare with me on this  - take a deep breath  -
Both the Challenger 2  and  M1A2 Abrams  would surely share some  similar  (kind of)  electronics and instruments  inside each  interior, also both share a 120mm  breech, and the rear ammo locker can be made to look very similar  - difference in the Chally  its open with no blast doors,   I think with some careful  adjutments  by  going over my interior Chally pics, I should (might)  be able to come up with something  quite close  (well it will be locked away  and when  Two figures are standing  through the hatches  you wont be able to see a thing  (I will know its in there  though.
OC.
Current builds
Completed works.
You seen this brother?
http://dogsofwarvu.com/forum/index.php?topic=535.0
Quote:
6 minutes ago, Egilman said:
Thank you kindly  for finding that  - yep seen those infact I am using a couple of the pics for my research,    would be good if I could find some  - side by side  comparison pics of the Two tanks internals  from the same camera angles.
OC.
Current builds
Completed works.
