HIJMS MIKASA 1902 by Jeff59 - HobbyBoss - 1/200 - PLASTIC
Well that’s it for now, shall need to start work on forward bridge structure and mast, a lot of work in this area so don’t hold your breath. 🤪 Jacqueline also bought me a second Pontos set so l have the parts I need to go forward. Who said us modellers are sane. Here’s a photo of the propeller before I dressed it up.
Link to comment
Share on other sites
Great work on all the railings Jeff, I know how tricky they are. Looks amazingly clean.
Tim Moore
Perfect is the enemy of good
In progress
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
DH.9a Ninak, 1/32, Wingnut Wings
The Blue Sky Company, 1:48, Sierra West Models
Completed
Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
Link to comment
5 hours ago, Jeff59 said:
Thanks Tim, seems we are always trying to get better. As usual the photos show up the imperfections that makes you strive to doing them better, guess that’s what modelling is about. 👍 Hope your build coming on well. ?
Hi Jeff, yes I’m back into it, just  started on the fore superstructure. I’m out on the west coast for a couple of weeks but hope to settle back in soon as I return in October.
Tim Moore
In progress
On Deck
Completed
Link to comment
Hello again, Yip it’s that time of life, time for an update. I remember this part of build being quite busy to say the least and knew it would take a while. Starting with the lower bridge super structure following Pontos instructions removed unwanted surface details using electric chisel and my craft knife with curved blade, then start fitting the etch details, following the sequence in instructions works easy enough. Just added some extra details, pipes and jibes, cable drums, it all helps to bring the model to life.
Edited by Jeff59
Link to comment
It takes a while to get round all the detailing and painting them separately before fitting, I did purchase a second Pontos set to get the necessary parts I wanted, I know this is over the top but there’s no way of producing the 1902 version without the necessary parts, it would be great if Pontos could do an additional set to help if the markets out there. 👍
Link to comment
The bridge wing deck requires plastic details removed top and bottom. My sequence was to stain the wooden decking for this and the bridge roof, then clue to plastic parts using white glue. Followed by masking of the decking, I then fitted the handrails then painted them, carefully removing masking once paint was dry. Incidentally I did alter the position of the upper bridge forward by about 2mm, seems to be this way on actual ship at mueseum. My best guess anyway.
Link to comment
A pleasure to view your work and log, Thanks for sharing.😀
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
Time to try to progress with another update. The metal etch details for the underside of the bridge wing is a little gem but a lot of work, same as after bridge really, the steelwork framework at each end is quite tricky. Shall put some photos up to show how I tried to set them, still not easy though.
Link to comment
Also try to show how I glued the plastic part of bridge wing to the metal etch part which is all very fragile. After both parts painted separately the handrails were turned upside down to sit on flat surface, then lined up the etched bridge wing on top of this and glued together applying light pressure were necessary, take plenty of time here. You may prefer another method, not saying this is suitable for anyone, just my own solution. 👍
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
