Hi Russ -- Great to hear from you again, I've missed your updates.  Your work here shows, as always, your fine eye for detail.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Martin:
Thanks. I wish I could find more time, but sometimes it is not there. I am hoping to lay a little more deck this evening.
Alfons:
Thanks for those kind words. I hope mine can at least come close to matching your fine schooner.
Russ
Russ this thing looks great. I can't believe how much time this takes. My name is Frank Trochesset My great great grandfather Martin Fountain built the American Girl and my great great grandfather Jean Victor Trochesset Owned it . I have a few pictures of the boat and would like to know if you might have any pic or info that you may be willing to send me copy of? I grew up at the family's Boat Yard in Galveston Tx and have several pics of the sawed framed cypress hull boats that where built there most where shrimp trawlers. Years ago I saw several pictures of the American Girl and the Cup that was won. But after my Grandfather passed the pictures can't be found. So if you have any info where I might find any or know someone that I can talk to that may have them it would be greatly appreciated. Thank you
Frank:
Thanks for the kind words.
I have sent you a PM with my email contact. Shoot me an email and let's talk. I have all of the history of the American Girl and I will be happy to share the paperwork. I also have some photos of her, but I am always looking for more.
As for how much time it takes, I am notoriously slow about my model building. I am sure others would have the time to spend on this and would crank it out in a few months. Not my style really and even if it were, I just do not seem to the time to spare on some days.
Russ
Here is another small update. I had some time to solder up the chainplates tonight. There are ten total. Each has an eye soldered in its upper end and is drilled for two wires that will fasten it to the hull.
Here is a photo of a dry fit. Never mind the wires, they will eventually be glued in and cut off. Also, the chainplate will be cut shorter, just below the bottom wire. That will happen only just before final installation. The rail is notched for the chainplate to lay flat against the hull and there will be a wooden cap fixed along the outer edge of the rail to help secure the chainplates upper part.
Questions and comments welcomed.
Russ
Edited by russ
Alfons:
Yep, there was a little tear out in the rail. That will require a little filler, but when the cap is on and everything is painted, it will be invisible.
Russ
Russ,
Your metal work is always so clean, it gives me something to aim for. I have noticed you are painting rails,etc before you install them. I am assuming that is to limit masking, is there another advantage?
Sam
Current Build Constructo Enterprise
Sam:
Thanks for the kind words. The soldering job here was actually only competently done. There are others around this site who are far neater and more expert than I. :)
I painted the waterways, inner bulwarks, and railings before I began the deck planking to avoid having to mask that area. I want a natural deck and crisp line along the curve of the deck against the painted surface. So far, it is working out well. This reminds me that now the weather is a bit better, I can paint the port side railing and the stern railing bfore I lay any more deck plank. :)
Russ
This past week, I got a little more decking done and I also added the rubrail along the sides of the hull. This is a 1/32" square piece that follows the line of the planking.
Russ
Alfons:
Thanks. I will post a pic of the deck when I get the planking completed. Right now it is just one small plank after another. :)
Russ
Pat:
Thanks. These schooners were very beautiful indeed. Credit Martin Fountain Sr. for this particular design. He was a master builder back then.
Russ
Really nicely done!!   Looks like a real nice ship and should be a beauty when finished.
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
looking good Russ.....the bow lines are very nice  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. She has a nice sheer line and I hope that the planking will still be apparent after the paint work.
Russ
Here are some photos of the completed deck planking.
I have given the deck its first scraping and it looks pretty good so far. The last outboard planks on both sides are not glued in. The fit was good enough that once they fitted, I could not get them out to apply glue.
Russ
Congratulations on finishing the deck planking Russ it looks very good.
Michael
Sherry, Sam, Michael and all who "liked":
Thanks for the kind words. It is much appreciated.
Sam, I seriously doubt I will need to do anything about those last planks. They are in there to stay. I have done this before and never had any issues with the wood moving that much. In any event, the deck will eventually get a clear sealer of some sort and that will settle the matter.
Russ
