Thanks. I am hoping to get some time on her soon. I have to finish another paying project and then I can get back to this one. :)
Russ
Nicely done!   I look forward to and dread the fiddly bits part of the ship.  Dread because they are tiny and usually a lot of them!  Look forward to because it starts to bring the ship together.
Liking it!
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Adam:
I was frustrated for a while not because the parts are small (and they are), but because I had not figured a way to engineer them properly. I think I have that worked out now and it is a matter making some time in the shop to get them completed. Once you know how to make them, the rest tends to get a bit easier. :)
Russ
Glad your back. Also glad you figure out the problem of getting them to work the way you want. Sometime you have to sit back for awhile and think about the problem instead of trying this and trying that. When things start getting to you it's time to take abreak and think about it for awhile.
Wacko
Joe :D
Go MSW :) :)
Joe:
I promise I never went anywhere. :) Just got really busy.
There are always challenges to find a way to make something in a given scale. That is one of the things I love about model building.
Russ
John:
For some photos of the process, see the first page of my log.
I used a piece of masking tape to measure the distance to be planked on each bulkhead. I placed the tape on a given bulkhead using a longer piece of tape and then marked the deck line on the tape and the top edge of the keel. Then I took the tape off and laid it out flat. Now, I measured the total distance between the two marks and divided that by the number of planks from deck to keel in the hull. That gave me the width each plank on that bulkhead. Now replace the tape on the bulkhead with part of the bulkhead showing and transfer the marks for the width of each plank onto the bulkhead. I repeated this operation for each bulkhead and now I have the width and shape of each plank laid out on the bulkheads. I did this along the angle of the bow and for the stern frame as well. I do this for both sides of the hull.
When I planked this hull, I did not use any premilled strips, I cut each plank out of a sheet of basswood. These can be gotten for a few bucks at your local hobby or crafts store. I got mine from Hobby Lobby. I used white card stock for spiling and tapering each plank.
Cut a piece of card stock just a little longer than you first plank at the deck at the bow. Make sure it is somewhat wider than you need as well. Hold or tape it against the hull so that its edge sticks up above the deck. Now, run a pencil along the edge of the deck against the card. This is the upper edge of your first plank. Now, cut the card to that line. Mark the bulkheads that your first plank crossed on the card and measure from each bulkhead the widths of the first plank on the card, using the upper edge of that plank on the card as you reference line. Do it for the bow rabbet as well. Once you have these widths marked on the card, connect the dots. Now you have the shape of your first plank. Decide where the butt end of the plank will occur.
Now, cut the card to that shape and check it against the hull to make sure you have got the shape exactly as it is laid out on the bulkheads. If it has been done carefully, all is correct. Lay the card on a piece of basswood and trace the shape. Cut the plank out and use the card template as a guide to fine tune the shape of the plank. You can leave the plank a little long until you are ready to fit and glue it in place. If you need to soak the plank to get it to bend easier, that is no problem. I held mine under hot water from the faucet for a minute or so and then clamped it in place on the hull and let it dry. Once it was dry, the plank held its shape well enough that I was able to glue it place, using my fingers to hold it for a few seconds while the glue set enough.
For planks that have their edge against another plank, use the card again as a template and use a compass to trace the edge of the plank above onto the card. You can connect the dots to get that edge shape for your next plank. That is spiling. Then you can measure the widths as before to get the bottom edge of that next plank. That is tapering.
Where you have a bulkhead in the stern that does not extend down to the keel, draw lines extending that bulkhead's position on the deadwood down to the keel. Your measuring tape will need to cover that distance since planks will fill that area.
Let me know if you need anything further.
Russ
Edited by russ
Here is a little more progress. Got some time to work on some deck fixtures. There is still a good deal more fitting to be done. The corner joints on the hatch coamings still need some cleaning up and the coamings need to have their bottom edges cambered to match the deck.
Russ
Pat:
Thanks for the kind words. I need to get this project moving along as I have a few others who are waiting patiently for space on the bench. :)
Russ
Looks good Russ, shes staring to come together. Nice work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Beautiful job.
Bob
Current build:  SS_ Mariefred
Dave:
Thanks for the kind words. However, they are obviously cleaner and sharper in the photograph than in real life. :)
I will say that making the half lap joints was enjoyable. Just me, a few hand tools, and the wood. They are not perfect, but it was a great way to pass a few hours.
Russ
Love your work Russ.   Really appreciate clean crisp work - something I am still striving for.  The deck structures look fantastic!
-Adam
Current Builds
Completed Builds
Here is a little more progress. I managed to make the wheel box today. Not too bad, but it still needs some sanding now that I look at the hi res photos. :)
Russ
