Lady Nelson by dsadberry - Amati/Victory Models - 1:64 Scale - first build
Hi Folks
This will be my first build log and also my first ship build. I chose the Lady Nelson because as @ccoyle mentions, "it has the "three nots" needed for beginners, i.e. not a lot of planking, not a lot of guns, and not a lot of rigging". I am new to woodworking as well so this will be quite a learning experience. I will appreciate any guidance you all can offer in regards to shipbuilding as well posting on this forum.
I have put together the keel and bulkheads. I noticed that the bulkheads fitted loosely and also low, so I shimmed the bottom and one side with index card stock.
Link to comment
Share on other sites
Below are some shots of the frame. I tried to make it as square as I could. It looks pretty good to me, but what do you guys think.  I also added the first balsa wood filler block. The others should go quicker. I decided to add the fillers first and then do the fairing. I have a couple of questions in that regard: Is it best to use balsa wood? Or should I be using something like basswood? Should I have done the fairing (or at least a rough fairing) before adding the filler block. My thinking was it's best to do the fairing with the filler block, but my concern is that the balsawood is so much softer the the bulkheads and that may cause a problem where I remove too much of it. And finally, I don't think I want to try a rabbet on the keel because there doesn't seem to be enough real estate, but thought I would fair the hull down to maybe 1ml and then when I add the walnut prow, keel, rudder post that I would have my rabbet. What do you all think?
Link to comment
I don't know if it's due to the photography or not, but it does seem to have a slight longitudinal curve. Noticeable in the first side shot and last head-on shot. If so, at this stage packing out a filler on the inner side of the curve should be enough to fix it. I run a steel straight edge along the keel when I check mine as I fit any fillers.
Basically how I handled mine, I also fitted these items before planking, not after as the instructions indicate.
Rick
Link to comment
Rick
You are spot on, Rick! I do see the curve. Thank you so much for catching that. I need to train my eyes better. It may not show in the photo very well, but it looks like the bend is between the 6th and 7th bulkhead. It's early enough in the build that I can fix is as you say.  Thanks again for the catch, I really appreciate it
Dennis
Link to comment
Moved to proper area.
Link to comment
You should also have taken those first two planks right up to the stern post, otherwise you'll have a nasty lump instead of a smooth run to the keel and stern post.It's not too late to CAREFULLY remove those two plank and replace with one's running the full length of the ship. I know they'll be slightly damaged but the can still be used elsewhere.
Rick
Link to comment
Rick
I thought only the 2nd planking filled the gap to the stern post to keep the thickness down?  I guess I have seen it both ways though...
~Kirby
Link to comment
No - part of the reason for the rabbet it to take the first layer, as I mentioned this will then provide a smooth run and with 2nd planking at .6mm it will all fall in place neatly. You do need that area to taper off smoothly and at the moment you have a bit of a hump there, if you don't want to try removing and re seating then a bit of judicious sanding should work.
Rick
Link to comment
You may want to take a little more off at the stern end; where the char is; the transition to the deadwood could be a little bumpy.  Other than that, I think it looks real good.  Have you run a plank from bow to stern and see how it hits each bulkhead?
.John
.John
Current Build: Lady Nelson
Next up: Speedy (Vanguard Models)
Link to comment
Thanks @drjecklYes, I see what you mean. I will work on it some more. And yes, I have been testing the lay with a thin brass strip that work really well.
I have another question. Would you recommend that I attach the keel assembly first, or plank it first? I'm thinking that with the LN at least, that I should plank first, but would like your opinions.
Edited by dsadberry
Link to comment
Again, I'm a noobie too but I can tell you that I put the keel pieces on before 1st planking and I wish I hadn't.  During that planking, I broke the keel, bow stem and stern piece several times.  I initially used PVA glue to add those pieces and again, after they broke.  Finally, after maybe the 3rd or 4th break, I used epoxy to add them.  This held until the last break I showed in my build log.  I would recommend that you check out my log here and then follow it:
Bottom line is having gone what I went through, I would wait to add the keel pieces until after the 1st planking.  Not sure what ramifications you will run into by doing that.
Stay in touch...John
.John
Link to comment
I had good luck with the stem and keel glued on. They make nice pieces for clamps to hold the first planks. I shouldn’t have glued on the stern post, but I managed.  I haven’t had time to finish my first planking... only two runs to go.
You are off to a way better start than me though. I refused to add the filler blocks... the transition between BH4,5, and 6 is abrupt and I hope that I can smooth it out for the 2nd planking.
Edited by KirbysLunchBox
~Kirby
Link to comment
Thanks man. I appreciate the encouragement.  I am glad I did the bulkhead fillers. Planking start tomorrow! I gotta be honest, im nervous.
Link to comment
The beauty of the first planking is that you can stuff it up pretty badly and still get away with it with careful sanding and filling. Additionally using PVA glue it's not impossible to remove some planking if it goes horribly wrong. With one of mine I had to strip nearly half off one side, it had just got a mind of its own!
It's a learning curve and first planking is a pretty good exercise, just treat it as that and take your time.
Rick
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
