VW samba bus conversion by kpnuts - Revell - 1/16 - PLASTIC
That's a pretty hefty stretch your putting into it there brother.... about doubling it's wheelbase?
Interesting....
Quote:
1 hour ago, kpnuts said:
Sorry title is wrong should be 1/16
Fixed the title.    Not sure where this log is headed but sounds interesting.   An extended bug bus?
tantalizing!  a wonderful exhibition of necromancy! :ph34r:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ah... cool...  something to haul your Ferrari to a show without getting the tires dirty.
Tried making the louvers out of quartered cocktail sticks, not very successful
I measured the louvers and they are 20mm wide the quarterd cocktail sticks are 1 1/4 mm so way out of scale.
I have another idea up my sleeve let's see how that works.
Edited by kpnuts
That is the bravest thing I've seen in quite awhile... parking that car under the lift.
Those lifts are designed to do exactly that... they were originally installed in parking garages.... They were adapted to serve in auto repair shops, they have a ratchet mechanism which absolutely prevents them from dropping..... Hard to find an auto shop around here that still uses a hydraulic or air cylinder lift anymore.... You see the cylinders in the bay floors of the older shops but the lift plate and controls are gone....
Quote:
Yep - those are exactly the same type of lifts we had in the shop I worked at.  They are really quite safe as long as the pads on the lift arms were positioned correctly.  We used to park cars like that whenever it was going to snow enough that the lot would need plowed - much easier to plow a half - full lot.   Those lifts are hydraulic - each one has its own motor & pump.
Edited by marktiedens
current build - HMS Vanguard - Model Shipways
Thanks for setting me straight on the lifts.  I guess I'm just too old-school to keep up with all the new tech.
I thought the same Mark, just looks like an accident waiting to happen  - like we see in the films...
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
