Bought this decades ago and many years ago I assembled the frames
left on the shelf and started again a couple years ago
i am ar the point where the second planking is down to waterline
I plan to copper with tape so I will post some current photos and pictures of the plans as I saw an ask for plan photos
thanks Ian
I have to check on the wood - I discovered the clamps a little while ago that are not painted black so they wont leave the black marks on the wood when contacting the glue
I plan to use those from now on
I have not noticed the saw wearing out , good question though.
is there a small mitre box that is wood?
will post more recent pictures shortly
On 3/6/2021 at 2:52 AM, rookie said:
Question
am I allowed to post plans from artesania Latina.?
If you take a photo of the plans, laying on a table, I think that is okay to post. They will then be distorted and can not be used.
But I would guess that scanning them and then posting would be an infringement of copyright. So, dont' do that. 😉
And while I'm here, Welcome to MSW! Enjoy your stay 🙂
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Thanks wintergreen
i took photos of plans hanging on wall
sample below
ian the first layer was limewood
Here is the current state of build
i sat dowel in the mast holes and sat the bowsprit on to see how it looks
will be doing some lower mast work for a change of pace
also need that to line up the shrouds to add the lower channels with grooves for the chain plates at the correct angle
3 hours ago, rookie said:
thanks Ian
That explains it. I thought the wood itself contained occasional dark patches. Some sort of tropical wood.
Second planking looks very good!
I thought I would make a few comments about the Artesania Latina Morgan model itself
As I was going to start planking I found that the stern was way too small compared to the big wide stern on the actual ship. I cut out a slightly larger transom and "padded" the planking on the last one or two frames to build it up a little.
I also found the wide piece of wood for the bulwarks problematic to try to bend at t he bow and install. I have a feeling mine is not correct as I ended up not able to add the extra piece below the cap rail as it would have been too high.
I had seen the Model Shipways build and I preferred actually building the bulwarks up properly.  That model also forces you to build the deck structures whereas the AL model has blocks for hatches and companionways and tryworks.  The AL instructions just say to score brick pattern into the block provided. (yikes!)
I embellished the hatches etc and have not begun the tryworks yet.  Still wondering about actually using tiny bricks to make it.
In general, now that I have gone through the planking I have realized the next time there are things I would do differently.  I will definitely install the keel first and create a rabbet for the planks rather than sticking the keel on top of first layer.  I think I will also try to only do one layer of planks; it is tough enough doing it once without having to shape tiny veneer bits and do it again.
I will also follow advice I saw in various places about marking the run of the planks out in sections and shaping each plank accordingly.  In mine I tried to calculate the width at each frame and shape it but that does not work when doing the entire side of hull in one "section'
Anyway, my Billings Bounty will be better for this experience (fingers crossed)
Valuable information for anyone building this kit, I'd say.
It's also a slippery slope when you start to investigate and search for authentic information about a ship... all of a sudden you realize all the short comings of kits 😉
However, it's a learning experience and best off will be a balance between kit supplied and own enhancements. (unless you go over to the dark side of scratch builds that is. Then nothing is stopping you and the abyss is deep... 😄 ).
Planking a hull IS difficult and there are numerous accounts of how-tos and tutorials here on MSW.
Don't rush and you will do just fine!
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Thanks Wintergreen
Speaking of doing my own thing I decided to build the tops rather than use the stamped out parts in kit (plus one of them broke while removing it)
I will plank it using the kit piece. As a template
In the picture I may cut out thin piece and use .5 mm strips on both sides then cross supports to keep it solid
Well some minor progress to report
did build the fore top and maintop
seen here in photos dry fit to masts that are sitting in holes in hull
F62E1A06-00E7-40D5-B6CF-9F4C6CF7E7B0.jpeg.803d5cd8a79b7d50f374fd403c9fe98c.jpegDFD523FB-1251-4679-92EF-5DB980023C72.jpeg.c5f4875a4112e8b8f43d624859000c79.jpeg
next up is to finishh the channels
I plan to use a shroud on each mast to determine the chain plate angles and get those set up
i am also planning a stand but not sure how I want to do it
the keel seems too thin for screws
I may just sit it on a cradle
Well Rookie I built the same model a couple of years ago and found some the same problems. I bought my kit from garage sale on eBay. The blocks of wood left me cold so I decided i'd scratch build everything from the deck up. My research found that Mystic Seaport library and research have many drawings of the Morgan so I bought them. I have the hurricane house, skylight, aft cover, tryworks, tryworks cover (which the original had), forward head and the winch. I built my tryworks out of sculpey making my own bricks as the drawing had the coarses spelled out.
I put in a couple photos for reference
Hurricane House, skylight and wheel
My first attempt at being a  brick mason
Almost finished just fitting out the whale boats.
Let me know if I can be of help It does make a great model being larger the Model Shipways although the Model Shipways is a better kit.
Some things to think about
Original plans
Model Shipways plans (your can purchase them)
A website with wonderful description and photos of a Model Shipways version. https://www.charleswmorganmodel.com
NRG home page resources tab then resources for ship modelers articles and how toos has great instructions for tryworks
Again pm if I can be of any help
Stay Well and Stay Safe
Will :pirate41:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Syren by pearwill Model Shipways 1:64 scale
On Hold:
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Wow
thanks will
your model looks great
i have been adding the lash rail , top rail and finishing my fore and main tops
also trying to get the anchor hawse and the decorative bits at the bow
there Is nothing in the instructions so using photos of shup
tryworks is something I have not done yet - I thought about buying scale bricks on Etsy
Colin
  • 5 weeks later...
thanks Ian
I am working on the shelters at the stern and the wheel/tiller
the wheel that came with the kit looks like a "Lego" wheel so I am thinking of making one  🤔
Or I may get a wheel kit from Syren .....
Speaking of which I bought the Syren ropewalk and got it but have not assembled it yet
Probably do the tiller ropes to practice with it
Job I finally made some progress on the shelters at stern
Used the kit walls and added beams for the boat deck
got sidetracked with biking and Pak 40 that has been on shelf for decades as you can tell from $10 price tag
Anyway posting couple of photos of Morgan
Edited by rookie
  • 4 months later...
to be honest the actual photos of ship look like the bow is even more square than this model
I already had made the stern bigger on this but did not even try to change the bow
Thanks , I am working on bowsprit, foredeck and other things at bow then will move on to the chains and deadeyes
also other details on deck and masts
Well have not added anything here for a while
i am now retired so hope to have a little more time for this
i did take some golf lessons so that will cut into modelling time hopefully
here is the latest
working on making Davits using a sandwich of wood strips to build the curve - the curve is slightly off but close enough
will cut the size at top once I determine where the boats sit
Congratulations on your retirement. I’m a month into mine. New way of life… thank goodness for the ships. 😁
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Been a while since I posted
Busy with gym visits and golf lessons
i finally had a go at the tryworks : I had been wondering how to simulate brick mortar but realized the acrylic art paint I was using is thick from the tube so I painted the white in the spaces between bricks and wiped it off the bricks
then dry brush with red and brown and some black for soot
the bricks under the stacks are just grooves in wood with white and red paint
the copper around the pots is art paper painted with acrylic patina color and grey
the solder is tin color paint
the stacks are plastic square tube that I cut lengthwise and glued to make it rectangle
i painted with tin and will be adding black wash and bit of rust dry brush, probably
I included a photo of the current state with deck furniture etc sitting there
i will return to the davits and also figure out the position of supports for boat deck and tryworks shelter
On 2/1/2022 at 4:43 PM, rookie said:
Thanks Dave
models give something to do once in a while
