37 minutes ago, Louie da fly said:
Looking very good, mate. Real progress!
Steven
Thanks Steven.
Appreciate you checking in!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
3 hours ago, Moab said:
Looking good...Moab
Thanks Moab!
Appreciate you stopping in.
Lyle
Completed Builds:
In progress:
Getting down to the nitty-gritty!
Stern cap installed:
Mast work is pretty simple on this build. The mast was preformed and required nothing except sanding and a couple of holes drilled near the top to handle the rigging later on. I added a halyard cleat to the aft side of the mast. I made it out of walnut because every time I tried making it with the stock wood, it would split! After the fourth one... I switched wood!
I also added the mast step and used a piece of brass rod to ensure a solid joint:
IMG_5262.thumb.JPEG.80779882cc671cd35684854423dc6471.JPEGIMG_5263.thumb.JPEG.6d1447945bc8d5c3f5236b76508bc35c.JPEG
And then glued it into place. On my build, I measured forward 7.5 inches from the stern and cut away some of the partial ribs to make room for the mast step and mast. Double-checked the alignment on both axis:
IMG_5266.thumb.JPEG.ea01c3c6c0a16494a2afd4d7b61004df.JPEGIMG_5267.thumb.JPEG.bd1224eb5a7c824561e6484623897293.JPEG
Any minor adjustments can be done with the rigging. But actually it's pretty well aligned.
Mast done!
Looking at another build log awhile back, I saw some deck boards that I think would have been appropriate for the time period and the boat. I decided to use a similar pattern but maybe a bit more primitive than his work. If I can find it again, I'll give credit.
Used some Basswood just for a bit of change for the deck:
IMG_5268.thumb.JPEG.a7a813bf81616d248190e4073374c574.JPEGIMG_5270.thumb.JPEG.d8a06c22edfb62f6a83c4bab520dfab8.JPEGIMG_5271.thumb.JPEG.c93d27e405cbc99fbf14baef6b483f69.JPEG
Time for a coating of the finish. I followed the advise of the kit designer and used Amber Shellac. I've never worked with it but found it to be really easy to use:
IMG_5273.thumb.JPEG.36a1aacdf3b49d1bda3203faf698f44e.JPEGIMG_5274.thumb.JPEG.b524b5cf09b2a0910fdcf5ba6fac3e66.JPEGIMG_5275.thumb.JPEG.a41c4a59b7e21f2263a7944180a7be46.JPEG
I like the look and after some rubbing with steel wool, I like it even more!
Now that the main structure is done, it's time to get busy on the bits and pieces:
Pictured above are the oars, rudders, seats, oar locks and davit pieces. I started by sanding all the pieces and then went on to assembly the 4 oar locks:
IMG_5278.thumb.JPEG.998fda33d0bc19da7d04e39ff3d469ee.JPEGIMG_5279.thumb.JPEG.d9a366ba6af9f34c7631702c24b71f5d.JPEG
Some shaping with a round file and these will be ready for a little touch-up sanding and shellac and then be ready to install.
Work continues tomorrow and through the weekend!
Lyle
Completed Builds:
In progress:
Lyle,
    Looking good.  I like the finish.
    The excavation report indicates that there may have been floor boards/deck boards as you have modeled.  Floor boards were not found with the wreck, but this is easily explained since they would have been salvaged before the boat was abandoned.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
4 hours ago, Chuck Seiler said:
Lyle,
Interesting that the book I read did not mention floor boards.
There must have been an updated version of the book several years after the original was written.
I know the work to save the boat took several years.
Lyle
Completed Builds:
In progress:
    As I mentioned in my log, there were 2 documents-the book and the report.  The report can be downloaded from the net.  From a quick glance, 75-90% of the material is the same, but each has some stuff the other does not.
    Both the book and report were based on early findings.  I wonder if anything has been published as a follow-up.
Chuck Seiler
Oar locks, Oars, seats and rudders are assembled:
... and installed along with the rigging pins and rudder davits:
IMG_5281.thumb.JPEG.db1e9785cbd8631beb0a95a64c5e433a.JPEGIMG_5282.thumb.JPEG.69e7b1ae9d22328f7ee6d3da8cbd1cd6.JPEGIMG_5283.thumb.JPEG.46859a91d7c87402dece078260e95c9b.JPEG
The rigging is so much simpler than the usual work! No complaints!
Standing rigging including the seat to mast and the oars. I decided to stain the oars and rudders in a contrasting color:
IMG_5285.thumb.JPEG.14aa7ef55037ff31f2c888085f7fba2a.JPEGIMG_5286.thumb.JPEG.10e2136ea50669b6b41b656bc2795e6c.JPEGIMG_5287.thumb.JPEG.345f66d473a5e27d893317560a51f917.JPEG
Bending the sail to the yard was a simple stitch:IMG_5288.thumb.JPEG.7f652fb60400c7754bd597452a583393.JPEGIMG_5289.thumb.JPEG.ff6ff5c6a73376277e15ea118b4d21d2.JPEGIMG_5291.thumb.JPEG.81bc5782160f2d635dd039de48a97470.JPEG
My one regret is that I should have ironed the sail before bending it to the yard and hanging it on the mast... oh well! I have a few ideas to remove some of the wrinkles. I'll get to that last. Also, need to straighten out the stitching a little bit!
I began working on the remaining rigging. Again, very simple. As you may have noticed in the above (and below) pictures, I chose not to use the the supplied rigging lines and used the lines that I made with my rope making machine. The yard was bound to the mast and the line to raise and lower the yard were completed:
IMG_5292.thumb.JPEG.eae70010a3a56ebe5a694eee4d6d072d.JPEGIMG_5293.thumb.JPEG.b17f1b057f710e4fe83d513df9752a6c.JPEGIMG_5294.thumb.JPEG.6d1670ec990259f9c9cb4521b39a7725.JPEG
The sheet lines are actually made from a copper wire painted white... an interesting idea to keep the sail away from the mast and look more natural:
IMG_5295.thumb.JPEG.f8667c6c4493d1ce02d83a33b1ad3451.JPEGIMG_5296.thumb.JPEG.062369bf544adad4df3a7f7220d217ab.JPEGIMG_5297.thumb.JPEG.e510919bb8e9c108f1e95205ee503d9b.JPEGIMG_5298.thumb.JPEG.2e5a789209442e06435d20b2d40d0d16.JPEG
The stand:
The fishing net, anchor and line and basket are all that remain to complete this model.
I do intend to work on the sail... shaping and removing the wrinkles are the main goals.
Gotta check the little things too. Sometimes, I get lost in the big job and forget to look closely for anything that may need a little attention. If you notice anything, please feel free to point it out!
The next post will be the final of this build log with pictures of the final build!
It will be a few days, as I would like to set up a good photo area and finishing the little bit I have left.
Also, once I present it to my dad, I'll post a few pictures of that too!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
You're almost there, and it looks brilliant.  Looking forward to seeing the presentation--thanks for including that.  A small travel garment steamer might be useful. They work well in removing folds and wrinkles from clothing.  Just pass the steam over the fabric. Don't hold it in place for too long. Those things are hot.
Experience is what you get when you don't get what you want
Current build: Model Expo Glad Tidings, Pinky Schooner
First builds:
Midwest Muscongus Bay Lobster Smack
Midwest Chesapeake Bay Flattie
Excellent idea! Will give it a try!
Lyle
Completed Builds:
In progress:
2 hours ago, Chuck Seiler said:
Lyle,
    Are you going to encase it?
I don't think so. My dad has limited space and this guy should be pretty easy to keep clean!
Lyle
Completed Builds:
In progress:
I made it! With a couple weeks to spare!
Below are pictures of the final product.
This has been a fun build and I've really enjoyed it.
Once I give it to my dad, I'll post a few more pictures!
Until then...
IMG_0035.thumb.JPG.78e8b6665e3d561e05103d6a1e035779.JPGIMG_0020.thumb.JPG.3fdd777cee8da6133671267e9079b5d5.JPGIMG_0021.thumb.JPG.d9068477f2cd6c317afd4683a15c6213.JPGIMG_0022.thumb.JPG.8c7899399f3259d18440e1b1ac445808.JPGIMG_0023.thumb.JPG.c4eddbf66c29d1a4e4c8014ff05f9045.JPGIMG_0024.thumb.JPG.a750fe2b8520884d9eb0ca11fdfd2e2c.JPGIMG_0025.thumb.JPG.7a80c8c5c8a54640f213583814b18c29.JPGIMG_0026.thumb.JPG.cd78c3e731d04815c964960cdb33a755.JPGIMG_0027.thumb.JPG.f2cebcdf254872c3e45b4d5752cafe23.JPGIMG_0028.thumb.JPG.4d253f399dffaec4f82f7748bd96d11a.JPGIMG_0029.thumb.JPG.042eefeaaca80315f7e582475d510550.JPGIMG_0012.thumb.JPG.76e853c70c3cad3250c169f42111f2a2.JPGIMG_0014.thumb.JPG.b8ef64ea94dd7435ed5294033eb98861.JPGIMG_0015.thumb.JPG.4a59b42de78030f21cc922750e07211a.JPGIMG_0016.thumb.JPG.3128b4a14665f8856fa092394c26b197.JPGIMG_0017.thumb.JPG.23a0cda3f320bf3d4a78e0c219842e64.JPGIMG_0018.thumb.JPG.ea0dcbc650175d4c00d869b5642b2a3b.JPGIMG_0031.thumb.JPG.b2d4a65d1061f233bce03d88c2d1aecf.JPGIMG_0034.thumb.JPG.7503e2d9136de31e2e29db2bb8c9c0ef.JPG
Thanks to all for your encouragement, ideas and for tagging along!
I'll be taking a few weeks off and then... back to HMS Bounty!
Lyle
Completed Builds:
In progress:
17 minutes ago, Chuck Seiler said:
Congratulations Lyle.  Well done!!  :imNotWorthy:
Thanks Chuck!
Looking forward to your updates and progress!
Lyle
Completed Builds:
In progress:
Lyle...congrats on a wonderful boat...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Thanks Chuck, Steven, Moab and Tom.
Appreciate your stopping in from time to time and your comments.
Looking forward to dad's birthday!
Stop by my Bounty log!
Lyle
Completed Builds:
In progress:
Well, between a busy month of August and a minor health issue for my dad, I was late in delivering his gift.
All is well and he finally received it over the weekend:
IMG_5411.thumb.JPEG.f6f7660811964a977a49bcce93976613.JPEGIMG_5414.thumb.JPEG.d0b2a535238598809ea9b147d36a24e2.JPEG
I caught him completely off guard! And he was very surprised!
That will conclude this build log!
Lyle
Completed Builds:
In progress:
