Planks between thick stuff and channel wale (lower amarillo strakes)
This is fairly straight forward work though some careful attention is required to reproduce rabbet of gun port to receive lid because I already installed sill. Again pictures and depictions will tell the procedure.
I dry fitted 5mm x 1mm amarillo above thick stuff then cut opening of gun port along sill.
I marked actual opening line of gun port around line of sill already cut. Then carefully cut along marked line. Of course occasional dry fit to hull is required to avoid excessive cut.
Strake above gun ports is treated different way from lower one. Vertical lines of gun port are simply marked as extension of end of planks already glued. Also the height of gun port is designed to 12mm, so upper end of openings are easily determined. Photo is again showing cutting of opening for gun port.
Photo above is of final result of this procedure.
Some problem caused by gun port patterns
Before starting description on channel wale installation, I want to note about some problem caused by gun port patterns of the kit. IMHO it seems that interval of gun port lows of lower and upper gun decks are slightly wider than it should be at midship sections. It requires some compromise when deciding positions of strakes and rails above main wale. If I keep principal of ‘parallel running of strakes above main wale’, channel wale and rails will be showing excessive sheer in comparison with lows of upper gun ports. Finally I decided reducing width of channel wale and upper amarillo strakes towards both ends. This compromise is against to principal of parallel running of strakes, but I think it would be pragmatic way in this case.
Most of pictures of bellow were taken after planking work was finished. I should have to take pictures of comparison of kit profile drawing and gun port patterns settled on bulkheads before 2nd planking work, because they would be showing problem I encountered more clearly. But pictures of bellow will be showing you what I want to say. Of course these are only my opinions. I will leave final evaluation to each modeller.
Photos above are showing distances between two rows are gun ports are wider at midship sections.
Width of channel wale (and upper amarillo strakes) is reducing towards both fore and aft ends to keep appropriate positional relationship between running line of channel wale and rows of gun ports.
Edited by fake johnbull
Mitsuaki Kubota
Current building: HMS Bellerophon (1786)
Recent completion: Venetian Galleass/Imai (heavily bashed) 1/133
                                  IJN Hiburi Class Kaibokan Escorts/ Pit-Road 1/700
                                  HMAS Vendetta/Showcase Models Australia 1/350
                                  HMS Nelson/Trumpeter 1/700
                                  Mayflower/Airfix 1/96
                                  USS Powhatan/scratch 1/400
                                  HMCS Snowberry/Revell 1/144
Planking of channel wale
Kit instruction suggests starting channel wale installation after 2nd planking of whole hull finished. Instead I finished and blackened channel wale at this stage. Also I determined to plank and blacken strakes above waist rail before planking upper amarillo strakes. These will make it enable to plank upper amarillo strake easier.
BTW it would be much better to use timber of appropriate thickness (about 1.5mm) for channel wale, but I couldn’t afford new timber. So my channel wale is layers of walnut strips of 1mm and 0.5mm thickness. Strips of 0.5mm thickness was thinned from strips of 1mm thickness supplied in the kit.
Kit instruction suggests use one strip of 5mm width and two strips of 4mm width. I obeyed this suggestion but reduced width of uppermost timber towards both ends.
Pictures and depictions bellow will tell my sequence.
Photos above are showing how uppermost timber reduces its width toward both ends.
Photo above is of planking of 2nd layer of channel wale. I used walnut strips of 0.5mm thickness as I mentioned above. I blackened lowest timber before gluing to avoid spoiling amarillo strakes with black dye, though I had to sand it to get smooth surface of channel wale.
Preparation of blackening of channel wale. Once sanding of channel wale finished, amarillo strakes were masked and channel wale were blackened.
Above photo is showing final result.
Mitsuaki Kubota
Planking of strakes between top edge of hull and waist rail
According to usual ‘upward’ planking, next turn would be planking of upper amarillo strakes. But I planked them at final stage and preceded planking of strakes between top edge and waist rail. This unusual procedure will ease blackening of planks between top edge and waist rail. Also I want to run waist rail — it coincides top edge of amarillo strakes — with correct heights in comparison with 18 pounder gun port lows of upper deck. So determination of positions of waist rail was my priority and it was natural decision for me to plank strake just above waist rail.
Again pictures and depictions will tell the sequence.
Planking of strake just above waist rail position
Photo above is showing how planking work is continuing upward. Unexpectedly, three walnut strips of 5mm width reached top edge of gunwale just fore of bulwark brake. Also two vertical slits were cut to receive metal rods to enforce head timbers installation of later stage. Later I removed quarter deck bulwark in favour of more graceful line and these slits became useless. But I recommend cutting the slits at this stage if modellers want to build per kit design.
Planking work is continuing upward. Again unexpectedly, seven strakes of 5mm width strips reached top edge of aft end of poop.
Photo above is of blackening of planking after cutting excessive timbers above top edge. Also at this stage I cut 'top timbers' of bulkheads where inner bulwark planking will be done later.
Photo above is of final result.
Mitsuaki Kubota
Planking of upper amarillo strakes
Final stage of hull planking is installation of upper amarillo strakes. Amarillo strakes are also reducing its width towards both ends.
Photos above are of ‘shutter plank’ which is reducing its width towards both ends. But it will be hidden by waist rail later and I don’t mind its inauthentic finish opposing ‘parallel running’ rule.
Photos above are also showing the completion of hull planking.
Mitsuaki Kubota
Decorative rails
Next stage is installing of decorative rails on upperworks. I have also added some small upgrade to hull fittings. I want to depict them with pictures and comments as I did before.
Firstly I prepared waist rail. 2 x 2 mm and 1 x 1 mm amarillo strips were glued then they were shaped by moulds on brass board edge.
Although waist rail is once moulded successfully, I added one more groove after some second thought.
Photo above is of prepairing of other rails. They were shaped from spare limewood strip left after first planking.
Photo above is of preparing of fenders and chesstree. They were carefully shaped to fit ship’s side. Areas adjoining amarillo strakes were thinned and covered with amarillo shavings. Inner side of amarillo shavings was painted in white to avoid darkened by walnut colour of kit parts.
Photo above is of attaching of rails, fenders and chesstree to ship’s side.
Mitsuaki Kubota
Correction of height of knuckle aft of beakhead bulkhead
At this stage of construction, I noticed I had made terrible error on determination of height of knuckle aft of beakhead bulkhead while I was examining positional relationship of decorative rails, cathead and its supports. So it would be appropriate to depict about it at this point.
Many of British (and other nations) wooden man’o’war have knuckle on their bow generated by concave flare and vertical portion above it. It can be seen clearly on body plans, although it is sometimes buried into decorative detail drawings if the plan is including such feature.
I determined height of knuckle referring NMM Edgar plan, but I had misunderstood line shown on body plan and I gave greater height between hull top edges and knuckle. Perhaps attached picture tells you how I was dazzled by body plan. I had misunderstood that vertical lines of bow sections are height from top edge of hull itself to knuckle. Serious study on plan and referring to experienced modellers' works are revealing that vertical line on the body plan is including length of timberhead and knuckle should be running above than I firstly did.
IMHO kit bulkhead and gunport pattern design is also including some problem. Very close examination of Edgar body plan tell us knuckle position at beakhead bulkhead of kit is slightly lower than it should be in comparison with height of fo’c’sle deck, and lower corner of forward end of upper gun port patterns are furthermore lower than knuckle position of bulkhead. At first, I estimated lower corner of upper gun port pattern is position of knuckle and filled wood piece to gap between pattern and bulkhead.
It is consoling for me that I noticed problem at this stage. If I noticed my error at later stage, corrective work would be more difficult. Initially I placed knuckle to the border between walnut and amarillo strips – top edge of waist rail. I determined heighten knuckle by width of one walnut strip so that knuckle will be running along bottom edge of sheer rail. I once removed planks and re-shaped backside of planks then re-installed planks. Reworking on knuckle left some ugliness on plank joints, but I hope they will be hidden by decorative rails and cathead supports.
Perhaps this kind of error would be unfamiliar to veterans of ship modelling, but I’m still hoping to share correct knowledge to understand lines on ship plan amongst novice modellers.
Picture of before correction working.
Once remove planks and re-shape back side.
Corrected position of knuckle.
Mitsuaki Kubota
Upgrading of cathead
Determination of cathead position is very important matter because it runs between decorative rails. So I upgraded cathead part then temporary fitted it to its position.
Firstly I prepared thin walnut pieces. Three short length pieces and four longer pieces were prepared per one cathead.
Walnut pieces are assembled shown in picture.
After bond dried I cut head of cathead. Sheaves are cut from dowel then inserted to holes.
Vertical knee and hook were cut and shaped from spare woods. They were attached to after side of cathead.
Decorative moulds were added to fore side of cathead with walnut shaving.
Mitsuaki Kubota
Other small upgrade
Besides with decorative rails I assembled some other decorative parts.
Some PE parts show protrusion like flash of injection moulded kits. I noticed them after I painted them. They were filed smoothly. BTW I painted them in white to simulate those of contemporary models made from ivory or bone.
Decorative columns between windows. I greatly recommend file their side smoothly.
Kit bulkheads can be seen through rudder hole. Although it is minor faults, I feel some fixing is required.
I built dummy rudder head bulkhead from spare woods.
Dummy rudder head bulkhead seen from rudder hole.
Mitsuaki Kubota
Finishing of decorative rails installation
Photos above are of entire ship’s appearance after installation of decorative rails. BTW I abandoned to use kit metal taffrail part because they are very hard and difficult to fit curve of stern facia.
Photos above are showing taffrail base is raised with hinoki cypress strip I purchased from DIY shop in my local area. Rib of taffrail was made from .75 x .75 plastic rod. At this stage, stern facia is temporary fitted to its position.
Photo above is of cutting of top edge of quarter deck bulwark and poop deck side. After some thought, I lowered quarter deck bulwark to match Elephant drawing I found in “Nelson’s Ships” by Mr. Peter Goodwin. It needs scratchbuilding rails but I think more beautiful sheer lines will be generated by lowering bulwark. Top of poop deck side is also lowered to compensate depth of capping rail.
Mitsuaki Kubota
Start of copper sheathing
I’ve started copper sheathing. It is basically repeating of same procedure to glue copper plates to hull bottom in brick patterns. But estimation of running of copper rows and determination of place to start copper sheathing is something source of trouble because it is entirely new experience for me.
Again I want to tell the work sequences with pictures and comments.
Firstly I divided copper plates to each segments. Copper plates sheets can be easily divided into each segments by hand, but usage of glove is very important to keep copper clean.
Both of port plates and starboard plates are stowed in small boxes separately.
Sealing of hull bottom.
Sanding of hull bottom after sealing was dried.
Copper plates are jointed with tape like caterpillar track.
Photo above is showing how I transferred width of copper plates to seek running of plates with the track.
Photos above are of determination of running of copper plates. I determined to use no drop of strake of copper rows in bow section. But it seems to be inevitable to use stealers at stern section to keep natural running. At this point, I estimated to insert four stealers of copper plates to stern section.
Mitsuaki Kubota
Continuing of copper sheathing (part1)
Photo above is showing sheathing is started from aft end of keel.
Photo above is of two strakes of copper plates sheathed upward from keel and walnut strip as batten to confirm line of third copper row above stealer copper plates.
Photo above is of marking of running line of third plates.
Photo above is showing how I decided to insert two stealers here.
Photo above is showing third copper row is glued along marked line.
Photo above is showing triangular space is filled with stealers. In this photograph stealer copper plates and their neighbouring plates are cut in “edge to edge” manner.
Mitsuaki Kubota
Continuing of copper sheathing (part2)
Copper sheathing is continuing. I have done area including second stealer using some idea inspired by Ray’s beautiful Pegasus building.
(http://modelshipworld.com/index.php?/topic/87-hms-pegasus-by-ray-victory-models-build-started-jan-2010/page-2#entry1057)
Initially I thought it isn’t easy to adopt his method of overlapping stealer by uncut rectangular copper plates in the case of simulating “continuous row of nails is on upper side of copper plate”.
But I found Ray’s overlapping idea can be applied also in the case of above by some changing sequence.
Photo above is showing gluing strake of copper plates just beneath of stealer. It once stopped at the point stealer is starting.
Photo above is showing gluing strake of copper plates just above of stealer along line already marked with batten and pencil.
Photo above is of stealer plates roughly cut to their shape and glued to their position.
Photo above is showing gluing copper plates just beneath of stealer.
Photo above is showing overlapping idea inspired by Ray went well and it shows more beautiful result than filling cupper plates cut into triangular shape previously done. Later I reworked stealers between 2nd and 3rd strakes in same manner.
Mitsuaki Kubota
Continuation of coppering
Photos above are showing coppering is also started on port side. As I did it on starboard side, I adopted Ray's overlapping copper plate idea around stealers.
One of important matter of model building is symmetry of left side and right side of the model. Symmetry of copper rows is also important. As shown in photo above, I checked length between waterline and copper rows several times.
As copper rows closing to WL, it became apparent lengths between WL and copper rows are slightly different from one side to another because of poor job at bow section. To achieve symmetry of copper rows of both side, I trimmed lower edge of stb plates.
Photo above is showing bottom of keel are covered by combination of bent copper plates.
Mitsuaki Kubota
Finishing of coppering
Finally I finished hull coppering. Despite of poor solution to achieve symmetry of copper rows, I’d fully enjoyed hull coppering than I imagined before starting of the procedure.
BTW, it would be important how I cleaned copper plates after finishing of coppering. I’m sorry that I didn’t take pictures of cleaning procedure of copper plates, but I hope depiction of bellow will help your understanding of my method.
As can be seen on last photo of previous posting, copper plates became dirty by affection of human hand soil. After finishing coppering I rubbed plates with abrasive compound. Copper plates regain their shinning by abrasive compound, but white dregs are left to nailing moulds. I lightly rubbed plates with ebony colour Watco oil and plates regain its nailing mould effects
Photos above are of result of coppering.
Mitsuaki Kubota
Installation of rudder
After hull coppering it is turn of rudder installation. Working procedure is very straightforward task but I add some extra work to represent some features omitted from kit parts.
Photo above is of determination of positions of gudgeons. BTW I cut bottom of rudder by 2 mm after this picture was taken to achieve more favourable positional relationship between rudder, gudgeons, pintles and waterline.
Gudgeon nails are simulated by brass rod because I thought more strength is required for them because of curve of gudgeons to follow hull shape. But pintles have more plain shape so I simulated their nails with plastic rod which is easier to use.
Photo above is showing centre sections of gudeons and pintles are represented with paper. BTW I painted kit brass rudder fittings under waterline with Humbrol copper (No. 12) and chemically blackened those of above of waterline.
Photo above is showing addition of decorative strips between round tuck and counter. Dummy stern chaser port lid is represented with thinned walnut strips.
Photo above is of finishing of rudder. Emergency steering chains are added. Although it can’t be seen well in this picture, I also add chemically blackened brass strip and its nailings to rudder as fixing point of chains.
Mitsuaki Kubota
Stern decoration improvement
As I had written several times, stern decoration metal parts contained in the kit are source of trouble difficult to solve. Die-cast stern deco parts provided in “initial batch” of Vanguard kit are very hard to give adequate gentle curve of taffrail. I understand recent batches are improved by provision of more flexible resin deco parts.
One of solution is asking Chris Watton or Amati to send resin replacement parts which is easy to bend. One of other solutions is curving them by myself and another is duplicating kit parts with copying materials. Finally I decided to duplicate taffrail decoration with copying materials.
I understand designs of decoration parts in the kit are best guess works by Chris Watton and completed model using them can’t be claimed as “100% historically accurate model” comparing other 74s of which original plans containing decoration details. But this is my model and I want to add some changes to Chris’s design utilizing my “artistic licence”. While Chris Watton is suggesting using taller taffrail for Bellerophon and Elephant in his instruction manual, I decided to use shorter taffrail prepared as option for Vanguard and protrude head of Bellerophon from top of taffrail as can be seen on some of contemporary models.
Photo above is showing how to copy kit deco parts. Kit stern deco parts are pressed to thermoplastic moulding material (“Katadorikun” sold by Muto Shoji Co Ltd. in Japan).
Photo above is of completed mouldings and kit parts. BTW I didn’t copy quarter figures because of my preference to more 3D appearance.
Photo above is of duplicated deco parts with “Plarepair” which is also sold by Muto Shoji Co Ltd.
Photo above is of copied deco parts removed from backing then dry fitted to taffrail.
Photo above is of painted decorations. Colour decisions are completely owing to my artistic licence.
Photo above is showing gluing of ship name letters. As can be seen on this image, I used photocopy of kit stern deco plan drawing as template. I made slits between each letters of photocopy and glue PE letters one by one from centre sections to each ends.
Mitsuaki Kubota
Quarter figures
When I decided to build Bellerophon from three options, I decided to represent quarter figures as 3D pieces whilst those of the kit are represented as mere relief. L. G. Carr Laughton writes that quarter figures or “strong men” of ships’ stern became merely vestigial by the order of 1796. So quarter figures of the kit may be correct if actual ship had received repairs on these decorations after that date. But I prefer 3D quarter figures than mare relief and I determined to improve stern decos in some way.
Initially I tried using 1/72 Roman warrior figure released from Itareli for quarter pieces and it isn’t bad idea. But I noticed that stern decos of model are occupied by too much male motifs. So I decided to carve goddess quarter pieces by myself from boxwood.
I downloaded google image search results with keyword “Bellerophon”. I determined to settle Athena to starboard. I don’t know who is she but I determined to settle goddess figure based on another google image search result to port side. Maybe she would be Stheneboea or Philonoe. I resized downloaded images to desirable size for carving templates.
Absolute desirable finish is natural wooden finish, but carving from boxwood is my very first experience and I broke their neck and arms sometimes. I decided paint quarter pieces to conceal their vestiges. Also leaving quarter pieces with their natural colour requires further carving for other decoration motifs to match their colour finishes. I adopted easier way but I’m quite happy with results.
Photo above is of start of carving from boxwood.
Photo above is showing quarter pieces on carving process and their templates downloaded from google image search result and resized to match model. Neck of port side goddess is broken and it was repaired later with reinforcement of brass rod.
Photo above is of port side goddess nearing completion.
Photo above is of finished quarter pieces carving.
Photos above are of decorations seen from several angles
Mitsuaki Kubota
Other stern parts
Photo above is of lower finishing and drop scratchbuilt from excess of 5 mm walnut host sheet in the kit. Unnumbered MDF parts are also contained in the kit as upper and lower finishing as well as metal drop parts. But I preferred walnut for uniformity of material. Difficulty to shape metal drop parts to their positions is another reason to give up using them.
To ease to give appropriate curve to PE balcony rail, I cut lower rail. Moulded amarillo strip replace it.
I used White Ensign Models RN buff paint for painting of PE parts. This paint has very resembling colour with amarillo.
Dummy tiled roof of upper finishing are thinly sliced 2 mm plastic rod.
Mitsuaki Kubota
Construction of head
Construction of head would be one of most difficult stage of sailing warship model building because of its complex mixture of curved timbers. Fortunately curves of most of these timbers are 2 dimensional and I believe head construction can be achieved with some care and patience.
Now let’s start actual consequence with pictures and depiction.
Photo above is of dry fitting of figurehead. Before starting of head construction, I had to adjust jointing of figurehead and head. Figurehead provided in the kit are hard cast metal, so cutting of wooden head is only resolution. It is desirable to fit figurehead to head without any gap, but I had to rely on putty. I hope usage of putty will be sealed with black painting.
Photo above is of preparing of amarillo sheet. Because of usage of amarillo strip on hull planking, I determined to use same timbers for head construction. I don’t have electric circular saw and had to cut them by hand saw. Section after hand cutting are very poor, and I want to buy table saw someday.
Transferring outlines of rails from kit parts to amarillo.
Photo above is of cutting sequence.
Head parts cut from amarillo.
Photo above is showing construction of V shaped head timbers and gratings. Initially I put aft end of aftermost grating on the prow deck. But after some discussion with Arthur, I noticed aftermost grating should be even level with prow deck. Anyhow I recommend to careful test dry fit before gluing of parts.
Upper cheek is glued. I noticed that it is easier to construct head rail by settling model at upside down position.
Photo above is of hawse hole pattern construction. Holes are drilled to bow. I add thin wood strips to backside of patterns for perfect adjusting to stepping of thick stuff.
Mitsuaki Kubota
Continuing of head construction
Photo above is of gluing of upper rail.
Middle and lower rails are installed. These rails are 2 X 1mm amarillo strip and bent with steam and heat from kettle. I also add moulds to them with metal edge pattern.
Photo above is of covering to V shaped timbers. They are 3 X 1mm amarillo strips. I add some moulds to these covering strips as shown on pictures.
Installation of lower cheek
Symmetry of both sides are checked from directory forward. Perhaps small asymmetry would be discovered by careful examination, but I’m satisfied with the results.
Photo above is showing painting of catheads. Blue areas are represented by gluing thin strip shaved from amarillo and painted in blue.
Mitsuaki Kubota
Cathead support
Cathead support is one of most difficult parts to determine its shape. Not only its own graceful and complex 3 dimensional curve it should also fit on bow flare with minimum gap. Photo above is of pattern cut from black card.
transferring of outline from pattern to 0.5 mm maple sheet.
Maple sheet is cut following pencil line transferred from pattern.
2mm walnut piece is sandwiched by maple. Lower section between two maple sheets is also filled with walnut piece.
Rail connecting cathead support and middle head rail was built from pair of 1 X 1mm strip. It is far easier to bend pair of 1 X 1mm strip than 2 X 1mm strip. Bent them with steam and heat from kettle, then after desirable curves were gained, the pair of strips is glued together.
Photo above is showing connection between middle head rail and cathead support on its position. It was moulded with metal edge pattern and cut to appropriate length and glued to its position.
Mitsuaki Kubota
Completion of head
I managed head construction as depicted above. I’m thinking result is not bad and feeling relieved to finish this difficult section.
Photos above are of close-up of bow rails. BTW vertical sections of beakhead balkhead columns (part 418) are replaced by Evergreen channel strip because moulding direction of kit photo etched part is inverted.
Photo above is showing entire model.
These are all I can upload now. I'm now preparing guns for the model. I really hope members enjoy my building log ;)
Regards,
Mitsuaki Kubota
Hello B.E.
Thank you for your kind word :)
Although decorations of late 18c ships is surely simpler than those of previous years, they still show very beautiful appearance beside with gentle curve of basic structure of head, quarter and stern galleries. I really like them.
Regards,
Mitsuaki Kubota
Hi there MK
It is really a pleasure to follow your build log. Your patience and craftmanship are drawing respect.
Keep up the good work... the final result will be a beauty.
Mio
Nelu A
The shipbuilder without patience is like the ship without an anchor.
Completed build: SAINT JOHN THE BAPTIST by Mioriticul – D’Agostini (AL) – scale 1:50 – first wooden ship model
Hello Mio, Richard, Daniel, Arthur, Dirk and Juergen,
Thank you for your comments :)
Perhaps Arthur remember that I'm now working at workshop for deaf people. We are doing small assemblies like pencils, pencil lead sharpeners or paper clops. I sometimes make jigs for those assemblies and it is great joy to see my jigs help deaf people to assemble products easier and faster. Old people said that Art brings cheese. Perhaps modelling skill can be said as one of Art”. Actually skill cultivated by modelling helps me a lot on the job.
Regards,
Mitsuaki Kubota
I'm glad to see you and your Bellerophon back, I'm very much enjoying following your progress once again.  I love the "Art brings cheese" saying, you should have a lot of cheese!  :)
Cheers,
Jason
In the shipyard:
