I finally got the courage to cut out the anchor chain tube in the forecastle. The diagrams on where to put the hole in the deck.
Use a small bit first and go slow. Move up to a 1/4 inch bit. Slide the 1/4 inch tune up into the hole and cut flush. The boat door was glued up on the stern.
The back deck was also cut to fit as a slide in.
7 hours ago, highlanderburial said:
I decided to try and make the stern more accurate based on the original design. The stern has defined tunnels which house the rudders. I do not totally have the basis of the structure lined up, but I wanted to get this set prior to putting on forming putty.
Very nice work you have created! To me your model looks as the real deal! Man, you are doing well!!!
John
I used a lot of epoxy putty and sanding to get the tunnels complete. So far I am glad I did it because the stern will look sharp once the anti fouling paint and draft marks are on. I slapped some black paint on the stern to look for high spots when I sand it a final time. A shipmate sent me a photo of the stern of another FRC soon to be launched. This helped me out so I will post it here. I also started building the roof of the 01 deck and installing bulkheads. These are super tricky and the port and starboard structure rails are different sizes. The instructions are a bit ambiguous with the markings but just got slow and make sure you test fit a few if the basswood "C" bulkheads prior to gluing in the rear C9 flat panel guides.
Edited by highlanderburial
Today I puttied up some more low spots. The real ship has a bow thruster but the model makes no call out for this. I measured back about 4.25 inches from the hawser hole in deck and drew a circle around the boat to find the placement. I never like cutting a hole in a perfectly good hull. I used a small starter drill bit as a starter. I then moved up to 3/8ths then 5/8ths. The plastruct tube in inserted was larger than that one the outside diameter. MAKE SURE you glue one side prior to cutting the tube flush or it will pop out.
Very nice work.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Very nice build and a beautiful vessel. The kit came too late for me but it looks great. I have build this model also but did not have plans so did a best effort. I could not post the image but here is a link to a photo in my blog (don't really know if permitted?).
https://www.modelbouwforum.nl/media/3_dsc_0104_small.257905/
I really like your build quality and blog and going to follow.
Frank
I started working on hatches and scuttles. As a note to all those attempting this build should note that there are 3 different sizes of doors. I spent 40 minutes figuring out which ones were which when I could have simply held them up to the parts sheet. See photo. You will need to use a 3/16 drill bit to cut port holes in the water tight doors. You also need to do this with 2 different doors each with hinges both left and right.
Hi, I don't know if you want to make the model radio controlled but then you may consider to enlarge the access space to the hull using the large size of the upper deck to cover. It makes the access to the hull easier and in my vessel it came in handy to be able to install motor, servo, esc and batteries.
Frank
