On 10/7/2021 at 2:56 PM, Dutch builder said:
Hi, I don't know if you want to make the model radio controlled but then you may consider to enlarge the access space to the hull using the large size of the upper deck to cover. It makes the access to the hull easier and in my vessel it came in handy to be able to install motor, servo, esc and batteries.
Frank
DB
This particular model will be static. I do have another that I will likely make R/C. I think it would have a pretty tipsy profile at high speed turns like a destroyer.
Your build looked awesome by the way I went to your link.
Thx for your comments.
Mast work begins. I think the kit shorted me a dowel but I had extra. The kit gives you a jig to make to hold up the radars and connecting beams. The main part of the "A" frame is some 3/16 plastruct tubing but you 20211010_174016.thumb.jpg.3cc62e964ac6530c89fc30226f406560.jpghave to push through some very malleable aluminum wire. This keeps the plastic from deforming and lets it hold its shape.
Edited by highlanderburial
Grammar
Buff paint on a ship or boat is one of my favorite colors. Depending on lighting or weathering of a vessel it can look very different to the beholder. I use Apple Barrel acrylic paint colored Autumn Gold to simulate this. I then put in some acrylic gloss sealer in a couple coats to make it shiny. The mast has not been coated so far.
Nice job so far on your model. It will be a beauty. And I love the photos you took. You are lucky to be able to visit it. I looked all over the web for details but most photos are from far away or perspective distorted. I will use your photos to add some detail to my model :). Do you plan to add more detail? It will make a big difference to the original Dumas model.
Good luck with the next steps!
Regards, Frank
I would like to add a bunch more detail when I am able. I have applied flat black window glass but will leave the roof removable so I can add a more detailed pilot house later. Additionally there are a bunch of decals I would like to add to the deck as well. I understand that dumas had to run the line between details and reasonable durability for R/C purposes but I would like to add more.
I made a huge amount of progress but alas was not able to fully complete the cutter by the commissioning date. The officers still wanted it there albeit unfinished. From a distance it looked good but overall I was pretty annoyed with my project timing. I also included some pics from the ceremony.
Grammar
Nice work.  Time is our enemy on date sensitive projects.  I hope they'll let you finish her up.
You did a really nice job in a short period of time and I'm sure the crew and attendees at the commissioning ceremony were impressed with your model even if it was as complete as you would have like it to be. Thanks for all the photos also. They stir up memories of my Coast Guard years from long ago.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Superb work  - and what a great job  to do there.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
What a great way to build in a museum that is open for public! Surely must slow you down because of all chats but even so you build with a fast pace :).
I love the FRC and I am so curious about all black squares. As you seem to know a lot about this vessel hopefully you can explain to me the purpose of them. First I thought they were filters of some kind but after a closer look to your photos of the real vessel I doubt if I am right.
Frank
Hi, so I have just bought this kit, from me to me, and am really looking forward to the build.
I will be making it RC. My current build is the Dumas USS Crockett and 1949 Chris Craft prior to that.
I still have a lot to learn from masters like you so I am following this build with lots of excitement and can't wait to see what comes next.
I am from Centurion Model Boat Club in Centurion, South Africa.
Hi Johan, as much as I like this build I noticed that the added propeller tunnels as far as I can see are placed here as an extension on the bottom. The real model has it "cut out" from the bottom keeping the straight waterline. If you glue it on the bottom you break the smooth straight line and that can influence the behavior in the water as rc model. So for rc I think you best hang on to the original Dumas build instructions. Maybe I am mistaken and misinterpreted the build photo.
Good luck with the build! It is a really beautiful vessel.
Frank
