As everyone said .super work
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
3 hours ago, Old Collingwood said:
Amazing work Harry, every aspect of it  -  so  much  fine detailing.
OC.
Thanks OC,
Muh appreciated.
Agreed, the model is definitely not short on the detail side of things... 🙂
My thoughts are beginning to turn to Cabinet. options.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Thank you, kindly Ian!!
II am looking forward to your Bismarck build. when you get to it of course. 🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
4 hours ago, VitusBering said:
Absolutely beautiful work, Harry. Well done.
Thanks Chap!!
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
1 hour ago, Joe100 said:
Well now that Bismarck can transmit/receive, on the Shortwave, Longwave, and Mediumwave bands, what’s next??
Hi Joe,
Thanks for that!! 🙂
I am pleased that the Beastie is Rigged, not as complex as the diagrams you so kindly sent me but ever so slightly simplified.
(I'll be prototyping the Accommodation Ladders soon enough.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
A couple of updates:
The first is simple, RV Chima, (Rod), wanted to know what the ABER 1/200 Chain-Link Railings looked like.
Thay look very fragile.... 🙂
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Next Update:
Completed and installed the 10.5cm AA Guns. (The AA Turrets traverse), (As do the rest of them), I may fix the AA Turrets permanently in place.)
Installed the 20mm AA Gun on Turret Bruno. (I think that the poor sod manning this Gun would have a suicide wish when Bruno's Guns Fired!!)
Placed Arados, only placed at the mo as I am unsure about thier final positions.
Interference Grids almost ready for installation.
Enough for one day.... 🙂
Cheers....HOF.
Photos:
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
I have a question for the Forum and am hoping for some advice.
I have 3 DKM Flags, two for Bow/Stern Flagstaffs and one "War Pennant" that has a lanyard from the Deck to the Main Mast.
So, do I form the Deal around the Flagstaff's Lanyard, or do I wrap Foil around and then the Decal?
I wish to put the Decals on prior to installing Flagstaff's/Lanyard.
Any sage opinion/advice would be very much appreciated.
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Harry, this keeps getting better and better. Rigging looks great and the aircraft turned out nicely. Sorry I can't help with your flag question.
Ken
Started: MS Bounty Longboat,
Cheers and Regards,
Harry.
I hope to start in around two weeks..just waiting for the builders to finish what will be my very own workshop ..very excited 🙂🙂🙂
Hi Ken,
Thank you for your kind comments.
I notice a deformed Rail on the Starboard Service Boat Skid.... I think this needs to be fixed. 🙂
No worries about the Flag thing.
I'll either post on the forum under a different subject heading or ask Mr Google nicely.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi Ian,
You have some pretty major work going on there!!
BTW: When you "Embark" on your BM build, I do have some spare tiny Plastic and PE bits.
If you loose anything, drop me a line and I'll help where I can.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Cheers....HOF.
What I would  do  Is  to  make up your  flag  with  the  foil  and lanyard rope  trapped  inside  then glue  and  form the shape you want before  attaching to the  flagstaffs/mast.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thanks OC.
I am thinking around the same solution as you describe.
My thoughts, (I don't know if they are viable), is to cut the foil to size attach to the Lanyard and "Sandwich" the Decal around both sides of the foil.
Sae for Flagstaff's?
I especially want to do this, (Something), to the Flagstaff's before attaching these items.
It would be an absolute nightmare to attach the Flagstaff's first, decal after. (With the Decal/foil sandwich, I thought that the Flag could also be given some shape....)
What do you reckon?
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
39 minutes ago, hof00 said:
Thanks OC.
What do you reckon?
Cheers....HOF.
You could  build them up  first  (Flagstaff/Flag/Lanyard/Foil)   on the bench  before  fitting the whole assembly  to the  Ship, then just  run the ends of the lanyards  down to the deck  when the Flagstaffs  are  set.
OC.
Current builds
Completed works.
Mate  check this  out  might help   -    http://www.modelwarships.com/features/current/flags/flags.html
OC.
Current builds
Completed works.
OC.
Thanks OC,
That's awesome!!
(Now all I need is some sort of foil wrapped treat.... 🙂)
I'll give it a go!! 🙂
Cheers and Regards,
Harry.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
3 minutes ago, hof00 said:
Thanks OC,
That's awesome!!
Cheers and Regards,
Harry.
Harry  have you  got  any of that  cooking  foil  we use  to  cover  roated foods  to stop  them  burning in the oven,     that  will  do the  trick.
OC.
Current builds
Completed works.
Hi All,
Small update:
I "Farted" around for a couple of hours today getting tthe Starboard Arado installed.
RV Chima, (Rod), drew attention to mounting the aircraft on Catapults.
The aircraft "Skid" needs to be higher.to sit properly.
I ended up putting a 1.5mm "Spacer" between Skid and Catapult I then had to insert a 2.5mm temporary spacer under the Floats to obtain correct aircraft orientation.
Once happy with it, CA Skid and removal spacer under the Floats.
I'm still thinking about the second Arado.... Since it has folded Wings, I think I'll "Park" it in front of th Port Hanger.
(It makes the model a little different perhaps.)
Any opinion on this?
Another point of note, the 10.5cm AA Guns do not fit the "Barbettes." (The "Peg" on the Turret mounting is too long by 1.0mm or so)
I am unsure if this just relates to my Amati Version.
To fix the issue, I filed down the plastic Peg on the Turret Base that fits into the "Barbette" cup.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
OC.
Thanks OC,
Yup, got plenty of Aluminum foil.
I'll get my "Treat" tomorrow, I can then compare foil thickness. 🙂)
Cheers and Regards,
Harry.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
10 hours ago, hof00 said:
Hi Ian,
Cheers and Regards,
Harry.
Thanks Harry-- very kind of you.
No Worries,
I'll keep them aside.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
33 minutes ago, rvchima said:
Harry's Lady,
Beautiful work on the rigging! Thanks for all your help from all his friends at MSW.
Rod
Hi Rod,
Message from my lady, and yes, she did a fantastic job!!
"Thank you, that's very kind."
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
On 10/24/2021 at 12:07 AM, hof00 said:
Hi All,
Something newish for me thanks to the inspiration of others on this site.
I started this build several years ago, 2008?
I got  the basic hull and some Superstructure almost compete and thought it was time to drag it out again....
Reasons for this is that I am tired of sitting on my Chuff for the last couple of months waiting for surgery on a torn  right Rotator Cuff and looking like I'll be languishing for a couple more month's to come.
The scale and size makes things a little easier to accomplish with my left hand. 🙂
The Partworks version is essentially an Amati offering in 140 magazine issues and it seemed too good an opportunity to re-start proceedings.
(I have the Trumpeter 1/200 version with MK1 Detail set and the Tamiya 1/350 version also.)
I began this afternoon by ensuring all subsequent issues and contents  were present and put aside the 1/400 Titanic for a future when I have both arms fully operational 🙂
So, don't know how far I can get but my best shot and it's better than casting around feeling "Disabled."
The Hull looks good for the time it's been in storage, some attention with filling, sanding and primer will help
The Superstructure components will be wrapped in PE
I'm looking forward to getting stuck in!!
(A very big "Thank you" to the Gentlemen currently building the Amati version, it's given me much needed inspiration!!)
Cheers....HOF.
Photos:
If this was a one-handed build I have a hard time conceiving what you can accomplish with two hands!
53 minutes ago, ESF said:
Brings the phrase "busier than a one-armed paper hanger" to a whole new level.  Fantastic work.  Thanks for sharing.
Steve
🙂 Pretty much....
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Parking the Arado is just fine. They were moved all over the place, perhaps not while on-mission. Bismarck could ship up to 6 Arados but that would have meant storing two outside, not very practical.
Also, just for fun, Bismarck’s builders plate was just above the doors on the aft hanger. I have a drawing of it, if you guys are interested.
