I wanted to add a black wash to bring out the panel lines and hatched. In the past I have used a very dilute acrylic wash straight onto the surface. It has worked quite well but it tends to end up all over the various surfaces and darkens the base paints. I decided to try a different approach and air brushed a coating of Future floor sealant and when it was dry ran a dilute wash of artists oil black paint. I used Q-tips to clean up the surplus. I maybe should have made a stronger effect but I like the result.
The decals were applied. Not the kits strong point, lots of backing film but they went on quite nicely.
I will add a dust film over the running gear and lower hull next. I don't plan to weather too much. I don't think these were around too long to get heavily corroded.
Thanks for looking and hope everyone has a great weekend
Alan
Excellent work  Alan.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
The tank came out great.  Looking forward to your next piece of armor.
Nicely done Alan.
It is amazing how you can take a box with guns and make it an interesting build to follow. It may have been a simple kit but your effort made it better than it's parts. I for one enjoyed following it.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Very nice Alan, I really like the camo method, turned out great! I'm looking forward to the mk IV and whippet😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
On 11/7/2021 at 3:03 AM, lmagna said:
Nicely done Alan.
Thank you kindly Lou
I'm glad you enjoyed the build. I had a lot of fun with it and it actually came together quite nicely. And PE - free too😄
Alan
Thank you for the kind comment. The masking looked a mess but it worked out OK. The Mark IV is in progress - I made the mistake of opening the box - just to look.
Alan
I decided on some very mild weathering. I don't really know what a realistic level is. Some models seem to have been an exercise in adding as much weathering as the model would hold and that seems a bit too much for me. I can see vehicles on long campaigns bashing cross country are through rubble are going to get pretty beaten up but it seems the WW1 tanks would not have that sort of life and would be dirty in use and relatively tidy when in the rear. So I decided to add a little rust to the running gear, tracks and the edges of the lower panels. I currently using the Vallejo product and like the effect of the dark and light rust colours provided.
I used the dark rust colours at the edge of the lower panels and then a touch of the light rust within the dark rust and then diluted it and spread it with a wet brush.
After it dried I air brushed a mist of buff onto the lower hull and running gear. I'm trying to emulate OC but its not as good. Finally a matt coat was air brushed to lose the gloss applied earlier.
Lastly the point of this build - to meet the Renault FT17 to compare sizes.
Oh my
Can't we just get along?
Thanks for looking. all the kind comments and helpful advice
Alan
I do like your weathering  Alan  - that looks Spot on to me  - dont foreget the dust/mud can  go on in different ways  -  I thought of spraying it  but decided to dry brush it instead  - there are tons of different ways  we can achieve  our weathering  - I like yours mate.
OC.
Current builds
Completed works.
OC.
Thank you for the kind comment OC. I am a bit heavy handed when I dry brush so I thought the air brush might work. The down side is trying to keep the spray where you want it. I didn't want a line so I couldn't mask easily
Alan
