Sorry if this has been discussed before. I can see why this would be classed as running rigging and would be tan in colour. However even though it would make a huge mess of the windlass surely this rope being in the harshest of enviroments would be tarred and therefore either dark brown or black. What are peoples views on this.. Best regards Dave
Edited by DaveBaxt
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
My thinking on this is that the tarring of the standing rigging is to try and keep most of the wet out.
Since the anchor cable will be immersed when in use and completely water logged the tarring would just as effectively keep all the wet in and the cable would never dry out and eventually rot.
Of course....I may be totally wrong. 😉
Regards,
Henry
Laissez le bon temps rouler !
30 minutes ago, popeye2sea said:
...tarring would just as effectively keep all the wet in and the cable would never dry out and eventually rot.
I would think Lees would have mentioned this.  Maybe someone else can check before I can get to my library..
Lavery goes into great detail about anchors and cables, but doesn't mention tarring..
He does say a 74 would have had 7, 22inch cables of 120 fathoms.  That would have been a lot of tar that would need to be replenished..
― Jimmy Buffett
Slow crawl:    Rattlesnake
In wood, damage from rot is associated with fresh water; often from rainwater leaking from the deck into internal structure.  Salt is generally regarded as a preservative of organic materials.  Later Nineteenth Century American shipbuilding practice included pouring salt into cavities between frames planking and ceiling as a preservative.
I therefore,  suspect that rot would not be a particular concern for anchor cables immersed in salt water, particularly if they could be sluiced off to remove marine growth as they came inboard.  Ships were fitted with mangers to direct water and debris from the cable  as it was hauled onboard.
A real concern might have been damage to cables stored onboard in the dank environment.  Rats might have also been a problem.  I have read that they would eat flax sails if given a chance.
Roger
Edited by Roger Pellett
it goes about like this:
(I guess there are also some pendants where it is important to keep the maximum strength so it does not break.
If a tarred rope is let's say may be about 1/3 less strength than un tarred rope... does that mean that they had to slightly increase the rope diameter of ... few ropes?)
