Update
started with the aft section belaying bank and the pump-spill.....
Nils
the holes for the belaying pins will be drilled the size later on
upper part of pump spill fastened to the post that also will take up the aft end of the bow sprit
arrangement of the spill on deck
Current builds
-Lightship Elbe 1
Completed
Update
Rudder arrangement....
Nils
the part of the rudder above the waterline will be painted white
the actualship is equipped with twin props
Current builds
-Lightship Elbe 1
Completed
Update
Stb side complete sheathed,  and tiller made
Nils
Current builds
-Lightship Elbe 1
Completed
Coming on nicely!
Will you leave the deck like that or still scrape? It looks rather glossy, actually. Using steel-wools also give a nice matt finish.
54 minutes ago, wefalck said:
Coming on nicely!
Thank you Eberhard,
and also for your tip to use steel-wool. Up to now the deck is only treated with  Clou Schnellschleifgrundierung...
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Allan,
am pleased you like the "nailed version" of the sheathing....
Nils
Current builds
-Lightship Elbe 1
Completed
Update
making the sheathing plates fom 0,1 mm thick copper foil .....
The stb. and port ones require a mirrored poncing. It takes about 25- 30 single plates per sheathing-row on the hull
Nils
poncing the foil stripes with a self made poncewheel
cutting the stripes off a multi panel pattern. I make about 25 -35 plates from 7 stripes at a time
flattening the stripes from the rear side by rolling over with a glas jar ( is simple and works well )
stripes after flattening. This will provide complete identical sheating plates 15 x 20 mm afterwards, cutting at the black lines
Current builds
-Lightship Elbe 1
Completed
Update
today the standplate (not stained yet) and the two pedestals are made.
the front pedestal gets a narrow spacer underneath in oder to set the hull waterline horizontal
Nils
the baseplate is made just like all my stands to date
the upper sheathing waterline is set up absolutely horizontal
the counter of the spindles is done with a upside down press in nut (longer threaded sleeve and a larger contact diameter compared with a regular M3 nut
Current builds
-Lightship Elbe 1
Completed
Looking solidlly done - deutsche Wertarbeit ;)
Why don't you use an ordinary nut and large washer ('Karosseriescheibe'). That would be easier to tighten than these press-in nuts.
Eberhard, thanks for your words
the reason for using the press-in nuts here is merely for the long thread section, whereby the regular M3 nut only has two or three windings in interlock with the spindle. I experienced it once that on the spindle the interlock area was damaged because the force was only unsufficiantly only on two or three windings and they gave way....
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, a standard M3 nut is 2.4 mm thick, which gives you about 5 threads for a pitch of 0.5 mm.
However, given the size of the model, I would feel more comfortable with M4 or even M5 …
Eberhard, right I would have preferred M4 in the beginning, but the keel was so narrow, so it would have turned out too thick, also considering both sides planking and sheathing
Now I have appr. 5,6 mm thickness at the keel, in scale that would be 286 mm on actual vessel keel, which looks quite realistic to me as there is no center-board to be integrated
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Mounting the pinrails that also take up the sleeves for the davits.
Mounting the side vertical bumper-ails for raising / lowering the boats
Mouting a short bumpkin through the upper bowpost at the bulwarks and making the bow sprit that will be fixed a bit offset to the bumpkin.
Trying out if I can possibly make the two boats. The boats are symetric front and aft, so I would only need to make one halfmodel to take a silicone matrix from that. If it works out I can cast  the raisin halves to make two boats from
Making a gig to taper the bow sprit as well as the top spars later on.
The total model length ( bow sprit to aft end of mainsail beam) will be 750 mm
Nils
 tapering
tapering simultaniously requires two machines in operatio
tapered bow sprit
preparing for making the (only 1 half) for the boats
On 4/5/2022 at 2:10 PM, wefalck said:
Yes, that’s a point. Somewhere between 25 and 30 cm thickness sounds about right for a vessel of that size.
Current builds
-Lightship Elbe 1
Completed
10 hours ago, Jim Lad said:
Looking good, Nils.
John
Many thanks John...
Nils
Current builds
-Lightship Elbe 1
Completed
Update
making the boats.....
I could`nt find suitable double-ender boats in the web, so I decided to make them myself. It would be a 130 mm long double-ended and clinkered little model itself.  I used ply and easy to shape Balsa wood. This will be the model for taking the silicone form from in which I intend to raisen-cast two symetrical halves and glue these together afterwards. The clinker is simulated with double laying strips of self adhesive aluminium tape
Nils
rough shaping the boats hull half
after final shaping and  sanding over
fitting the rail ( from brass profile)
clinkering
Thats the look...
the boats will turn out 130 mm long in scale 1:50
Current builds
-Lightship Elbe 1
Completed
I think you will have to cut away the foil from the stem-/stern-post ... normally the planks would fit into a rabbet there.
Are you sure that stem and stern were really symmetrical? Typically, in double-ended boats the dead-wood under the stem is cut away somewhat, while the stern-post sits more or less vertical on the keel. This allows to have the fingers for the rudder deeper down and also adds to the directional stability while rowing. On surfboats the stern-post dead-wood may be cut away, but not on these pilot-transfer boats - they often had to be rowed back to the pilot-schooner by one man only, when directional stability is even more important.
Eberhard,
please would you please send me a handscetch on my message box here, it would be understood better what you mean.
I intended to make a symetrical end, cast the parts, and then do the fine tuning individualy afterwards... (Rabbets, cutaways, etc)
The raisin is easy to trim
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, what I meant is that the stern-post may sit vertically on the keel - like on the schooner, rather than running in a curve into the keel. The end would be still pointed, but the stern-post more or less vertical.
This a possibility, one would need to verify this against images. I think there are paintings and photographs of the Elbe-pilotboats that show the rowing-boats in the davits.
Many thanks Eberhard, now its understood.
Shall overwork the sternpost on the castings
Nils
Current builds
-Lightship Elbe 1
Completed
Update
making the box containment for the silicone mold and casting the mold from semi soft silicone rubber
Nils
the box must be large enough to allow buffer rubber material all around.
I used car polish wax for covering the box inside and for the submerging section of the model fot better removal
I used up the leftover 2 component silicone I still had from making my boats for Kaiser Wilhelm der Grosse.
It was just enough silicone for this application ( to the last drop ! )
taking the halfmodel from the mold, all looks well so far
Current builds
-Lightship Elbe 1
Completed
Update
making the tubes for the anchor chain, chemical blackening of the brass anchor chain, casting the boat halves, two halves of the boat checking out the fit, and ready for glueing together, the cockpit - cover still needs to be cut out
Nils
the chain is transported over the appr. shaped chainwheel
port for the chain
this is the cast box for the silicone mold
this is the removeable heart for the boats inner shaping. The little distance chucks are only preliminary attached in order to determine the boats wallthickness
here everthing is ready for casting the two-component raisin into the waxed parts
this is the very first cast boathalf
the fake frame-ends (at inner bulwarks) are included within the casting
dryfit of two boathalves
Current builds
-Lightship Elbe 1
Completed
Looking at the anchor pump-spill above, the levers appear to be rather short - the men would need to lean over the spill and would not have a lot of fulcrum. I think the handles should be outside of the spill-heads so that the men can stand clear of them - or do you have images that show the handles to be so short?
Right Eberhard,
the reason is that I just did`nt want to make the lever beam my self. The one I`m using ist normaly forseen for a double bilge pump and also the largest I could find. So the crew members would have to arrange with the given circumstances like always in life...
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Making the oarlocks and painting the boats
Nils
the painting requores some touch-up
DSCI8528.thumb.JPG.b5aa98dee3cefffa5f31638d0243c511.JPGDSCI8530.thumb.JPG.500be853ba22a7ede33d82d16fd5d3db.JPG
Current builds
-Lightship Elbe 1
Completed
Update
the boats are now complete, allthough the oarlocks and a sample oar look a bit oversized
Nils
Current builds
-Lightship Elbe 1
Completed
Update
fitted a set of overworked oarlocks (thinner wire), also boat cradles, bell, and the first coat of white paint above the waterline. The bulwarks (in boat swing out area) are cut back a bit just like the real vessel. The upper handrails are still missing as well as the deck`s super structure like companionways, hatches, skylights, etc
Nils
the upper hull has a white-silk finish
Current builds
-Lightship Elbe 1
Completed
Update
today I`m doing the bulwarks handrail from bendable beech stripe 1,5 x 3,5 mm flat. The aft rounding is done with a bending gig in order to bend the strip over the flat side and a pot of boiling water.....
Nils
the front and mid sections are easy because of the slight bend only....
this gig keeps the strip down flat during bending the curve... for the aft rounding
here the strip is inserted into the gig
for smooth bending the strip was put into hot water for a few minutes
out comes a smooth rounding over the flat side of the strip. I`m very pleased with the result
fixing the rounding rail to the aft bulwark. It will be shafted to the mid section bulwarks
Current builds
-Lightship Elbe 1
Completed
