A brief introduction to this kit  ---
Unpacked and contents checked.
All complete and in very good order.
Ply sheets perfectly flat and undamaged,  All strip wood is of finest quality and straight as a die.
Fittings and brass sheets perfect.  Eight big sheets of plans.   Full size plans are important.
With my eyes measuring from reduced plans then scaling up or down is hard work.
Ordered necessary paint pots with kit plus, balsa sheets for stem and stern blocking.
Bought a building board from my local hardware shop.
Already have wood glue and cyano in stock from my last build.
Tanganyika strip supplied instead of lime so no extras to buy.
Have a copy of Marquardt's AOTS book and, James Lees Masting and Rigging in stock
also several logs (of excellent quality) on this forum
Noticed from other logs on this forum that there may be a problem with the width
of the mizzen channels but have found enough 2mm walnut sheet in my spares box
to cover this.  So all ready to go.
First is to build the jig,  then assemble the false keel and bulkheads and the false decking.
Working as a draughtsman for 53 years, 20 of these using AutoCad I much prefer
drawings rather than pictures so am really looking forward to working on this kit.
Photo's to follow.
Best regards,
Sam.
Hi, and thanks for visiting.
Bulkheads 7,  8,  9  and  10 dry fitted.
Also false deck to central lower area.
Bulkhead 7  --  chamfered to suit planking run.
8,  9  and  10 left square,  mid ships so won't need chamfering.
So far this kit is a dream to work on.  Everything fits.
Bulkheads were a perfect sliding fit onto false keel.
Slots in keel needed opening slightly.
It looks like the false deck won't need any work in this area .
Next is the other bulkheads and false decks.
Then forming pockets for the masts.
Won't need the jig until I start glueing the bulkheads.
Best regards,
Sam.
IMG_1533.thumb.jpeg.c826fcabeba53d6ce3a7adf1a4f87ed2.jpegIMG_1532.thumb.jpeg.36179f2c1ef7244077c899eef8e893b1.jpeg
Hi and, thanks for visiting.
Bulkheads and false decks glued to false keel.
Jig built.  This is a lot sturdier than it looks.
Nothing warped and all slotted together with
minimum work or trouble.
Rear deck was approx. 3mm too long.
According to posts on this forum this seems
to be a deliberate design feature
to give a better fit to stern plate.
Next step is balsa blocking to stem and stern.
Wouldn't like to attempt planking on this kit
without packing especially at the stem.
Best regards,
Sam.
IMG_1538.thumb.jpeg.a1a2b216e09ab30068f73557b450e925.jpegIMG_1551.thumb.jpeg.4c66699bebed6563098b93746ea1baa5.jpegIMG_1552.thumb.JPG.0919e219190215ec8e8e01aab0478870.JPG
Time to pull up a chair and watch the building evolution. Looks good.
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
Started first planking.
5 x 1.5  lime strip provided appears to be excellent quality.
Due to the thickness of the strip and, the very blunt bows
I decided to build a simple jig to preform the bend required.
Main body of the jig is 5mm thk balsa (because I had it in stock).
Used the remains of the decking ply sheet as a template.IMG_1567.thumb.jpeg.c6d4b18ce3a8df401880bf998d5a0d0a.jpegIMG_1568.thumb.jpeg.4a2b081d22d5f4295629cce9cc13e16f.jpegIMG_1569.thumb.jpeg.ef0eac59a85613f6d7ec2dbff3bec5a2.jpegIMG_1570.thumb.jpeg.8f54a1037e00b19183c3bec1f2efdc7c.jpeg
Used  5 x 5mm walnut for the stops and small clips to locate
and hold the strips whilst drying.
Strips were pre-soaked in an electric kettle but not boiled
for 20 minutes then placed in the jigs and the clips applied.
Put on one side to dry and set in shape.
Photo's of jig construction shown.
The lime strip is excellent quality and bent without splitting.
Best regards,
Sam.
First plank fitted to bulkheads.  Allowed to follow it's own line at bow.
Fitting slightly damp is easier than letting planks dry out fully.
Instructions say that this plank should be fitted un-tapered.
All other planks need tapering as required.
So far, so good.  Have a feeling that this hull will require
lots of stealers.
Best regards,
Sam.
IMG_1572.thumb.jpeg.5980f363be28bf56be0909ad930a877b.jpegIMG_1573.thumb.jpeg.8982280d9635d485eed7ce276c78e2f9.jpeg
Still working on first planking.
Planks above deck level at the stem look problematic to say the least.
Instructions say to use the bulkhead extensions as guides
then break them off before deck planking.
Tried this approach on a previous build and caused so much damage
I swore I would never do it again.
Photo's below show my method of replacing with spare bits
lightly superglued to the deck plus, a guide at the stem fixed with one screw.
Before finishing the planking I detached parts 114 and 115  (forward capping rails)
and dry fitted to check line of top edge of guides.
Being Caldercraft they fitted perfectly.
The bulkheads are from very good quality strong ply which makes
detaching the upstands difficult.
Also noticed a very generous supply of good quality strip for first planking.
On some kits in the past this hasn't always been the case.
Best regards,
Sam.
IMG_1580.thumb.jpeg.287130a19c47ff68000b98b9b9d8eb6c.jpegIMG_1581.thumb.jpeg.ca7b237c72dff47395db104a3714c8af.jpeg
Hi, and thanks for the likes.
First planking finished,  whitewashed and marked with bulkheads, waterline and main 'wale.
The top rail will be located to suit the second planking
and the bows will be trimmed to suit the first line of second planking.
The main wale will be located to suit the planking run.
Marking out is a guide only.
First planking was easier than expected but needed a lot of thought.
 Let's see how the second planking goes.
Next is to fit the wales and stern fascia and, to plank the counter.
The quality of the plans supplied has taken a lot of stress out of planking a bluff bow.
Regards,
Sam.
IMG_1602.thumb.jpeg.651ca423279b9f149fbe214f8cf30e8a.jpegIMG_1601.thumb.jpeg.dc30e7d21d0bcf1e4dbd84e7fa8a6f63.jpegIMG_1593.thumb.jpeg.4d7c8676ad776614bb771c58a0265d16.jpeg
Wales fitted, painted and varnished.
Used Admiralty Paints  Shark Black and
Winsor and Newton Artists Satin Varnish over.
Both one coat wonders and quick drying though
the varnish takes a couple of days to fully harden.
Was expecting trouble at the bows so used flexible beech strip.
Went OK.  Second planking next  ---  this will need thinking about.
Using 4 x 1mm tanganyika for this along with 6 and 7mm wide strip
for stealers etc.
The shear strake will be notched to suit the channels.  Easier now than later.
Regards,
Sam.
IMG_1606.thumb.jpeg.b0d54df4aa670ea570ba98221183454a.jpegIMG_1604.thumb.jpeg.047c2e6daf056107c818e9edaee47f9a.jpegIMG_1605.thumb.JPG.b5c6c4784958dbf01a5654f5ab7115c1.JPG
Starting on second planking above wale.
After a first measurement I think that towards the stern planks will need tapering
and towards the bow I will need to fit two or three stealers.
This build has a very busy hull so I will try to keep these towards the wale.
Photo below shows the first run cut.
Regards,
Sam.
In addition to the references you mention, are you using the contemporary drawings of Endeavour as well? There are 7 contemporary high definition deck and profile plans available for free on the Wiki Commons site on the eighth page.  The profile drawing clearly shows where the wales lie.
Have you studied the planking tutorial by David Antscherl in the Articles data base here at MSW and the four part video on how to properly plank a hull by Chuck Passaro?   They are well done and yield a hull that has been planked like a ship rather than what some kits think is proper planking. Typically the strakes taper to about half their full width at the bow and widen slightly at the stern.   Use the tick strip method and mark off the hull in several places or more along it's length to see the width of each strake at various points.  Every strake should end at the rabbet.
Allan
Edited by allanyed
Hi Alanyed and thanks for the input.
Unfortunately I have already located and fixed in position the wales
according to the profile drawing supplied with the kit. This seems to match the AOTS book
but gives what appears to be a different planking run requiring stealers.
I will check the contemporary drawings you reference but feel it's a little late to change course.
I have trawled through other logs on this forum and found an enormous amount of information
some of which is contradictory and some which is supplied by different kit manufacturers.
I feel that I need to pick a direction and stick with it.
Once again, thanks for the interest shown and have a good summer in Florida.
Regards,
Sam.
Definitely pick a route to follow and stick with it.  The only thought I can add is whatever route you follow, do not use any road the kit makers that produce Endeavour have mapped out as they are chock full of very deep pot holes.  Check every detail against sources based on contemporary information before securing anything from the kits in place.   Even with the wales in place, there is no reason you cannot mark out the hull with tick strips to be sure each strake of planking is shaped well before gluing in place.
The Wiki site is https://commons.wikimedia.org/wiki/Category:Ship_plans_of_the_Royal_Museums_Greenwich   Of the 3679 plans on the site, about 800, including Endeavour, are high resolution.
Allan
Sam,
You are welcome.  I have no idea why RMG cannot have that link taken down, but such is the case and we are lucky to have it.  I have downloaded virtually all the high res drawings as the low res plans can be found on the RMG Collections site.  I set up folders by rates and similar labels, then I have subfolders within each for each specific ship and each drawing for that ship in the subfolder.  Added contracts in a few cases as well and a couple low res plans if needed to complete a set.  MSW expressed an interest about a year ago to take this and set it up for all members in the articles data base as the set is over 40MB.  The way they want to do it, new information can be added as it becomes available.  Alas, everyone has other things going on so this project has been a lower priority so far.  Hint hint😀
Allan
Looking very good Sam, I have this kit in my stash, so following your progress with interest. 👍
Andrew
Completed (Kits):-
Thanks for the comments Andrew.
And thanks everyone for the likes.
There are some very good threads on this forum for Endeavour.
I have replaced the walnut second planking with Tanganyika I had in stock.
The walnut is very good quality but I prefer the replacement colour.
Everything else in the kit is high quality and will be used.
Not an easy build to plank but not as difficult as I expected.
Good luck with your build, I will keep an eye out for your log.
Best regards,
Sam.
Hi shipaholic and thanks for the comments.
I have been ploughing through your postings (all 19 pages)
of your 1:51 build since last November.
A real quality build with outstanding detail.
Am picking up a lot of tips and inspiration so thank you.
Best regards,
Sam.
I haven,t been back to see your progress for some time but coming along really nicely. Some great work on the planking there. Well done Sam!
Edited by DaveBaxt
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
Excellent progress Sam, what did you paint the bottom of your Endeavour with?  See you have gone for the historically correct way rather than the more often seen pure white.  Though I think the fresh tallow was a off/creamy colour when initially applied and darkened rapidly when exposed to the sea.
Andrew
Completed (Kits):-
Hi Andrew,
Thanks for visiting.
For colouring below the waterline I have used
Admiralty Paints  AP9119W  WOOD (WALNUT)  BROWN
an acrylic paint.
WWW.JOTIKA-LTD.COM
I get mine from Cornwall Model Boats  (other suppliers available).
They are just up the road from me and delivery is usually by return post.
Two coats have been applied but I think she needs another one.
According to one thread of research both Cook and Molyneux
record boot topping using pitch and brimstone
both ingredients of  "brown stuff".
Cook did suggest in his journal the new procedure of painting with white lead.
Admiralty order of 6th October 1771 suggests that this was acted upon.
Best regards,
Sam.
