My Norske Love kit came without scribed/pinted deck planking lines on the deck pieces.  Rather than draw them in, I intend to plank the decks (simply because I have a bundle of 111 X 6 mm strips).  6 mm is entirely too wide to use this lumber as is, so I need to cut them (rip lengthwise).  I will be happy with 3mm wide planks.  I cannot figure out a simple, accurate & efficient way to do the cutting and I'm hoping someone here will suggest something...anyone please?
Cheers!
Bill
Current build Andrea Gail (Billings)
Bill,
I knew I'd seen something about how to do planks.... see this post for a link: http://modelshipworld.com/index.php?/topic/2915-milling-planks-need-help-moved-by-moderator/?p=80856
You can get plank strippers where you pull the plank through the device and the adjustable blade will cut to the right size. They are quite handy
Regards, Scott
Completed builds:
Awaiting construction:
Maybe try using the plank stripper by doing several shallow cuts instead of a single cut through the full thickness, this should help prevent the blade from following the grain.
Ken
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
I always cut my planking from 3 or 4 inch wide sheet. If the planks are from a 1/32" thick sheet, I tape a brass bar 1/32" thick by 3/4" or 1" wide to my table, leaving the front edge of the brass without tape. I then use another brass bar on top, overlapping the first by as wide as I want the plank. Now I can slid the wood under the upper piece of brass until it rests against the lower piece of brass and I have an edge to run my blade against. With this setup I can cut as many planks as I need.
Bob
Current build:  SS_ Mariefred
Brian,
It should.  I usually don't cut planks from walnut or mahogany but I do use a straight edge.  With this setup you hold the wood against the stop underneath while you cut against the straight edge on top.  Should be the same.
Bob
  • 3 months later...
Thank you for the tip will try it with walnut.
Respectfully
Bob,
   That is an excellent way of making the strips, you don't waste any wood like if you did it a a table saw, and I don't see any problems with using other woods. You might have to cut more that one time but it should still work. just take your time when cutting harder woods. Taking time seems to be a down fall for a lot of us.Also a lot of us don't have that much time. So many sip and so little time is the problem. Thank you for the tip.
Wacko
Joe :D
Go MSW :) :)
I bet a good head knife would do an excellent job used with your guide and measure system. You run the head knife along your guide while applying as much pressure as needed, should end up with a clean cut, even in heavy woods at planking thicknesses.
jud
