Starting this build log well into my build, but better now then never.
I've completed the hull and placed most of the deck fittings.  There are several aspects of the hull that didn't go very well and much of that stems from breaking one of the bulwarks when trying to attach to the deck and planking the outside of the bulwarks before installation. I made a replacement piece for the bow section of the starboard bulwark that broke.
What I don't understand is what I did wrong that resulted in the bulwarks being curved inward as can be seen in the photos. The inward curve caused the bow stem, and keel pieces to not fit properly and the bulwark at the bow being about half the height above the deck then it should in the plans and also caused some misalignment of the top rail pieces. These compounding early build issues have been a constant source of frustration and disappointment but not nearly enough to turn me off this build or continuing with the next. In retrospect I should have remade the entire starboard bulwark and removed the port side and started over with some advice.
 For the most part, the rest of the build has gone well. I found the build log by Baltic Submariner for the same model which inspired me to make some wood pieces to replace some of the metal components.
Ken
Current Build
Fair American - Model Shipways
Completed Builds
18TH Century Merchantman Half Hull Planking Kit - NRG
San Juan Felucca - OcCre
HM Cutter Alert - 1777 - Vanguard
Need some thoughts on installing the shrouds. The references I search show British / American rigging with the shrouds wrapping around the mast above the crosstrees, but this felucca has no cross trees and only sketches without directions.
From the sketch, it would appear that the shrouds are seized directly to the mast just below the masthead but not sure if that interpretation is what is intended or proper. Is there a correct way to affix the shrouds to the mast where there are no crosstrees??
Ken
Ken
Current Build
Completed Builds
Thank you E Z Breeze. I'll press on and post a picture of the end result when I finish.
Ken
Ken
Current Build
Completed Builds
Ken, you are correct in the assumption of the shrouds being directly seized to the mast. E Z also hit the nail on the head as small boats have much lighter loads on the mast due to less sail.
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
Thanks to you both for sharing your insights. This ship does have shrouds on both sides which I imagine would make tacking quite a challenge to work the boom to the leeward side.
Ken
Ken
Current Build
Completed Builds
The metal small boats that came in the kit really detracted from the overall look so I took inspiration from several build logs and customized them a bit.  I used thick paper cut into 3mm wide strips to simulate planking, and added a rudder and tiller. The final bit was adding the oars made from modified tooth picks.
On to the bow sprit and anchors while I continue working on the standing rigging and setting up the blocks for the running rigging.
Ken
Ken
Current Build
Completed Builds
Hi Ken,
is the line on the davits holding your boat from the kit?
For the future, keep in mind the planking on the boats was similar to that on the ship, that is, the strakes were tapered and end at the rabbet.  For the oars, Steel gives dimensions of the parts of the sweeps and oars for various size boats that you may find interesting.
Breadth of boat
                               Oar    Handle  Loom  Body      Blade   Loom Square    Blade Broad   BladeThickmess    Diam
                                         Lengths        Inner  Outer    Inner Outer           of
Feet                          feet      ft. in.    ft.in     ft.in.          ft.in.      in.             in.       in.          in.       in.              in.
7-0                            20     0-10        6-0      6-10         6-4         4               3 1/8   6 1/8     2 7/8   7/8           1 ¾
6-0                            19     0-10        5-0      7-2           6-0         3 7/8           3        6           2 ¾    7/8            1 ¾
5-0                            18     0-10        4-0      7-6           5-8         3 7/8           3        6           2 ¾    7/8            1 ¾
4-6                            17     0-10        3-6      7-4           5-4         3 ¾            2 7/8   5          2 ¾    7/8           1 ½
4-0                            16     0-10        3-0      7-4           5-4         3 ¾            2 7/8   5          2 ¾    7/8           1 ½
Hi allanyed,
Yes, that is a boat from the kit after I modified it a bit.
Thank you for the info on proportions for oars for various size boats and you point about planking being similar between boats and the ship. I will definitely keep that in mind going forward.
Ken
Ken
Current Build
Completed Builds
Continued to progress on my felucca build. Hull is now complete with all deck fittings installed.  I modified the anchors with wooden stocks using the sketch Gregory posted in Dave E. Rattlesnake build and installed.  I find these types of sketches and tables to be most helpful to get close to proper dimensions like for the stocks.
Ken
Ken
Current Build
Completed Builds
From the previous picture you can also see that I've installed the bow sprit.  My early problem with the bulwarks came up again as I worked on the bow sprit.  In addition to needing more height for hole, I needed to try and make the bow look more presentable. You can see the changes in relation to what it previously looked like as shown in the first picture. I recognize that I am straying away historical accuracy, but other than tearing down the entire build and starting over, I really had no choice.
Hopefully, the bulwark issue won't raise its ugly head again, and there will be no more need to stray from the build plans as I move on to the masts and rigging.
Ken
Ken
Current Build
Completed Builds
Good progress this week on my build and almost ready to step the masts, bend on sails and install the yards and mizzen boom,  Masts and yards are shaped with blocks and parrels fitted, and working on the lower blocks for the shrouds.  This rig is quite different in that there are no deadeyes and the shrouds are set for quick disconnect via a pin similar to a  belaying pin.
I am quite excited about where I am with this first build, and the Commander in Chief is chuckling at me every time I go show her my progress.  Overall, I'm pleased with the results, albeit far from the quality of workmanship I see from so many other build logs, but I plan to get there at some point. I've learned so much thus far in the build and am keeping a running list of lessons learned that I'll post when the San Juan is complete.
Ken
Ken
Current Build
Completed Builds
My San Juan is moving past the sheer hull with the mizzen mast stepped, yard installed and spanker boom set.  Connecting the yard with the parrel just seems odd as it just wraps around the mast and gets tied in place.  I understand the mechanics and looked hard and the build log from Baltic-submariner and a you tube video, but not sure I have it correctly connected to the yard lift.  I took 2- turns around the mizzen and tied the perrel off with the lifting line tied to where the parrel and mast meet. It's functional, but just seems wrong.
I am following the advice and sequencing in Frank Mastini's Ship Modeling Simplified and built the mast off to the side on a block of wood. I can certainly see why he says to not build the mast after stepping it in place. It would have been very difficult to file lines, blocks and the parrel any other way and would likely have resulted in breaking something.
Strapping the blocks took longer that I anticipated an I still need to connect the spanker sheets,  but all said I think I made good progress this weekend.
Ken
Ken
Current Build
Completed Builds
Received the rope I needed and shifted back to this build from the half-hull planking kit.  I realized after lashing the top of the mizzen shrouds to the mast head that I neglected the beckets in the blocks. Fortunately I was able to resolve that issue without having to start over with new shroud lines and re-strapping the blocks. With the minor setback behind me, I was able to complete rigging the remainder of the mizzen mast and install the sail.
Admittedly, I am learning a lot from this first build but I find this kit leaves a lot to be desired. Plans have many lines just tied to the pin rail (no belaying pins at all), up to 3 running lines connecting to the same deck cleat, and sail sheets tied off to the cleats on the aft boat boom. Additionally, the number of single blocks was not sufficient for all the places needed (I've had to make 3 so far and will need 1 more), and an overage of double blocks.
I will still display it with pride as my first build and as a reminder of the many lessons learned - both good and otherwise - I've discovered during the process.
Ken
Current Build
Completed Builds
Hi Ken,
VERY neat work!
One comment/question, hope that is OK.  It may be me or the photos are not clear, but your blocks look to be mostly upside down.
Allan
Thanks for the feedback Allen.  I was so pleased that I had found a good method, but you are correct, they are all upside down. Another lesson learned.
Ken
Current Build
Completed Builds
I finished!!! So excited to complete my first build despite all its flaws.
Not including technique and methods, here are some quick lessons I learned during this build:
  • Read through the complete build plan carefully before starting
  • Build sequence may need to change - look for sequences that could cause difficulty
  • Mistakes don't get better with age, they tend to compound
  • If a part breaks, stop, tear it down and rebuild a new part
  • When in stuck or in doubt, ask the question on the build log. There is always someone (and usually several) experienced modelers willing to throw a lifeline.
Thanks to all who responded to my questions, periodically monitored my build, and commented or liked aspects of my build during this journey.
Going to order my next kit now!!!
Ken
Current Build
Completed Builds
Thanks Paul and Chris.
Ken
Current Build
Completed Builds
  • 7 months later...
Ken, a little late here, but congratulations on finishing the San Juan last summer.  I am in the midst of building her currently as my maiden venture into modelling.
I am curious about two things here:
  • Did you do any staining/dying/painting of the San Juan?  I am pondering trying to add a little color to the deck, but this being my first build I'm fairly unfamiliar with the process of applying any sort of finish.  Curious if you did any sort of finishing to the Sapele second plank layer on the hull as well.
  • Did you add the keel/stem/stern post before or after you finished planking the hull?  I did them after, and I am wondering if I could have achieved a more exact and flush plank layer if I had attached the keel, stem, and stern post prior to the planks.
Cheers,
Will
Edited by PostCaptainAubrey
-Will
Felucca San Juan by OcCre
  • 2 months later...
Hi Will. Thanks for your post. Sorry my reply is a bit late but I've been away from the site for a while. As to finish, I used a polyurethane satin varnish on the hull, deck and all deck structures and fittings.  I used a small flat brush to apply. I think the varnish was sufficient to bring out a richer color in the wood.
Like you, I added the keel, stem and sternpost after planking per the instructions. I believe the end result would have been better if I had installed them before planking.
I found the San Juan an enjoyable first build and learned a ton during the build which got me motivated to continue with additional builds.
Ken
Ken
Current Build
Completed Builds
