I think you’ve done an excellent job,  Commodore!  The kit designer may have allowed a bit more space for the gains. You did so good you gained timber:-)
And the outer hull is finished for the time being. Attached the skeg and the bilge keels. I had a hard time deciding where to place the keels in relation to the skeg, since the instructions left that a little ambiguous (stating just "place as shown"), and after some fiddling around decided on an overlap of 6 scale inches (actual measure 1/2"). Now that this section is done, I'll be building the daggerboard case and installing the frames.
In Shipyard:
1:12 Norwegian Sailing Pram
Completed Builds:
1:24 Lowel Grand Banks Dory
Looks really sharp, Commodore! Nice hull work!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Constructed the daggerboard trunk and installed it. The slot for it was about a 1/16 of an inch longer than the pegs, so I made the decision to shift it forward in the slot rather than try to finagle it to be in the middle, banking on 1/32" not mattering all that much either direction. I then filled in the 1/16" gap with wood putty.
As an aside, wood putty is my best friend in this build. I applied some at the stern transom where the planks were a little gapped away. Next up is ticking the keel where the frames go.
I read ahead that the model needs to be 3 3/4" at the widest point, and a scale inch or so more will make trouble with the thwarts. My model is currently 3 5/8" wide, but I'll check again with the frame installed. I don't see it being an issue, since I can make the thwarts smaller, but can't enlarge them.
In Shipyard:
Completed Builds:
I thought I had marked to follow this one.  I have now.
Nice job so far.  Looking forward to watching the build.
Robert Chenoweth
In the research department:
Nothing at this time.
Before I put the thwart supports in, I wanted to jump ahead slightly and work on transoms, since they've been on my mind a fair bit. The bow transom went as well as I expected (that is to say, quite), but I'm hesitant on the stern. As stated earlier in my log, the planks at the stern rose above the line provided where the stern transom would be shaped by around 1/8". Now, my thought is to raise the line by that much, which if my math is correct would equate to having an extra 1.5" of transom if this were full scale, which on the real thing wouldn't matter too much I don't think, but I'm curious how it would look on the model.
In any event, I'd welcome any thoughts on how yinz think this idea will work, if it will affect the rudder or anything like that, etc. before I make any cuts and shaping to the stern.
In Shipyard:
Completed Builds:
Hey Commodore, I think it will work fine. I’ve had a lot worse issues. Besides, all of us that are keeping up with your build, will be be the only ones that even know:-)
Here is a good shot of how high the rudder fits, you'll have more trouble building the arm than you will worrying about if it will clear the transom haha. Its very fragile to fabricate.
Still need to put the soleboard cleats on, but things are coming along. I had a little bit of trouble with over-beveling some of the thwart frames, and again, wood putty is my best friend.
If you've been following this build, you'll know I had worries about the transom. For a freehand sketch and a LOT of sanding with dull files, I think I did pretty alright. I might see about adjusting the skeg at some point. It's off just slightly enough to bug me. I know, I know, looks right is right, but I think I can make it look better.
In Shipyard:
Completed Builds:
Looking good, Commodore!  I was hoping you'd be satisfied with the transom after we all gave you the "it'll be ok" encouragement.  In this hobby, like many other things in our lives, we become our own toughest critics and naysayers.  Carry on!
Gregg
Lot of stuff in one here. I got the gudgeon cut and attached, I unglued and reglued the skeg to make it more center, I lowered thwart frames B slightly, and I attached the floorboard cleats. For the measurements for those, I started with two each of 2 7/8", 2 3/4", and 1 7/16" and filed down to size from there.
I had hoped to the slots cut for the backstays before I have to set the model down for a bit (long story short, I'll be on the tall ship LYNX for a month and won't be around to work on the pram), but I didn't have the saw blade. I'm hoping I can finish the oarlock pads, and maybe the rub rail. We shall see.
In Shipyard:
Completed Builds:
  • 5 weeks later...
Sorry about the hiatus, I've been on the tall ship LYNX for the past month and just got home yesterday. So, back to work. I got the slots for the stay plates cut, and fit the fore thwart. I like to think I learned a trick or two from the dory build, because I wasn't entirely happy with how those turned out, but I'm MUCH more please with this one.
In Shipyard:
Completed Builds:
Took a while, but I got the rest of the thwarts fitted. I had to request some replacement parts from Model Expo (the knees were miscut) which took a little time. I also made a cover for the daggerboard case, which turned out rather well. Now that the thwarts are fitted, I can take them off and paint the hull. I'm doing dull red for the interior and warm white for the exterior. I also picked up some metallic brass to paint the bottom of the bilge keels, mimicking weather strips.
In Shipyard:
Completed Builds:
The amount of detail in your beveling and shaping of such small, thin pieces of wood to make everything fit together so perfectly is quite impressive.
  - Eric
  • 3 months later...
Apologies for the LONG delay in updating, I've been in California for the past two months.
I got the interior painted, just need to do some touch ups on the hull. I also used some brass paint on the bottom of the skeg fin and bilge keels to mimic weather strips.
Edited by CommodoreErie
In Shipyard:
Completed Builds:
The boards look great!  Do they have a stain on them now, or what are you planning?
Gregg
I was going to leave them unfinished as is. I kind of like the look of them that way. Obviously if I was going full scale, I'd varnish them or something, but this works for the model.
In Shipyard:
Completed Builds:
I'm still working on the sole boards, but a miscalculation led to some screw ups, and now I'm waiting on replacement parts. In the meantime, I'm moving onto some brass fittings.
Currently I have the anchor point for the forestay attached. Took me four tries because I kept dropping the pipe cutoff and losing it in the carpet, so I'm happy there's so much extra. These pieces are held in place using CA glue as opposed to wood glue. Works pretty well.
Semi-related pro tip, if you need to polish brass but don't have the right chemicals for it, toothpaste works in a pinch.
In Shipyard:
Completed Builds:
I ended up changing out the nails that were supplied with the kit, since they're a bit too large (at least to my eye). Fortunately, I had a number of smaller brass nails from a previous failed kit, so I can use those now. They work pretty well.
First picture is the backstay plate secured with the supplied nails, second is secured with the replacement pins. These work out great for the oarlock pads too.
In Shipyard:
Completed Builds:
