Next step is to attach the lifts. They start of course at the yardarm, go through a block in the cap, and terminate to a single becket block.There were two difficult steps which took about 2 hrs. One, getting a line through the little blocks under the fife rail. (see post#22) Second was to align the lifts so the yard would be perpendicular to the mast.
8 hours ago, MrBlueJacket said:
Upper topsail yard prepped and ready for its sail.
Hi Nic, could you share a few thoughts on how to get the foot ropes to lay so easy?  They look just right….
Thanks
So the sad saga of the jib sails......
First attempt to use 2mm split rings was a disaster, they ripped out of the sails trying to put them on the stays.
Second attempt to tie them to the stays also ripped out.
Now I just made a third set of sails, I'm going to tie them BEFORE putting them on the stays, and to make the attachment stronger, I will put just a tiny drop of CA on the knot. Wish me luck!
