20230703_212659.thumb.jpg.eff140d16f938b210f21d12cb9769c2b.jpgBonjour,
The Granado is my second wooden ship build these year.  This follows the ship Endurance which you can follow the link to in the MSW gallery.
Before to start I learned many things with the forum. Thank You Timmo, Joe, Kevin, Brian, Vane...
I was a little bit disappointed when I opened the box because 3 sheets missing. Thanks to Glenn (Cornwall) the problem was rapidly solve.
Like everybody the fitted of the gunport pattern is not easy. At the end Ithe gunport cutouts of each pattern (port and starboard) were not fully aligned (1-2mm) !
François
________________
Completed :
Endurance (log - Gallery)(OcCre), Granado 1756 - HM Bomb vessel - JoTiKa/Caldercraft - 1:64
Good luck on your journey,  with the names you have mentioned  you are in good hands. Looking forward to seeing your log.    :cheers:
Start so you can Finish !!
Finished:         The Sea of Galilee Boat-Scott Miller-1:20 ,   Amati } Hannah Ship in a Bottle:Santa Maria : LA  Pinta : La Nana : The Mayflower : Viking Ship Drakkar  The King Of the Mississippi  Artesania Latina  1:80
 Current Build: Royal Yacht, Duchess of Kingston-Vanguard Models :)
Hi,
First planking completed. 2 stealers at the stern, rabbet for the stem. 1 filler block for the stern and of course hull plank tapering. a good training before the second planking.
Next step the Wale !
François
________________
Completed :
Hi,
The whale and the second planking from the wale to the false keel is finished.
The second planking is laid using 1x4 mm walnut. The color of the walnut is very heterogenous. I used the darker for the bottom.
I did 3 dropstrakes close to the sternpost.
Next step the upper gun deck and may be the sternpost and the stern counter even it should be to a later stage according to the instructions. For the white painting I think that is too early.
François
________________
Completed :
Hello
Mortars housing and bed done
Planking of the upper deck
Fit the inner bulwark pattern
Liningthe gunports without Lids
next step completion of the second planking...
Edited by Jorez de Saint Nazaire
François
________________
Completed :
Hello Gentlemen,
Completion of the second planking
Lining the gunports with lids
Inner bulwark spirketting
inner bulwark sheer rail
Upper gun deck grating, hatches,coamings and spanshackles
Fitting the forecastle
Planking the forecastle
The quality of the kit is very good
François
________________
Completed :
Francois,
I am most impressed.  All of that work looks G R E A T!  You are moving right along.  I like how you rigged the bowchasers, etc.  Keep up the good work my good man!!!!!!!!!!!!!!!
Best regards, and yo ho ho,
BT
PS: it is a good kit, I agree!
Thank you Brian,
it is good to share the same project you in USA and me in France. The net is magic.
Like you, may be, I will not paint the hull in white.
Next step for me the stern Fascia !
Have a nice day
François
________________
Completed :
I agree, the net is an amazing help for communities like model ship builders.  I'd be lost without it, and my boat building efforts would look much more pathetic!  I look forward to seeing your work with the stern fascia, bending it and getting it in the right place, etc.  I am considering whether I want to paint the hull on the Sphinx now that I am making some progress on it, but I have a long way to go before I really need to worry about that part.  I'll be getting back to the HMS Granado in a few weeks, and I will make sure to send some pictures of the modest progress I have made as of late.
Hello,
Stern fascia and stern counter doned and also the famous quaterdeck bulkhead.
My friends suggest to paint the bulkhead in red instead of the french blue and to paint the decal in gold.
Quaterdeck fitted and planked with the grating, The quaterdeck bulwarks is finish and the capping rails in progress.
François
________________
Completed :
Nicely done!!!  I really like your approach with the decals too!!!  I wish I had thought of that…
Hello,
During holidays I did the rudder ( I'm not so happy of the result, the rudder pintle straps and the hull gudgeon straps are not fully in line with the AOTS), deck guns and carriage (without the rigging I will do it later) and I start the windlass with belfry (nice piece from Jotika).
As you notice I will not paint the hull in white.
May be my last post before the new year.
Ami modéliste je vous souhaite un excellent réveillon !
29decembre2023(4).thumb.jpg.d1e298b2c41de2586c94fde659f39a7a.jpg29decembre2023(1).thumb.jpg.66a1448abc771101415a6ee2efe9b4ea.jpg28decembre2023(3).thumb.jpg.cc0412ea5d953d3ba2aa523aa963894b.jpg
François
________________
Completed :
Well, I've made some nice progress since the last update, and am just now getting caught up with the photos.
  • The windlass and the belfry
  • Galley flue painted and installed.
  • Quarterdeck rail installed with the finger and thumb timberheads and the main brace sheave block
  • Pumps fitted ans painted (pumps close to the mizzen mast moved forward because it was to close the quaterdeck bulkhead)
  • Jeer bitts & main sail topsail sheet bitts fitted ans painted in red
  • ladders main deck to quarterdeck and main deck to forecastle fitted
François
________________
Completed :
That is looking veeeerrrrryyyyyy nice Francois!  Great work on your Granado!!!  Keep up the good work and the updates, it is inspirational to see your work as it progresses.
Cheers,
Brian
Hello,
Fitted the anchor lining and fenders.
Fitted the side steps (doing it myself).
Fitted the tiller and tiller housing.05fevrier2024(1).thumb.jpg.1b30a7c012ac23919b6e184154c1e0cf.jpg
Starting the rigging of the main deck gun.
Fitted the hawse hole bolster (added a piece of tin to the hole).
François
________________
Completed :
Thank you Brian,
 For the rigging, it was inspired by a the book of David Antscherl. I will not fit the training tackle. I will not coil the rope like a "fromage". It was not possible to used tackle hooks (too small!).
Have a nice day
François
________________
Completed :
Hello,
Soon, the mast and the rigging will be done. It's already been 8 months! This kit is great.
I'm currently assembling the channels, chain plates and deadeyes  I'll likely wait until the shrouds are fitted to ensure the chainplates are secured to the hull at the correct angle.
François
________________
Completed :
Hello gentlemen,
Being worked on the bowsprit. I might sand the cleats down a bit. Your comments are always welcome!
Have a nice day
François
________________
Completed :
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
