HMS Sphinx 1775 by rvchima - Vanguard Models - 1:64 - 20 Gun Sixth Rate Frigate
Outside of the Hull (Finally) Complete
The rudder, displacement numerals, and random reinforcing plates are now attached. Rudder.thumb.jpg.058444b6ee2b3487337432997b504314.jpg
The rudder was hard because of about 120 nails holding the gudgeons and pintles. Those parts are non-functional - the rudder is actually held in place by 5 PE pins. A while ago I mentioned that my rudder wouldn't fit past the rudder post so I removed 1/4" at the top. Now the top pin has nowhere to attach. And with the pins the rudder was now a few mm wider and wouldn't tip in place. I had to use my trusty rotary tool to enlarge the hole in the hull, which is what I should have done in the first place.
I glued the displacement numerals with CA. The plans showed the starboard side so I did that first using a cutout copy of the plans for placement. For the port side I made a mirror image of the pattern with Photoshop and started gluing. After a while I realized that Roman numerals look the same forwards and backwards, but XI is not the same as IX. So I had to remove and reverse a few numerals. That removed the patina, which turns out to be fairly delicate. I touched it up with random green and black acrylic.
When I attached the copper plates I covered up the holes for the horseshoe and keel plates. I laid the paper cutouts in place, poked a pin through a marked hole, and hit the corresponding hole through the copper on the first try. Amazing!
Link to comment
Share on other sites
8 hours ago, Thukydides said:
She is looking good, I like the patina, very visually striking.
Thank you Thukydides. The patina is more intense than I ever imagined but I like it. I was hoping for a visually striking model (even if not quite historically accurate) and it is certainly turning out that way.
By the way, do you have another name besides Thukydides?
Two Ladders - Never to Be Seen Again
Chain Pumps and Supports
Link to comment
Interview with Chris Watton in Nautical Research Journal
If you haven't seen it already, there is a fascinating interview with @chris watton, designer of the Sphinx kit, in the latest issue of Nautical Research Journal. When I was looking for a new project I was debating between the Diana by Caldercraft and the HMS Fly by Amati. Moderator @ccoyle told me that I had a good eye because both models were designed by Chris Watton, and suggested that I consider the Sphinx. After reading the article I realize that I could have chosen any number of kits and that Chris would probably have designed most of them.
The only thing missing from the article is a photo of Chris' private collection. My house is getting crowded. Chris' house must be a museum.
Link to comment
I have very few completed models in my house, no room! All the models I did for other companies are with them. I only have a few fully completed models here, Alert, Speedy, Trial, Adder and Sherbourne, and then some of hull only for Duchess, Fifie and Zulu, and then only three prototope hulls (what I used to check designs) for Indy, Sphinx and the re worked Speedy.
Vanguard Models on Facebook
Link to comment
Chain Pumps, Hand Pumps, Grates and Finally the Stove
This part of the build is quite enjoyable. Each little component adds something interesting to the model. I built the stove almost two months ago and finally got to install it, and to jump ahead three pages in the manual past those instructions.
deck02.jpg.62f297f2c6c854c0055ab6acec8b4cca.jpgdeck03.jpg.0a177094a3a623a347743505dafd00a0.jpg
Link to comment
Eclipse
We had a solar eclipse today, 87 percent coverage where I live but only briefly visible through the clouds. I managed to get one decent photo with my old Celestron 90mm  spotting scope with a solar filter and an iPhone holder.
Link to comment
A New Base
The outrageous patina on my copper hull needed an equally outrageous base. I made one out of a light cherry with a Bubinga veneer, finished with Watco natural oil and several coats of Minwax wipe-on polyurethane. I have been ordering brass name plates for all my models from a vendor on Amazon. The temporary base will go back on while I am working.
I have just started to rig the breech ropes for the cannons. @Thukydides posted a brilliant description of a jig for rigging the cannons off the model here. However, the instructions for the Sphinx had me install the eyebolts around the gunports about 20 pages ago, so I will have to do that rigging in place.
Edited by rvchima
Link to comment
You should still do them off model. Just you are limited by the fact that you have to run the ropes through the rings on the guns. I did some posta on my method in my alert log.
I like the base, she is looking nice.
Link to comment
Breech Ropes
As suggested, I am rigging the breech ropes to the cannons off the model. I just use a single knot under the barrel with a spot of CA.
Then I glue the cannon to the deck.
The ends of the breech ropes must go through the eyebolts and get tied with much thinner thread using a single clove hitch. It is quite difficult to tie a clove hitch in that tight space, but it is MUCH easier to tie a clove hitch in your hands by overlapping two simple loops. There is an excellent animation of the procedure here. I hold the clove hitch with an electronics test hook clip, then put the breech line through the clove hitch, through the eyebolt, and back through the clove hitch. I grab both ends of the breech line with another test clip (red.)
So now I have a clove hitch around the breech line as desired. I release the yellow clip, snug up the clove hitch, add another single knot and a spot of CA for safety, release the red hook, and trim the ends. Fairly painless.
Link to comment
Link to comment
Quarterdeck Beams Installed - 308 Hours, 122 Days
This was another satisfying task. I added the optional hanging knee braces below the beams, sanded most of the laser char, and finished all the pear wood with Watco oil stain. Yes, I know most of this won't be seen, but the pear wood is just so pretty that I can't resist.
Quarterdeckbeams02.jpg.0884dc18219c34d81d354a934826659b.jpgQuarterdeckbeams03.jpg.5cdc97a062131308168c93c649997e5d.jpgQuarterdeckbeams04.jpg.53708203dcaa16da0389dc2ea6bd48fa.jpg
Link to comment
Forecastle Beams Installed
My quarterdeck beams all ended up about 2mm too long and had to be trimmed on each end to fit. I did build the hull with the recommended jigs in place so I don't know why the parts were off. The forecastle beams dropped into place perfectly. I really hate to cover this all up.
Link to comment
Upper Decks, Railings, Cathead, Binnacle, and Drumhead Capstan
The fore and aft upper decks and railings are all complete. The aft deck took a little shaping but the forward deck dropped right into place. As before, I stained the decks with Minwax Golden Oak. The belfry, stove chimney, and some belaying pin racks are also done.
deck-fore02.jpg.b08c6d0f74eabef7bb7be9f9eff57777.jpgdeck-aft.jpg.23cb0b7daf124663279709abb348e784.jpg
The stanchions for the quarterdeck railings are flat and need to be sanded round. I chucked them in a rotary tool and hit them with sandpaper wrapped around a dowel and taped to a stick.
Here's a view of that railing with the drum head capstan behind it and some more ladders nearby.
A lot of parts in this kit are PE brass that are typically cast metal or wood in other kits - eyebolts, belaying pins, etc. I had my doubts about them at first, but frankly they look just fine. However the ship's wheel is three pieces of PE glued up and it looks pretty flat. I considered buying a better wheel but would have had to resize the drum to make it fit, so I stuck with the PE. The binnacle is very nice.
Catheads - from the manual: "The holes in the bulwark are deliberately left smaller than required for alignment and part integrity when assembling. You will now need to open these up to fit the catheads. Use small files and a sharp blade to open these up to size." Easier said than done. I spent a couple of hours on each side filing those slots to within a hair of the railing and deck before those pieces would fit.
Link to comment
You can give the wheel a few coats of spray primer, white or red oxide. This does help round off the edges. Wooden wheels are always way too thick and out of scale for 64th, metal ones almost as bad, and 3-d printed versions too fragile. (in my experience, at least - same applies to belaying pins)
Link to comment
Thanks Chris. I tried to paint the wheel to look like wood and left the PE rims and hubs blackened. A better wood color would have helped.
Link to comment
Boat Beams
The manual says that if the rear beam hits the chain pump handle you can cut a little notch in the beam. Mine hit way too much for that so I gave it a good twist. It would never go around but no one will be able to tell. The handles definitely should be smaller.
Link to comment
Proxxon Sander (my favorite tool for removing laser char)
Ever wonder what's inside a Proxxon oscillating sander? Well mine started running erratically and making funny noises a few days ago, and it's only 7-8 years old! Can you believe it? So I took it apart (typical engineer). There's a switch, small permanent magnet motor, fan, eccentric, a big, heavy weight, and a plastic arm that oscillates the head back and forth. I cleaned everything out using my airbrush as a blower, added a drop of oil on each side of the motor and some graphite on the other parts. It should be good for another 8 years.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
