I started another project, the Model Shipways Grand Banks Dory.  There are many build logs with kit pictures, so I won’t include here.  I’m planning on replacing all the basswood anyways.
I usually have two projects (wooden ship and plastic airplane) going, but for a bunch of reasons, thought I should try doing two ship models at the same time.
Rationale:
·         I got a really good deal on it at a club auction
·         I’ve wanted to try one of David Antscherl’s kits
·         I think I have my jointer and bandsaw finally tuned right, and wanted to try milling some wood
·         I’ve found working with laser cut pieces on the longboat a little frustrating.  I’m sure I will get better at it with some more practice, but wanted to get a sense of the comparison between cutting the parts out myself vs cleaning char off laser cut pieces.
·         I want to build with boxwood and some contrasting wood, and wanted to see how well patterns made from scanned laser cut sheets would work.  This was particularly important on this model as the plans in the instruction book don’t include all the parts.
·         Main reason: I’m planning on starting a fully framed Echo, but want another project going so I don’t try working on Echo when tired or distracted.  This seemed a good opportunity to pilot building two ship models at the same time.  If it isn’t going to work for two fairly simple kits (longboat and Dory), I shouldn’t try it with Echo.
So far, so good.  I started with the stand as a test for the jointer and bandsaw.  The wood is a piece of pao ferro that I had on my shelf.  Very happy with both tools. The bandsaw got knocked out of alignment during the house move a few years ago, and is finally dialed back in.  The jointer was never fully adjusted and is finally working the way it should.
Scanning the basswood laser cut sheets has also worked well.  The burn marks are thin enough and in the right place to get good patterns.  For the first few pieces (hull bottom, stem, transom, stern knee) cutting the parts out has been very straightforward and taken less time than cleaning char.  For some parts like the longboat frames this would not be true.
I’ve also been making some progress on the other two projects and will update the logs soon.
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Following along.
Your decision to use different wood illustrates that even a simple "beginner's kit' can provide challenges and avenues for the more experienced modeler.
I look forward to this build.  You've got a good start and a nice plan for the project.
Edited by robert952
correct typo
Robert Chenoweth
In the research department:
Nothing at this time.
Robert - many thanks!  I have a special talent for turning simple things into challenges.
Helge - thanks for following.  I looked at your build, which looks really interesting.  I hadn't realized that Dorys were rigged for sail.  I plan on building according to the model shipways plans (or at least to scans of the kit parts) so will not be rigging the model.
I've made a little progress, adding the stem and stern.  I've started cutting the frames and crosspieces for the building jig.IMG_6341(1).thumb.JPG.18761bddc28302dd823d1d8a85fedcf1.JPG
Looks like a great start! I'm very interested in seeing how it turns out with the boxwood/contrasting wood hull.
I spent some time travelling and work got busy, but I've been cutting out and sanding pieces.  I made the jig support pieces in basswood.  They are thick enough that I think they will support the sanding and bending even thought the boxwood frames and planking may exert more force than the kit basswood during the sanding and gluing.  I made new parts and didn't use the kit ones as it looks like these get sacrificed when the model is cut from the jig and I wanted to leave the original kit buildable.
The frames  are cut out, glued together, installed, and faired.  I debonded and reglued the sternpost again after the picture was taken.  When I dryfit the garboard strake, it was a little too short. I realized I had glued the sternpost a little too far out.  I'm not using the kit parts, and without the laser marked guides, didn't get the post in the right place the first time.  After regluing and refairing, it looks like the planks will fit correctly.  I tried brushing water on the hull bottom as per the instructions.   It looks like it works great on the kit wood, but not the boxwood I'm using.  I didn't get an adequate bend, and there were some water stain marks (should have taken a picture, but didn't) on the other side of the wood at the margin of where the water soaked into the wood.  I was able to sand most of the stain away.  I got an adequate bend from fully soaking the wood (fortunately did not weaken the glue joints) and didn't have a problem with staining.
IMG_6377.thumb.JPG.4e92288ebf774bfc3498882d1044d86d.JPGIMG_6384.thumb.JPG.78c9a465f7ce307c210837bc7d29aa46.JPG
Druxey - thanks!  I think boxwood is worth the extra effort in terms of how it looks, especially if leaving unstained or painted.  I've been trying the techniques in the instructions to see which ones might work with it.  Brushing the water on one side was intriguing.  I haven't had any problems with clamps or rubber bands indenting the wood, even when wet.  For the garboard, I'm soaking the entire piece, which was working great until I knocked the sternpost off.  Work on hold until the glue dries.
  • 2 months later...
I'm doing a restart on this.  I finished the planking and when I took the hull out of the building board realized I had a little asymmetry.  I could probably have debonded and reattached the planks, but cumulatively between the waterstains on the bottom, a couple of pieces that were a lot different color than the other planks, and a few other things I wasn't happy with, it was time for a redo.  The beauty of scratchbuilding is that it doesn't feel like a big deal.  Over the weekend I milled the wood and cut the parts to shape.  I'm travelling, but next weekend will sand everything and begin assembling.  Having done this once, I don't think the redo will take anywhere near as long, and the end result will be a lot better.  Will start posting pictures again when I get back to where I left off.
Edited by davec
  • 3 months later...
I picked this up again.  I've redone the frames and started planking.  I had some visible glue spots, but they seem to sand away with 320 paper, so I think this will come out ok with a clear finish instead of paint.
Somewhere along the way I must have done something a little off because the sheer plank was about 1 mm short.  No pictures yet, but I debonded the too short planks and cut slightly longer ones.  Will post some more pictures once I bend and install the new planks.
Back in business - shear planks replaced.  I've been afraid to look at how much glue I will need to clean up on the inside, but the outside cleaned up well enough that I think I can use a clear finish.  I'm trying to decide between swiss pear, cherry, and natural pear for the contrasting wood.  I really like swiss pear, but am thinking of going with one of the other woods just so it looks different from my other models.
IMG_6766.thumb.JPEG.08c97144a4c0c4fa615d4ec8aea3296b.JPEGIMG_6765.thumb.JPEG.234b6a0c339ba08eaed382cdff93bf18.JPEG
Edited by davec
A little more work done.  I've removed the hull from the building jig, and added the false stem, side cleats, and seat risers.  I've also cut out the bands, milled some 1/16" square stock for the gunwales, and sharpened my chisels in preparation for trimming the frames for the gunwales.
IMG_6771.thumb.JPEG.336b0fc823c446b2ed3193ddf07e379d.JPEGIMG_6773.thumb.JPEG.d0016a09e9e907b3d4355ccf394cebff.JPEG
I have some time off over the holidays and have restarted work.  I've added the bands, gunwales, and breast hook and cut the cap rails. Cap rails are Swiss pear to give some contrast.  I had a few false starts with the gunwales.  I didn't shorten the frames enough and ended up sanding the gunwales too thin when fairing the upper edge.  I debonded and repeated.  I think I will make the frame irons out of brass.  I am going to glue the gunwales in place, apply some minwax wipe on poly finish, then add the frame irons.
Cap rails attached.  The instructions say "any gap can be fixed with a little filler and paint."  The model is a little more challenging when that isn't an option.  The instructions and a lot of the completed models use a three color scheme with white oars and thwarts. I will make these out of holly.  If I get to the workshop later today I will work on the last few parts and apply some clear finish.IMG_6857.thumb.JPEG.22301ff79872bb9b3691022768147e56.JPEG
Druxey - many thanks!
Fortunately, I did not make any commitments to finish by the end of the year.  I thought about it, but it didn't happen.  I did do some more work.  I finished the hull with minwax wipe-on poly, which I think brings out the colors of the pear and boxwood really well.  I also made some 3/64 pear dowel, ripped holly for the thwarts, and rough cut the oars, also out of holly.  I started shaping them, but won't post pictures until they start to look ok.
This is a nice clean build, I love the contrasting wood colors. Very nice work sir.
I have the oars mostly shaped.   Some need some more sanding.  I also cut out the thwarts.  This was another area where laser cutting would have been easier.  Cutting slots with chisels and files has turned out to be really tough. I'm not entirely happy with them.  They aren't glued in place yet.  I took them out to finish with minwax polycrylic (dries clear without changing the color of the holly).  What looks like misalignment of the fore and aft thwart I think is distortion from the camera.  I will recheck once the finish is dry and adjust/replace if necessary.
IMG_6871.thumb.JPEG.a925bb61ccd74e18e0ddee84b38f13c7.JPEGIMG_6870.thumb.JPEG.24bd3eee759395deea338e4b766b9e29.JPEG
It's coming together.  I redid the fore thwart and raised the end one of the seat risers which was a little low.  Beckets have been installed.  I'm going to call it quits for the day and plan to finish after work tomorrow.  I just have to glue down the thwarts and oars and add the thole pins.
My dory is complete.  When I started it in March, I didn’t expect to spend 8 months on it, but I had a lot of fun.  I’m pleased with the final product.  It is time to get back to the longboat, finish the Halberstadt, and finally start Echo.
IMG_6883.thumb.JPEG.7d4af8e3e5e115e5e3f050409c43291b.JPEGIMG_6882.thumb.JPEG.c67a5c65b57f3597c69017d79a25092d.JPEGIMG_6886.thumb.JPEG.16fa92d87b8102c43ca88a978cd9bbfc.JPEGIMG_6881.thumb.JPEG.4e19db9a0d769a5db0d5222b5cff74d5.JPEG
Excellent work! The decision to use other woods and leave them with a natural finish really worked out well, it's a striking result and definitely a very unique variation on a frequently-built kit. Looking forward to your next builds!
Well done, nice clean build :)
Current Builds
Midwest Maine Lobster Boat
Trumpeter R/N Fiume
Upcoming Builds                                           Completed Builds
Billings Boats RCMP St Roch                          Model Shipways Norwegian Pram
        Midwest Models Lobster Smack
        Model Shipways Dory
        Billings Boats Norden
I stream my builds live, join me at  https://www.twitch.tv/bartbandy
Nicely done,  great work Congratulations     :cheers:
                   WASA
                   USRC Harriet Lane
