Yeah, $45.00 is too much... I'm looking to see what I can find....
Warbirds does a set for the T-birds "D" models in 1/48th, If you can find them...
Well the Skyblazers and the T-birds flew F-100C's for a number of seasons before they switched to "D" models... I have the 1/32nd scale Trumpy F-100D which is a gorgeous model, (needs an aftermarket nose) but finding decent T-bird decals for it is just as much a problem as Skyblazers...
I fully understand it being a no-brainer... the F-100C will make a beautiful bird though it was one of the more colorful aircraft in the USAF inventory...
Edited by Egilman
Quote:
You know brother, the Trumpy  1:48 F-100D #02822 has the decals for both the T-birds and Skyblazers.... It can be had for as low as $34.... It's out there, most have it for around $45 -50....
https://www.scalemates.com/kits/trumpeter-02822-f-100d-thunderbirds--203629
https://www.super-hobby.com/products/F-100D-IN-THUN.html?partner_id=9
Edited by Egilman
Quote:
On 4/1/2024 at 6:18 PM, CDW said:
Can someone here please explain why this particular aircraft has those distinctive color striations at/near the afterburner? I've often wondered but never read an explanation of why they all seem to have this look.
This can happen when Titanium alloy is cladded with aluminum. In my working experience, testing a titanium foil with aluminum deposited on it at high temperature (around 450 C) we got such a discoloration. The phenomenon is due to the aluminum getting migrated into the titanium and forming a intermetallic compound that had such a discoloration. A more familiar but similar phenomenon was visible with exhaust tubes of old style motorbikes that had tubes made of steel coated with chrome. Also in this case, under the effect of high temperature, the chromium went dissolved into steel making the typical, and much nicer in this case, bluish discoloration.
I hope this help,
Dan
Yes this does and will happen, but it doesn't happen to the tail of an F-100, the tail of an F-100 is solid Titanium sheets, not clad in anything... High chromium content steels like high end stainless will show the same discolorations when subjected to high heat although it appears grey like any other steel when new...
Titanium alloys used for aircraft structural panels discolors like that starting at around 850 C.... In fact the reduction/elimination of that excess heating of the tail panels on aircraft led to the development of air bypass engines, to help keep the tail fuselage surfaces cool...
Edited by Egilman
Quote:
