Suggestion on how to get the mast caps to the right angle (84.49 degrees on the plans)?
Right now, the top of the main mast is right at 4mm, and the mast caps ride snugly. I’m guessing I either need to narrow the mast a bit more or widen the mast cap hole a bit. That’ll make it loose and allow it to take on a slight angle but then it’ll be loose. Do I then just “lather” with glue and hold it in place until it’s set? That’s what I’ll plan to do tomorrow unless someone has a better suggestion.
16 hours ago, palmerit said:
best way to tie the blocks
There are many logs and posts in this forum on the many different ways to seize blocks, try a search. There are also YouTube videos some have referenced.
Regards,
Glenn
Current Build: HM Flirt
To get everything to stay aligned with gluing, I made a copy of the section of the plans and taped it to a scrap piece of board (the build board from my Dory), inserted the glued mast cap to the mast, and taped everything down in position relative to the plans. We’ll see how this works.
It looks according to the plans that there might be a narrow disc on top of the main topmast. Is that right? I didn’t see it on the photos in the manual (but I think some of the photos are from a different ship). If so, would those be left natural wood or painted black?
The main mast, mast caps, and main topmast are assembled (glue is drying). Thankfully I attended to how the holes that were drilled into the topmast needed to be oriented. Will paint black both mast caps and the masts areas between them.
Edited by palmerit
The topmast and some of the yards are made from 4mm dowels. I unfortunately just started cutting the yards to size and didn't realize that I should have made a couple small ones from the same dowel. When I went to cut the last one, it was longer than the pieces I had left. I thought I had them all planned out, but I had missed accounting for one of them. I asked Chris about ordering another one from Vanguard, but he suggested to order one from the US. Chris told me that the dowels are walnut made by Amati. In the US, I can order them from Age of Sails (https://www.agesofsail.com/ecommerce/am2535-04-amati-walnut-dowel.html). While the dowels are inexpensive ($1.37 each), the shipping is pricey. But at least I'll be able to continue.
More progress on the yards. The drill trick works. Can’t imagine glueing on those tiny little wooden pieces (blanking on their name) without an optivisor.
I accounted for all the masts and yards by taping them to their respective plans.
Edited by palmerit
Nice work Palmerit, Im following partly of your log to build my mast on my Sherbourne too 👍.  A question regarding the main mast the part that is 4mm on the 6mm dowel, That is just sanded down on the same dowel right?  No part that is just cut and glued on seperately.   Im juts double checking so I dont misunderstand or do something wrong here
Edited by Stuka
All of the masts and yards have some kind of a taper. None are glued together. The full mast in the photo is of course made the several parts, but any yard or mast will be made from a single piece of wood. I can’t imagine a model doing otherwise. I made photocopies of sections of the plans for each mast and yard and first cut them to the appropriate length with a micro miter box and razor saw. All of these are one piece. Then using my digital calipers, I measured the width on the plans in several places (the plans are all 1:1 scale) and wrote the measurements on the plan copies. Some taper gradually and consistently, others taper differently. So you don’t want to just go from the widest to the narrowest part. I mounted the dowel in my drill. I did wrap the end several times with a strip of paper because the first time I tried I saw that the drill chuck left marks. I used a clamp to keep the drill running. I've seen people mount their drill in a bench vise, but that doesn't seem necessary, at least for this kind of work just using sandpaper. Then it was using 80 grit sandpaper to really taper away. I’d do some, then lay the copied bit of plans with the measured marks under the dowel and measure in the marked places. I’d also just look at the shaped dowel to make sure it was tapering consistently. I always was moving the sandpaper up and down the spinning dowel to maintain a consistent taper. I’d move the sandpaper slowly with pressure on sections that need a lot removed, faster with less pressure on sections that needed less removed, all in proportion to the amount of taper that was needed. Key was doing a little at a time, measuring with the calipers, measuring, sanding. I suppose without calipers you could eyeball the dowel with the plans (which is why making a photocopy of a small section of the plans helpful). When in was close to being done, I used higher grit sandpaper. I finished off with 320 grit to smooth.
I had posted a while back asking if I needed a lathe to do this kind of work. Thankfully a bunch of people said to use a drill. One nice thing about the drill method is that I can just do it all at my regular work area. I don’t need to move someplace where I might have to keep a lathe. I’m sure a lathe is essential for other kinds of work, and certainly might make shaping quicker and easier (I might get one someday). But the drill worked fine for me.
Edited by palmerit
I was looking at some build logs of other ships and saw on some that the anchor rope was looped (at least once, sometimes many times) around the winch - I'm guessing it would need to be wrapped around if the winch (is this winch called a windlass - and a vertical version a capstan - I'm still learning the language) is actually used to raise and lower the anchor. I haven't attached the anchors (I just have the anchor rope pulled through the holes at the front). I followed the photo in the instructions (attached), which doesn't have it wrapped around. I suppose if I do wrap it, I'll need to make sure the anchor line is long enough.
Edited by palmerit
Far as I know the anchor cables were always wrapped around the windlasses in a cutter, the crew would be out of luck if an anchor deployed with no windlass to recover it.
Like many things in a build the instructions are basically showing you how to produce a reasonable model out of the box. There are many places such as this where you can make small adjustments to improve the model. Ultimately it is up to you (a model is a piece of art after all), but if you want to see an example you can look at my alert log where I detail how I did it.
The walnut dowels I ordered from agesofsail.com arrived and I made the main boom. I had to get a new 4mm because I hadn’t arranged the cutting of my 4mm dowels properly. While the dowels were fairly cheap, the shipping was costly, so I ordered a few sizes in case I need a replacement for another model someday.
Finally starting to do the rigging. I need to add eyelets to the main mast. Should I assume that the eyelets marked A that are attached to the sides of the upper rectangular mast cap would go in the middle of the mast cap? The plans show where they are located on the front and rear view but don’t show their position on the side view.
Another thing I’m unsure about is what to do with the PE-2 eyebolts (they’re larger than the PE-1 eyebolts that I used in lots of places in the kit). I’ve yet to use a PE-2. I must have missed where.
I don’t think I have enough of the PE-1 to add eyebolts to the main mast. I lost a couple PE-1 eyebolts (they’re small and can fling off a set of tweezers). I don’t know if I missed where I was supposed to use the larger PE-2. There are a bunch of them. I’ll probably need to use the larger PE-2 on the mast.
I ended up using the PE-2 eyebolts.
Edited by palmerit
 Hey Palmerit,
Good progress Im on the same step as you so im struggling aswell 😆. As for the PE-2sLook in the Plans 7,8 and 9. I have found Pe-2s to be used on the outer pattern close to the stern, aswell as 3 on the bow.  Unlike you I have almost ran out of PE-2s so i wouldnt be surprised if I accidently used some while building the cannons.
For the eyelets on the main masts above, I put them around the middle maybe slightly a little bit towards the extension mast I used manual side 49 as the picture for reference. Though in the reference picture It looks like the are slightly more on the end of the extension part.
As for the 5mm triple block I did not find it either so likely it was overlooked in production, I did reach out to the only one I think so far thats finished the Sherbourne  "ECK" and he said the following to me  "I sanded down one side of a 5mm double then flattened slightly another double and glued them together" . Im thinking of doing something similiar or maybe putting together some blocks from another old kit I inherited.
Good luck on the build!
Edited by Stuka
The Quad Hands really make it easier (far easier) to rig the blocks. I was trying to tie in the block without using them and failing completely until I pulled out the Quad Hands. I’m guessing there’s a way to do this without them but I couldn’t figure it out.
I put together two 4mm doubles (there are no 5mm doubles). Thanks for the suggestion.
Now that I’ve finished the Pram and Smack, I’m getting back to rigging the Sherbourne, my first model I started.
Some of the blocks are tied to eyelets. I followed the instructions for tying them in the instruction book.
I also need to tie blocks using a line that goes around a mast or a yard. I’ve attached a copy of the drawing from the plans for one of them and a close up photo from the instructions.
I know I could just knot the line to the mast with a half hitch (plain simple knot) and then tie on the block.
Are there alternative ways to tie this on? I’m not sure what to search for to see what options there might be. Is there a name for tying on a block like this I could use in a search?
I might resort to just a couple simple knots but I’d like to see other options I might have.
Your illustrations look like two rope-stropped blocks that share the same strop, which is made long enough to pass around the spar. I don't know whether there is a name for that arrangement.
Ashley illustrated one version of it as "span blocks" for stuns'l halliards (his #3175) but it's not clear whether he meant the name for that one application or for any paired blocks surrounding a spar. All of his blocks secured to spars, whether with one block or two (and all for full-size vessels, of course), had the strop with two ends, each with an eyesplice, while a lashing held the two eyes together around the spar. At scale, you would presumably make a loop, slide it over the end of the spar. then fit the two blocks and tighten up with a seizing by each block.
Darcy Lever showed something similar but with hearts, not blocks with sheaves, for bowsprit shroud collars. I dare say the other contemporary authorities showed it too.
