While I was trying to sort out the prop tips I took some time off and weathered the plane approximating to the real aircraft photo posted earlier. I used Ammo engine oil wash on the wings and masked up the panels that seem to have discoloration.
Suitably grubby!
I decided I wasn't making progress with the props - I just can't freehand the tips without something to rest my hand against. So I did what I should done at the start. I pulled them off (luckily I had used Gators Grip glue) and thankfully didn't break anything. They were stripped back and now will now be painted again, hopefully with a bit of precision. It possibly worked out for the best because I decided that it was a good time to add the PE details and I don't think I could have fitted a lot of it without bumping the prop blades.
The turbulence control vanes over the flight deck were horrible to install; they are just so small (and there are 16 of them). Everything else was fairly respectable to work with but there are now few places that the model can be handled. Reinstall the props and touch up the paint and I think we will be done.
RIMG0421.thumb.JPG.b1b8f5acd9798042b9375e5b9d3f8dfa.JPGRIMG0422.thumb.JPG.258384bed8f2f4cb42a676c72d760ac4.JPGRIMG0426.thumb.JPG.6b0605764404753009d54d3aa146e322.JPG
I added landing lights made from discs of aluminium foil and a dot of glue for the lense.
Thanks for looking in, the likes and comments
Alan
Thats  Great  work Alan,  I remember  bashing around  with  plastic  plane kits  in this  scale  and  doing  horrible  jobs,  love  how  you are  turning this  kit around  mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you very much OC. This is a first venture into 1/144 scale and there is a learning process as always. I need to tidy up my paintwork. It looks okay to the eye but the camera shows up every flaw. There were some horrible parts in the kit and flash, fit and some deformed parts made it a challenge but I was very happy with the way the fuselage, wings and booms went together. It all locked into place with the booms square to the wings and parallel. I gather the Beverley is much worse.
alan
Progress is shamefully slow to finish this one. The second attempt to detail the prop tips were a miserable failure. The masking worked quite well but I seemed to suffer from incompatibility / inconsistency between the paint colours which were a mix of acrylics from Vallejo and Tamiya. The Tamiya colours didn't like being brush painted and the Vallejo either chipped off or peeled off with the masking. So its all been stripped off again and I am trying again using Tamiya and the air brush.
The front and backs have now been primered and tomorrow I will mask and add the first colour.
All this for a bit of red and white on the tips of teh blades.
Thanks for looking in and the likes and comments.
Alan
I too  used  to have issues  with detailing the  props  -  with me  it was  getting a  nice straight line at the  tip,  so I hear  your pain  mate.
OC.
Current builds
Completed works.
OC.
It looks so obvious when its off. I got the white sprayed on today. Tomorrow I mask and add the gray to the blades.
Spend more time cleaning the airbrush than spraying paint.
Alan
Alan
Sounds like a  plan  mate.
OC.
Current builds
Completed works.
So at last the sage of the prop tips is over.
Paint props white
mask tips and paint grey
,mask blades and paint red
Each time I let the paint cure for 24 hours between coats and I used a dilute clear coat to seal the masks.
I never seem to get on well with Tamiya Red but the alternative was a bottle of Mig Ammo Atom Red which is completely untried and I did not want any more drama. I had to tidy up the results from spraying but they were close enough to make it worth a bit of touch up by hand.
Touch up duly completed and the props reattached. They are not perfect but they are reasonable for a first attempt at 1/144 scale aircraft.
RIMG0444.thumb.JPG.3ab78b615158b2b0cdd113380088f366.JPGRIMG0445.thumb.JPG.a3f5857a1e661f98634b4ca8a6875e78.JPGRIMG0446.thumb.JPG.14a12ae657cf1c58d842f56187f94cf3.JPGRIMG0447.thumb.JPG.89048e7a70bcab7d153414d9df726a8c.JPGRIMG0448.thumb.JPG.7f8790025c1a0c803fbacd0709daf444.JPGRIMG0449.thumb.JPG.2e0211553b54fbf1ea82459c01f35b08.JPG
Lots of scope for improvement - and I have a few more 1/144 scale to build when I feel strong enough.  I think I have learnt a few things that will improve my efforts for the future. Fairing wings, fuselage and tailplanes will be given more attention and @Landlubber Mike has provided an excellent note to help future builds.
Thank you all for the likes and helpful supportive comments.
It was nice to see an old remembered aircraft come together as a completed model
Alan
Hey Alen,    thats  turned  out  really nice  -  you  have to take  into account  the  problems  you had with  the kit, and  then the scale  -  you  have built a  faithfull  rendition of the  the old  bird  -   she looks  just  like an "Argy"    yep  I have seen a  few  at a few  airfields  over here.
OC.
Current builds
Completed works.
Congratulations Alan on wrangling this mini “beast” into shape, looks very unusual, nice to see a rare bird like the Argosy.
Andrew
Completed (Kits):-
OC.
Thank you very much OC. A bit of a struggle at times and my inexperience shows but I’m really happy to have built something from the high days of post war British aviation when there were so many different types around.
alan
Thank you very much Andrew. It must be old age but I find I have a lot of affection for the aircraft produced by British aviation prior to the forced amalgamation of most of the great old names. I remember the hangers at Boscombe Down in 1972 having so many different types. Lightnings, Javelins, Canberras, Hunters, Sea Vixens. It would make an interesting project to build one of everything that I saw there that year.
alan
Hey Alan, that came out great!  Nice work showing that stubborn kit who is boss!  Like anything else, working on something difficult teaches more than something that falls together.  You should feel proud having completed it!
After slogging through this one, you should try a Tamiya or Hasegawa kit.  My Hs 129 kits by Hasegawa have perfectly fitting parts.  After my JRS-1 and Special Hobby past build, I was practically confused and couldn’t believe my eyes when the fuselage just snapped together to the point of likely needing little to no filler.
Congrats again!
For a tiny little 1/144 model, there's a surprising amount of detail there!  Well done!
Brad/NavyShooter
Congrats again!
Thank you very much Mike. The Yak is the last of my planned exploration of east European kits and it looks like it’s going to have its moments. Lots of filing and filling. I have promised myself the next will be something from the opposite end of the market and will be back in the ship page. Something Flyhawk I’m thinking.
alan
Really nicely done Alan.
OC.
Current builds
Completed works.
  • 9 months later...
@king derelict Hi Alan, hope you don't mind me adding to this log from last year, but I got to see an Argosy last week, and go in it! 😁
This example is at the Midlands Air Museum on the edge of Coventry Airport.  It is suffering a bit for being stored outside, but not much option for most museums for an aircraft of this size.  Also hard to get far enough away from it to get a decent picture, so apologies, thought you and others might be interested.
Link  for the Midlands Air museum here:- https://midlandairmuseum.uk/
I also got to go inside the Vulcan cockpit and one or two others like the Meteor they have.
Andrew
Completed (Kits):-
Hi Andrew. Thank you very much for adding the photos of the Argosy to my log. The photos are great. Ive not been to the Midlands Air Museum and Ive added to the list of places I would like to visit on my next UK visit. Luckily my dad lives within easy reach of Newark Air museum, RAF Cosford and the air park at Castle Donnington. The Coventry museum looks like it has a good selection of exhibits.
Alan
