The yacht D'Oro from Corel actually looks like the replica (called Sehnsucht) of the Great Yacht from the Brandenburg Navy.
This kit from Corel dates from 1973, the plans and especially the instructions are completely off.
Bought at a very good low price. If you really want to build a yacht from this period. For the same retail price there are better quality options.
A challenge ... 👍 ;)
I think this the only existing painting of this vessel
There is a model in the Maritimes museum in Hamburg
9d2403cf599b07f0_1280.thumb.png.2d6465945a1aa09e18d1d656ee8a4d0c.png15ec748387b23304_1280.thumb.png.8161fef1e3395a3022d5aaf5fab1af08.png65d417fb1d2051ea_1280.thumb.png.9bc367294b8499e65eb7cc9568af96ac.png1500b3521437e370_1280.thumb.png.6a0ba14be7abea2550503cfbc5fdef89.png
Content of the box
Drawings
"instructions...."
plywood
more plywood
planks and others
fittings
PE parts
The supplied walnut planks for the hull will be used for the decks and such. For the hull itself, planks are sawn from pear wood.
20241002_155247_1280.jpg.e234626aa1f98b75b54f103d8ab9483d.jpg20241016_190801_1280.jpg.3cab4270d895744a096cb2c512cb47d8.jpg
A set of new flags is also made and printed  on tissue paper20241016_190636_1280.jpg.f7c5476a4fbd3a0f00d5061bd4b1b3d6.jpg
A challenge, perhaps, but at least Corel kits typically have good-quality wood.
P.S. I have edited the log title, including correcting the spelling of Größe to Große -- the first instance is a noun, the second is the adjective form. Those pesky umlauts!
Thanks. And the wood is indeed of good quality.
öß or ß ???
Neither letter is on the keyboard of my pc or smartphone. We do not use these in the Dutch language.
So I did a "copy, paste" of the text on the website of the Maritimes museum in Hamburg.
A German museum that cannot spell a German text correctly on their website....😪
Btw, English, German...  never learned at school 😇
Edited by Baker
Here we go
The plywood is beveled at the keel and bow. And the new keel and stem are ready, these are connected with a scarf joint.
Gluing
Test, pretty ok
Dry test bulwarks, also ok
By using the plywood and the walnut planks as deck, I have to lower the bulwarks and the plywood keel piece at the top by 2mm.
20241023_193521_1280.jpg.ec6ffc4f365f1c35acf9e25059296205.jpg20241023_194258_1280.jpg.f1f65978b4561b2ffe1ec2d1c757f2c5.jpg
Sawing
To be continued.
Good luck on your journey with this build, :cheers:  Bob  M.
                   WASA
                   USRC Harriet Lane
8 hours ago, ccoyle said:
Misspelling one's native language is a shared human experience!
I thought only Americans have that problem.
"Bee nott afrayed of anny man thatt walks beneath the skys,
tho big he bee or small you bee, for I will equalize"
- carved into the grip of a Colt army revolver, 1870's
The bulkheads are glued to the keel.
plywood decks in place
To make this plywood easier to bend, cuts have been made on the inside
20241027_135931_1280.jpg.8638430d3835661434628a8936fe032c.jpg20241027_140120_1280.jpg.115acdf8fb14158fa81b2a8e3c1cbae2.jpg
Now to do is shape the bulkheads a bit better and bevel them.
The hull shape does not match a Dutch yacht from this period.  But fortunately we are not building a Duych yacht 😇
planking
Corel's idea is to nail extra supports to the deck.
20241105_081131_1280.jpg.16a0cbffe1d120a0a1294f0cdacde548.jpg20241029_155341_1280.jpg.d4dc50513065c5c1a4cd9062f4789f82.jpg
I don't think this is very practical. That's why they were removed and this material was used in a different way that gives more support to the planks.
20241101_133121_1280.jpg.dcc0a36803d052c319407aaeca22d003.jpg20241101_133144_1280.jpg.e6d905d3a9cecd69f402d1a6dc0b095e.jpg
The pear planks are very flexible.
I don't know anything about a 17th century yacht, so I bought some reading material in advance.
There is no hole for the tiller.But the problem was seen in time and solved
planking, work in progress. The diagram of the planking on the transom comes from the book.
Planking
First planks were placed on which the large PE parts will later be glued.
For the correct position, the height of a cannon was first measured. And this way the position of the first wale can be marked.
Once this wale is glued, the excess part of these first planks is removed and further planking can take place.
20241108_112618_1280.thumb.jpg.7c02ca9b162f5051d1915e9cacc2c1e4.jpg20241109_072607_1280.jpg.44306f8acc344615472ca19053a2b2a1.jpg
Planking, work in progress
20241115_180837_1280.jpg.2a6ee17f59b38f8329468c73f5ef91e1.jpg20241115_180851_1280.jpg.a69945995dc2b6a154c8c3cd00950eb4.jpg
Planking
Before further planking can be done, a spiral staircase must first be made. Originally this is made of plywood, so a new one is made of pear
The opening is placed more towards the middle, then there is less hindrance with the cannon that is in front of the staircase.
Planking,
this method is found in the book of the Dutch yacht Utrecht.
"Plank bender"
Planking is ready for sanding
A first sanding with grit 60 has been done
20241126_155450_1280.jpg.aeafea5111bcb55de5c198767e1c0d6c.jpg20241126_155541_1280.jpg.d41581e71d87c2b83658d5f7ef8df726.jpg20241126_155518_1280.jpg.c5d6dc7b08b52f36a5d7ed80e63ac726.jpg
And the plywood supports on the deck are removed
Edited by Baker
She's looking really good and bit tiny next to the Mary Rosasaurus Rex behind her. 😁 I've seen many here working with pear. I haven't tried that species yet. I'm not sure how available it is in the US.
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
Thanks.
Luckily Mary Rosasaurus doesn't have any teeth yet😉.
Personally i like cherry wood more than pear wood
Planking the inside of the railing.
Checking if the cannon ports are still in the right place ;)
And the planking of the deck has begun.
For the deck planking the walnut wood from the kit is used. Excellent quality 👍
20241202_190930_1280.jpg.1133a41cfe8ea3825328406453da5c0b.jpg20241204_154057_1280.jpg.3dd2f65dc59e1f03f481ff7bbddb0697.jpg
Edited by Baker
The deck planking is ready and treated with two layers Danish oil.
(The kit provides only plywood for the deck)
The wall from the rear cabin and the hole for the whipstaff (kit)
20241218_191910_1280.jpg.1ea442df99116126fa9754e0fbb7c871.jpg20241216_190012_1280.jpg.e3b51b4cd6a7fcb35c595f7b60b70d3c.jpg
A new lay out for the wall
New designs (wip) dry fitted
A new base for the mast20241227_163902_1280.jpg.03b6995ea6de5f504d304bd955268de9.jpg
A new ladder, and the chimney (wip)
The large PE parts are glued and nailed and the revised wall for the cabine is ready
drilling holes
nails
Did a little further on the transom
PE parts in place
current status
replacing plywood parts for pear wood
And some juwelry (99cents /bag) as extra decoration round the cannon ports and holes for the anchor cable20250106_132303_1280.jpg.3551db41c45978dda2dffda2f20db861.jpg20250108_124529_1280.jpg.68a88ca972bdff55ad268ee6a58f46b1.jpg20250109_182754_1280.jpg.ab71ba43f690aa9f8ab0f39002632501.jpg20250109_182808_1280.jpg.ea5f2c0a35eee056a6e5029e79653701.jpg
Edited by Baker
Well that's pretty kool!
Mikki
Reconstruction of the stem
The plywood parts are replaced by pear, there is still sanding to be done I see in the photo.
A first layer of paint
With a solid base for the figurehead (dry fit)
The wall of the rear cabin is painted and placed. And the planking of the upper deck has started.
Planking ready, still needs finishing.
20250118_162930_1280.jpg.26f1eeb7f265789fa3e10ea9d9313097.jpg20250118_163008_1280.jpg.ebce598ef8d1bc5249550ea003dbaf43.jpg
Thanks.
Yes and no.  Corel is not really helpful.
The only thing I base it on are the colors on the Brandenburg Marine painting.
Building the side windows of the rear cabine.
There are 2 "shapes" provided, the material of which looks like pressed paper. Some PE parts and 4 figures.
First sand and cut into shape, and then get started.
20250117_133912_1280.jpg.652e82f6302052f74c635638821984b2.jpg20250122_092602_1280.jpg.47047b89a959d99935f01120c5cd186b.jpg
A bit better than the kit parts.
And a first layer of paint has been applied and sanded. No masking tape has been used, at the time this was not available either
20250124_105246_1280.jpg.bab7b70debe58e6e140551a0b29363ef.jpg20250124_105259_1280.jpg.f87668ebe7bb4d99d9dab7a55ae74dc7.jpg20250124_105311_1280.jpg.5e44c7ce808a73c3d02946198a1d5285.jpg20250124_105426_1280.jpg.66e26126e1726d542a96138c6f79c801.jpg20250124_105347_1280.jpg.2cf9904c42c274d6a938a560feb57323.jpg
Started painting
The red paint first got some gray drybrushing. Then the decoration around the cannon opening was painted yellow with a gold drybrushing on top.
The parts of planking that are not white, black, or otherwise colored. Are provided with some "wooden" treenails (toothpicks)
The wails of "bolts" (head pins)
And the plank between the wails of "nails" (fishing wire)
20250130_081125_1280.jpg.ba0f68cf1b726c2b953232bdc620f8ad.jpg20250130_081143_1280.jpg.9908b608a672744e8198ecba9c914eb9.jpg20250130_135623_1280.jpg.cd94667fd1372a58faeb96e60c33cf80.jpg20250130_135630_1280.jpg.ab4e31d469e4bad4f5b4b92164c84d7d.jpg
I also started painting on the decoration, the PE parts that were included with the kit for this were a :default_wallbash:to be painted....
Base color red, decoration yellow, and over the whole a drybrushing with gold color, I really can't do better.
Also started on the winch
Kit parts
improved part
20250127_190654_1280.jpg.0e70848070c7a630ee8068096a5a79fc.jpg20250127_191050_1280.jpg.85bea3dc6378cca6f62b6082dbd76b4e.jpg20250127_191756_1280.jpg.740287109e4fdc6ff8c44333ce356674.jpg
Grooves have been milled into the winch, which provided more grip on the winch
Reconstruction of a new scratch build winch
20250205_083144_1280.jpg.201efe681955f6eeeaeaf44f55e800cc.jpg20250205_165011_1280.jpg.b83fcad61eede3d1e2e67b26bf0fcb9a.jpg
with "new" supports from "leftovers"
20250205_083150_1280.jpg.127568f804c64569c44ab8eb7a1c2239.jpg20250205_165059_1280.jpg.59e2b33e3161322a38cec94665cf861c.jpg
construction of the handle which can block the winch
20250206_150615_1280.jpg.94720f7f93ed11fac9ea3b21b2cc6099.jpg20250206_152141_1280.jpg.d96acf52de7a6253071c53c92de93fb1.jpg
Winch ready, chimney in progress
And some further detail
Looking great!!!! Nice work
Mikki
