1 hour ago, Keith Black said:
Nice case, plans for the Sharpie?
The first visitor I get that looks at it more than once is taking it home with them. 🙂
29 minutes ago, KeithAug said:
All coming along very nicely Paul.
Thank you Keith, I really appreciate your comment !
Best Regards……..Paul
 And your address is? :)......... no way, Paul. She's way too nice a model to be adopted out.
“And your address is? :)......... no way, Paul. She's way too nice a model to be adopted out”
Its been finished for a while now and no one has met the requirements yet so I will probably have to get going on making a case for it.
Hey Everyone, wishing you all well. Thank you very much for the Comments and Likes. In the last post I mentioned that I would like to attach the main deck cabin but after some thought decided that it would get in the way of laying out the planking. The planking I chose to start with are the ones that run along the inboard side of the bulwark stanchions as seen in the next photo. They are labelled LONG'LS which I take as being short for longitudinals.
Some spacers were made and laid on the waterways and then the long'ls were glued to the bulkhead extensions.
The bulwark stanchions that rise up to the cabin deck where laid out to get the shear. I used the same process as when laying out the main deck cabin.
A piece of 1/8" basswood sheet was used where the height changes. Next came making a multitude of bulwark stanchions and covering boards. A couple of months ago I decided that this build would require some machine assistance so I bought a Slicer from Ultimation Tools. It really shines when it comes to making these small pieces.
Port and starboard stanchions were done simultaneously. I'm now halfway down the main deck.
**** The frames that pass either side of the main hatch will be reinforced with an additional frames as seen in the next picture ****
 ( This statement is not true. The stanchions in that area have the same spacing as the others. The 10 1/2” frames stop at the deck beams and the 13 1/2” frames continue up to become stanchions. The two 10 1/2 “ frames that were installed have been removed.
Now back to the slicing.
Edited by Paul Le Wol
Wrong interpretation of drawings
 Nice work, Paul. Slicers are the only way to go, I can't believe how long it took me to see that lightbulb come on. :)
Great work on the stanchions, they're really even!
Is a slicer more precise than using a razor saw with a miter box and a stop? I've only used the latter before.
Paul,
You are planking the hull from the inside out! That is a very good way to get all the bulwark frames in place.
I envy you on this build. The HAER report drawings show so much detail of the construction of the ship. We don't have that detailed information for most builds.
Somewhere here I should have photos (slides) I took on the Wapama back in 1972 when I was in San Francisco for discharge from the Navy. If I find them I'll scan them and send them to you.
Phil
Current build: USS Cape MSI-2
Thank you very much Jacques. They are great if you have lots of cuts to make. The blade on this one only cuts square on one side so you still have to square up the end of the strip you are cutting from before making the next cut. I don’t think it is much more precise than a miter box and a stop but when it came to cutting the cover boards which were 5/32” x 5/32”  x 7/32” long basswood it made a big difference just being able to pick the pieces up with tweezers and glue them into place. The cut on the piece you are using is straight, clean and doesn’t really need to be dressed.
I have a RP slicer and I think it's much more precise than a miter saw for repeated cuts requiring the same length, IMHO.
10 minutes ago, Dr PR said:
Paul,
Hi Phil, your offer is very kind. Thank you. I agree, these HAER drawings are very detailed. I spend a lot of time just looking at them and discovering new tidbits. The notes on the drawings are aiso full of great information.
That’s a good looking machine Keith. I’m still getting used to mine. Funny thing is that even if I’m using a repeater most times I still double check the measurement. Must have trust issues 😀
I like the RP a lot. The only issue it's limited for long lengths. If I was cutting long lengths I'd have to design a stop for doing so. I've used mine enough to trust it way more than me and a miter saw. Anymore I just blow and go.
Hi Paul, I just discovered this interesting build and am pulling up a chair. Beautiful work as always!
ian
ian
Thank you Ian, always glad to hear from you.
Hi Everyone, I hope you are all well. Thank you all very much for your support. The bulwarks have been completed.
The model was unscrewed from the build board and three standoffs were attached to the hull with #6-32 machine screws. The other four supports are moveable under the hull.
The stem is 1/4" x !/4" AYC , It was attached next.
After a bit more fairing the planking will begin at the stem with 3/16" x 1/16" strips of AYC. The top of the first strake will be level with the top of the waterways. This plank should be 5/32" but I don't have that size available. My thinking was that a wider plank will probably make it easier to get a nice curve along its length. I've been wetting one end for a few minutes, clamping it and drying it with a heat gun with a few clamps pulling down the far end. I let it sit like that overnight.
This could take a while but there's lots of other stuff to work on.
 Moving right along, Paul. 👍
Hi Keith, it’s going faster than I expected. Glad it came off the build board without any grief
 Isn't it great when something works out like it should! At times during a build that can seem like the rare bird.
Hey Everyone, thank you for the Likes and Comments. The are always appreciated! Planking has been moving along at a pretty good clip. The first plank laid was CA'd into the rabbet at the stem.
Spacers were made that sit between the waterways and the longitudinal boards on the bulwark stanchions making it easier to maintain the proper run of the first strake.
The strake above this one contains the freeing ports and the scuppers. The scuppers were filed into one plank port and starboard using a strip of brass with a notch filed into it. There are 21 scuppers on each side.
The  planks are edge glued and glued to the bulkheads using white PVA. Small tabs are glued to the backsides of the planks to help keep them aligned.
A mold was cut out of a pine board in order to shape the planks running around the stern. The two trigger clamps pivot on their jaws as the planks are moistened and heated with a heat gun.
These planks are attached with CA just at the centerline and then with PVA the rest of the way.
I added some filler blocks where the port lights will go. The next photo shows the tabs behind the planks ganging up at the bow.
And this is what she looks like today.
The planks are not in scale but the wider planks are just easier to install and the hull will be painted.  Once it is planked up to the forecastle and cabin decks the model will have to be tipped over and the lower bulkheads faired. Take care!
Excellent work, the scupper jig is a great idea too.
 Beautiful work, Paul.
44 minutes ago, Glen McGuire said:
Creative way to bend the stern planks to shape.  Nice, clean work with the whole planking, Paul.  She is looking good!
Thank you Glen, This is my favorite part of the job. (Not that its a job.🙂)
42 minutes ago, yvesvidal said:
Great simplification of the hull building, by keeping it as a waterline model. Then the difficulty will be to recreate a realistic sea for the base.
Yves
Thank you Yves, I don’t think I’m up to the challenge of making a realistic sea base. I was thinking about getting a slab of 1/2 Corian countertop type material cut for a base. Something dark grey.
Thank you Jacques, the jig worked well but wow did that take a long time!
Thank you so much Keith.
44 minutes ago, Jim Lad said:
Very neat work, Paul. She's coming along well.
John
John, thank you very much for your comments and support.
