Peugeot Char d'Assault by RGL - FINISHED - 1/35 - Vargas models - 3D-printed
5 hours ago, yvesvidal said:
In addition to that strange armored vehicle, Peugeot created something much more useful, the Pepper Grinder:
Yves
They also created the L76 engine in 1912.... A 7.6 litre, 4 valves per cylinder, dual overhead cams... The first 4V-DOHC IC engine ever made.... It proved itself in the French Grand Prix, and the Indy 500 and became the racing engine of choice from those days forward... Harry Miller took it and designed his V4 DOHC engine based upon it and made himself a legend at Indy, only to be followed by a guy named Offenhauser....
Peugeot was one of the technical engineering leaders of their day... Right up there with Ford and Krupp and all the rest...
Edited by Egilman
Quote:
Yes, I am aware of that and agree completely. My brother owned a 403 Diesel, a couple of 504 Coupe(s) and is currently driving his 504 Convertible (4 Cyl. not the horrible v6 PRV engine) among other cars. Modern Peugeot cars do not have the same quality and present absolutely no interest.
Yves
Well that set you all off!
Wow, Greg, you touched a nerve there! 😆
Love a “Fugly” anything you build!
Andrew
Completed (Kits):-
I wouldn't want to be inside one, when the gun was fired - that's awfully tight space.
It seems that Peugot originally made a variety of articles using cast iron and steel, such as coffee-grinders, pepper mills and then started to make wheel-spokes, which took them into making bicycles and eventually cars etc. Bicycles and pepper mills are now independent companies from the car manufacturers.
A not uncommon practice. Most of what we know today as the large automobile manufacturers were behind many other consumer products. Off the top of my head, the appliance brand “Frigidaire” (in North America, was developed and eventually spun off from General Motors. Kubota (known for farm tractors and light industrial equipment) got their start as a manufacturer of steel pipes. Closer to home (for me) CCM is known now more for their sporting goods (especially hockey equipment), but CCM actually stands for “Canadian Cycle and Motor company…. They made cars!
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
One of the most famous products to come out of this process was Kingsford Charcoal Briquets... The waste product of Henry Ford's woodworking plant...  The white oak and hickory char from burning the shavings from the  spoke lathes was found to be great firestarters and when compressed into lumps made excellent cook fire fuel....
It all started in 1919 when Edward G. Kingsford helped Henry Ford procure a stretch of timberland to supply wood for his auto plants. Mr. Ford wondered if all the wood waste generated by his sawmill and plants could be put to better use, and found his answer in a new process for pressing blocks of reconstituted char... While the innovative charcoal briquet was initially marketed under Ford’s own brand, it was eventually renamed Kingsford Charcoal in Edward’s honor..... Very profitable product once it became known...  The process was split off into it's own company after Henry passed and still operates today...
Quote:
Such an unusual looking beast (but thats enough about me lol)
Nice to see some of the regular faces back  - "how are you gents"?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Some excellent work there Greg just the right amount of weathering  and great detail.
OC.
Current builds
Completed works.
8 hours ago, RGL said:
Thoughts?
I like it a lot, it somehow looks steelish, which is always great, when plastic or in your case resin looks like the real thing. The weathering is spot on, specially with the fibers inserted. The front left upper coil spring seems to be a little off, but maybe that´s the reason, why the crew removed the cover ;).
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
