Boat deck secured and support stanchions in place. Some more photos: In the bow shot you'll notice the second stanchion on the right needs fixing. My pipe fitters took care of that this morning as you can see in the subsequent photos. Also, the chief of the boat is in charge of painting that panel on the pilot house door.
Tom
superb looking progress Tom........the windows,  stanchions and doors look fantastic!  she's really shaping up to be a fine looking vessel!
  I applaud your work,  good sir! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
She's coming along nicely.  You should be happy with her.
Bob
Current build:  SS_ Mariefred
Thanks guys for the support and encouragement. My next task is to come up with a moulding around the top of the pilot house (not the one around the edge of the roof; that's easy) that looks like the original:
That block moulding looks tricky, Tom.  How about a piece of wood cut almost through to form the blocks (cut on your table saw with a spacer jig).  If there's only a very thin backing left it should curve around the wheelhouse nicely.
John
Tom,
Isn’t it fun to look at the pictures and say, “Oh, blank, how do I do that”?  Seem like I do it all the time.
John's idea sounds good to me.
Bob
Edited by Cap'n'Bob
HI Tom, Very nice build looks great very impressive
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Andy, thanks for the link. I did check it out and it's a little hard to tell the dimensions of the "blocks" from the picture. I'm thinking of going with John's suggestion which is doable. The problem I'm facing is the size of the cuts. If you look at the above picture, the cuts are about as wide as the mullion in the pilot house window. That translates to a cut of .5 mm on the model. I have a Preac saw, a Rolls Royce in its day, but Charlie Files, the creator, died a few years back and that was the end of the company and its supplies. I own a blade for the saw with a .020 thickness, that's going to be on the wide side. Charlie used to make available a blade with a .010 thickness, and I haven't been able to find anyone who sells the thinner blade since Charlie's passing. So I'm stuck with the .020 cut. So there it is.
Crackers, I'm no good at lettering. I thought what I would do is just make a copy of the sign on my computer printer to size, cut it out and paste it onto a backing.
Tom
Well.. according to the specs, that strip it 2" long... I counted 53 blocks and spaces along the strip, comes out to dentils that are roughly 0.030" (probably smaller due to the slight excess of the ends, so you're probably closer to 0.025")
If it was me, they're really not that expensive, I'd order a set and see what you think in person. Otherwise you could be stuck doing a royal PITA job...
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Tom,
You say the cut you want is 1/2 mm or .019685”, so you are correct your .020” saw is too wide by .000315”.
Bob
OMG 3 ten thousands of an inch!! whatever happened to Accuracy with these scratch builders? :P
Michael
Okay, okay, you guys, I get it, sheesh! A practice run with the saw shows a kerf of .5 mm which should be just fine. But yesterday I sprung for Andy's dentils. So I'm committed, and we're going to wait to see how they look first.
Tom
While I wait for the dentils to arrive from CA, I'm turning my attention to the stack. The photo shows the base that I shaped on the lathe. I have a 5/8" brass tube that should serve nicely as a stack. I'm assuming that the holes you see in the photo at the base are, in fact, holes and not rivets.
Tom
Edited by TBlack
Years ago I planned to build a large model of a western river steamboat with a working steam engine.  Ah the dreams we have.  Anyway.  On river steamboats the stack goes through a large hole in the deck so the hot stack does not touch the wood.  The large sheet metal ring with the sloping top keeps the rain and other water out of the large hole.  The holes in the ring prevent heat buildup.   Usually instead of vent holes there is a gap between the ring and the sloped top which extends a few inches past the ring as you can see at the far left of the picture. The intake to the boiler is near the firebox where the stoker works.
Bob
Thanks guys, for the validation. Damn this is a smart group!
Tom
PS. I'm just looking at the time Andy posted his response. Andy, do you ever get to sleep?
Edited by TBlack
I'm thinking so too... since you don't see any cowl vents for air intake for the boilers.
Andy
I was thinking of river boats that had large doors, usualy open, where the boilers were located, but on a boat like this without those doors this heat shield could also be used as the intake for the boiler.
Bob
On occasion I have been known to pass out.. :P;)
USF Confederacy
Andy, Actually there is a cowl vent, just barely visible. Back in entry 30, page 2, of this log we had a brief discussion of it. At the time I thought it was a smoke stack for a stove in the salon. Since then, I've discovered this photo which makes me think it is a cowl vent which is what you all were trying to convince me of in the first place. It's just visible behind the pilot house roof.
Tom
Yeah.. I'd call that a cowl vent.... :rolleyes:
Too bad we can't get these old-time photographers to take better photos these days.. :P
Andy
USF Confederacy
I decided to take Andy's suggestion and buy some pre-cast dentils from an outfit in Calif. rather than try to make my own. They are made of styrene and come in 2" strips. They're close enough, and I certainly can't make anything smaller.
They needed some adjustment along the top, but married to a single bead moulding along the bottom, and the whole assembly looks OK. It's not an exact replica of the prototype, but I can't get that detailed with the tools I have.
To make the single bead molding, I cut the profile in a razor blade secured to the tool post of my lathe, using both the large Dremel cut-off wheel and the small Dremel cut-off wheel. The thickness of the larger wheel is just the right width for the moulding (2mm), and the thinner wheel is as small as I can get to cut the bead. It's the profile on the right. Sorry for the bluriness.
So the final product still needs to be smoothed out where the joints occur and all painted. Sorry for the lack of close-ups, but my camera doesn't do it very well.
Tom, great stuff the little details are what make a great model fantastic.
Michael
That's really coming along.
Bob
