Well i've done just about all I can do until I get the sails fabricated.
The spars are ready and lots of rigging line everywhere to confuse the issue.
I finished the spars with minwax waterbase woodsheen in oak color, this is a rub-on stain/finish that I am happy with.
So far I've used waterbase finishes everywhere except some metal parts that are touched up with oil base paint. I like the low odor of the water base finishes used.
I decided to add cannon balls, bucket and tools to the battle stations (swab/worm & ram/loader).
I can't imagine how the full square rigged ships get done! I'm doing so much rigging prep on everything but it will be a lot easier than once the mast and spars are installed.
My main focus now is getting my sailmaker going on the sails, I need them complete before I install the standing rigging, as I plan to thread the fore sails hanks onto the stays to save me having to sew them on while on the ship.
Ken
Edited by BareHook
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
I've installed the Horse, Backstays, and Shrouds, but they are not tied off, but awaiting the forestays installation for final adjustments. She has a lot of lines all over the place, so watch your step!
I'm waiting on the forestays to complete the sails, so I can slide the foresail hanks onto the stays rather than trying to install them after.
My sailmaker has begun the sewing of the sails and completed the internal sewing, next is attaching the bolt ropes. I'm going to see if I can tack them in place with the fraycheck adhesive before sewing the zigzag, otherwise seems extremely difficult.
After the boltropes, its cutting, hemming, reef lines, hanks, shaping/stiffening and rigging.
Ken
RATS!
Starting the ratlines, first discovery is I cannot make the cowhitch at the ends hold tight with the .012 line so I'm going with the clove hitch at the ends as well and live with small tag ends protruding.
The alignment card guides work well, I'm doing every 5th ratline to hold the spacing then will fill in the rest.
question regarding the ratlines near the top, the spacing gets really close, should I just knot them close and call it good, or leave them off?
The main mast standing rigging is complete and I'll add the topmast after after the ratlines and getting the mainsail lashed to the mast rings.
Sail making going slow, I tried threatening keelhauling if the sailmaking doesn't start producing soon, but with her being the Admiral, my threat carries no weight.
Ken
Edited by BareHook
The port ratlines are now completed. I'm happy with how they turned out. I used the clove hitch at all 4 points and just trimmed the ends off close.
Once I got the method down, I found it pretty easy. I started with every 5th to hold the spacing and then filled in from the bottom up. The template clipped in place behind really helps as well for keeping your spacing, and providing a contrasting background for grabbing and knotting the ratlines.
Following this method, I found it easier to tie by clipping one end of the string and working with the other end for the first knot:
  1. Clip one end to the edge of the template card, near the height of the ratline, remove after first knot.
  2. Tie the center two knots, adjust height with small tweezers.
  3. Tie the outer two knots, adjust height with small tweezers.
  4. Repeat until the section filled between every fifth that were first installed.
  5. Double check alignment and tightness of all ratlines tied in group.
  6. Lock all knots with dilluted white glue.
  7. After glue has dried, trim off ends and start next group.
I was able to complete a set of 4 ratlines in 10-15 minutes.
Ken
Edited by BareHook
I'm enjoying watching your rigging procedures.  Just a couple of questions:
1.  What is a crow hitch?  (vs. a cow hitch or a half hitch)
2.  Is your sail maker open for business?  (How much would she charge per sail?)
Thanks.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
I figured sail making rates might be kind of high.  My daughter-in-law is talking rates that are high even with my "family discount".
Since I only plan on having reefed sails, I think I will do my own; I shouldn't require too much sewing.
Thanks.
Edited by KenW
Ken
Completed Builds:
Excellent ratlines Ken. I used a similar method but did simple overhand knots rather than clove hitches - I'm not sure if you'd ever notice the difference. One thought is to add a few more lines at the base of the shrouds below the cleats? I did this by thinking that the first line at or above the cleats is too high for a sailor to mount (you can see these extra lines on my log).
You are brave doing sails but it is going to look really good I'm sure. I just had a look at my AVS. Seeing your deck I was reminded that mine was as white as yours when I finished but now it is a yellow tone (which I like) must be a slow reaction between the lacquer (Testors Dullcote) and UV light. I wonder if you'll see that change too.
A great AVS model you have there mate.
Cheers
Alistair
Cheers
Alistair
Current Build -
Thanks Alistair! I'll look at those lower ratlines, maybe tie them and see how they look. I must say, the ratlines over the deadeye lashings is more difficult as you must get it aligned on the first clinch since you cannot slide it or adjust it after its tight.
I haven't noticed much in color change on the decks, I used minwax waterbase satin finish for all the wood. It will be interesting to see what it does over time. I like it because there is no intense odor or fumes, it smells a bit like armourall tire treatment.
Ken
The ratlines are complete and I'm very happy with the results B)
I also added one additional row on each side below the cleats per Alistair's suggestion.
I found the clove hitches worked very well and retained their tightness until locked with dilluted white glue, and I was able to trim the tag ends very close.
I also used .012 black line instead of the .021 per the instructions for better size contrast and more accurate sizing.
Confession: I decided not to serve the standing rigging on this build, but will try it in future builds :o I plan to invest in the serving machine in the near future.
I'll install the Topmast fore and aft stays and then I need to set up and install the main sail.
I'll probably have her rigged on (at my best laymans guess) a port tack? Where the main and fore sails are rigged to the port side and the top sail angled with the starboard side forward.
I'm probably going to stiffen/shape the sails a bit with hairspray while a fan is blowing on them.
Please provide info if my terminology is wrong, thanks! :piratetongueor4:
Ken
Your ship is amazing.  I love the little cannons.  Most of the comments on here are way above my head.  Hopefully, one day I will know what you guys are talking about.
People sew sails for model ships?  Heck, I know how to sew.  That may be one of the things I would be good at. ;)   How can I get a sample of a sewn sail?
Ken,
Great job. I've got this kit on order so your build log has been a great motivator. Your tips and advice will come in handy. I do have a question. Did you use the deck plank material that was supplied or did you replace it?
 Thanks,
Rob
Current build : Triton cross section 1:48
Rob,
Thanks for the feedback! I have lots of build ref docs I can email you, just let me know. I replaced the deck planking with Holly from Hobbymill. The planks were a pleasure to work with, very precise and no edge cleanup required. I did the caulking by painting the edges after cut n initial fit with black hull paint from Model Expo.
Ken
I thought it looked like holly. I really like the way it looks. The edges are so much sharper than basswood and the color is great too. I sent a PM with my email address for the build reference docs. I'll take any help I can get!
Edited by rjones726
The Mainsail is hung, but I still have a bit of rigging to complete on it. The sails a lot more work than I expected, but the look is rewarding, though a far cry from perfection, those other sail fabrication posts make it look too easy! The bolt rope are just about impossible and not very visible, so they will be left off the remaining sails, and the zigzag stitch will form the edges. I attached the reef lines with a single half-hitch sewn through the sail, then had to stiffen/straiten them by isolating/holding them strait with masking tape and applying dilluted PVA. I'm undecided whether to attempt putting some wind shape into the sails or just leave them as-is, will see how they look when more are added.
Ken
Edited by BareHook
Beautiful little boat. If I were you, I would stiffen the sails and put some wind in them. Another advantage of stiffened sails is that it holds your running rigging tight and with less slack.
Regards, Keith
Hmmm, with regards to keeping running rigging tight, how do I keep the traveler tight to the portside and the boom taught against that?
As far as stiffening, I tend to agree. The sail looks good, but the wrinkles stand out in photos. I just need to figure out the best method, I'm thinking either spray starch or brush on dilluted PVA and shape it with a blow drier.
Any suggestions? I know I should have done it before it was hung, but I got on a roll last nite.
Thanks
Ken
Hi Ken, this post here is a link to my Viking ship which shows how I stiffened my sails. I soaked it with a dilute solution of 40% white glue then hung it to dry:
http://modelshipworld.com/index.php?/topic/4311-viking-ship-drakkar-by-amfibius-amati-scale-150/?p=130603
This links to my HMS Bounty, completed 6 years ago. The sails were stiffened with the same method:
http://modelshipworld.com/index.php?/gallery/image/5688-241c8923-ps/
I don't mind the wrinkles, I like the way it looks. In fact, I crushed the sails with the Bounty to add more wrinkles.
How to keep the rigging taut - after you lay out all the running rigging, tie it loosely around the belaying pins. Once all the rigging is done for that sail, tighten them one by one to take up the slack.
Regards, Keith
Jim,
Yes they are magnets. I got the idea from the "Ship modeling for dummies" site. They are very usefull for keeping the planks aligned until the glue dries. Once you are down to the last couple planks, you can no longer use them as there is a mating magnet on the inside that must be removed. I found they were a lot easier to use than pins or clamps. I did all my planking with "Weldbond" and didn't have to use any CA ahdesive, which I preferred as it allowed me to do small adjustments before a fixture cure of the adhesive.
All,
Please feel free to ask about any previous steps or images and I can expand on how I did the process.
Ken
Sorry - dumb Q alert!
Do you just use the magnets to hold each plank to the adjacent plank?  I.E. the magnet is not holding the plank to the bulkhead/frame directly?
Thank,
Brett
For anyone planning to build the AVS, I have planking spreadsheets and a lot of building documentation I can email to you. They were originally provided to me from Peter Jaquith, whose build of the AVS provided much inspiration to me.
Ken
Hi,
Can I get a copy of these if they are still available, please?
Cheers,
Brett
Edited by ortho85
Brett:
Like it or not, you just gave the entire world your email address. I would suggest you go back and edit your post to take out your email information and then send it through a PM which the entire world cannot see. :)
Russ
I finally got my sailmaker to complate the topsail. I must say, anyone who has done sails for a full square rigged ship, my hats off to you!
I'm overall happy with the results, but it was certainly challenging.
I shaped the sail, then stiched it to the topsail yard and then loosly rigged it to the spreader yard.
I then hung this assembly with the topsail yard halyard and attached the yard parrels.
Next the spreader yard jeers.
Then I did the sheets, clewlines, and lifts.
I then added two buntlines which I cleated at the spare shroud cleats #3.
Finally I did the Braces for both yards.
I can now see the light at the end of the tunnel, just 3 foresails, rope coils, swivels and final clean/touchup.
Ken
I think I may be approaching the "home stretch". All the sails are hung and filled with wind to the best of my abilities and the colors are aloft.
Now is time for coils and more coils, what a messy crew leaving all the lines everywhere! :10_1_10:
I stiffened and shaped all the sails with dilluted white glue. I attached the flags to the halyards with a tiny bead of CA.
I think all thats left to do are the coils, installing the swivel guns and any final clean-up and touch-ups. :cheers:
Ken
