More progress with the second planking following my pattern - getting there I think.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Just want to add folks  - the look of my second planking isn't her final appearence, as the rough look will be cleaned up with some light sanding, and all the marks (most of it dried pva glue) will sand away nicely (I hope)
OC.
Current builds
Completed works.
Hi folks,
Firstly can I take this opportunity to wish everyone a great holiday and seasons greatings, hope santa brings us "big kids"  some lovely kits or building stuff.
I also want to thank everyone for the kind comments/remarks and help, and all the like button pusher's.
So where am I at now?   well I have nearly second planked the lower hull, just two planks either side and a few dropped planks, then it will be ready for a dry day so I can sand it down.
OC.:cheers:
Edited by Old Collingwood
spilling
Current builds
Completed works.
you have a great holiday season as well.......glad to hear your almost done with the planking.   look forward in seeing her soon :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi folks  -  second planking finnished,   just needs  a few trimmed planks and sanding.
OC.
Current builds
Completed works.
I have done the sanding on the one side of the hull and  sanded around the rudder post, ready for some additional  planking.
Here's a few pics.
OC.
Current builds
Completed works.
57 minutes ago, cog said:
That looks like a babe's bottom, OC. Very smooth finish
Thanks carl,   doing the other side tomorrow, then I will be placing a false keel and stern post section/s of planking to make it all flush and to create a scalf joint mid point along the keel  then I will be working on the front adding detail planking from the keel to the stem.
OC.
more text
Current builds
Completed works.
Unable to get outside and sand the other side of the hull because of the weather,  I decided to knock up a  stand for it.
Just needs a couple of coats of paint.
OC.
Current builds
Completed works.
Hope everyones xmas is going well,   So i got round to finishing my stand and even got a few coats of black on it.
OC.
Current builds
Completed works.
18 minutes ago, Bill Morrison said:
Beautiful work so far!
Bill
Thanks bill,    happy xmas.
OC.
Current builds
Completed works.
Hello everyone,
Well I got the chance to sand the other side of the lower hull,  I think it came out ok.
Here are a couple of pics.
OC.
Current builds
Completed works.
15 minutes ago, zappto said:
Looks very well done! Very nice progress. Will you paint it, or leave wood alone?
Thank you for the compliment,  im going to paint it white upto the watermark, and yellow ocre  between that and the wale, its how 1720's period sixth rates where painted.
OC.
Current builds
Completed works.
hull and stand looks super OC........all the stands I've made,  I've never though to create one that way.   very ingenious! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate,   hope you have had a great xmas.
OC.
Current builds
Completed works.
A bit more work starting with boxing in the rudder post and false post planking.
OC.
Current builds
Completed works.
30 minutes ago, BANYAN said:
Looking great OC, moving along rapidly now
cheers
Pat
Thnak you pat,   yep the physical  messy work is over now,   getting the hull planked and sanded was a Huge hurdle for me, its nice to be on the more artistic areas now.
OC.
Current builds
Completed works.
Hiya folks  hope all  are well,       Last time I posted I was  working on the keel, well I have constructed some box work to tidy up the keel, as it really got a battering from all the hull building and sanding,  I have also started planking the stem with individual planks, most of this will be hidden with paint, but It will reinforce it and give it appropriate dimensions.
Here's the pics.
OC.
Current builds
Completed works.
Hi folks glad to be back on  the last two days have been So....so....so    long,  any way  I finished the hull including the keel and the stem, I also cut through the stem for the rope routes.  I also sanded back the wale and cleaned up some of the paintwork ready to be touched up.
Here's a few pics.
OC.
Current builds
Completed works.
Hi folks  here is a rather technical way of attaching a finishing strip to the top forecastle bulwarks.
OC.
Current builds
Completed works.
11 minutes ago, zappto said:
Doing a fine fob there, hull looks perfect!
Thank you so much   some paint work to do yet.
OC.
Current builds
Completed works.
Today was paint day,    I decided to change the paint scheme slightly  - this is the pre paint stage the french blue paints  on in a semi gloss finish,  this will be tamed to a matt or satin-matt finish.
Here's a couple of pics.
OC.
Current builds
Completed works.
