I have some gun bluing liquid- it didn't work on the brass at all.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Putting on the lower deadeyes & chain plates. Tied a line to the mast at the crosstree to use as a guide for where the shroud lines will be when they are added later.
I glued the deadeye strop to the channel. Glued the plate to the hull after scratching off paint for better a hold. Drilled holes for nailing. Finished touching up with paint.
They came with the kit.
Very nice work, Jesse. Can't wait to see those deadeyes and chain plates on the Maid.
Steve
completed models:
Shenandoah (Corel)
waiting on the shelf:
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Patsy (derisively): "It's only a model."
Arthur: "Sshhh."
Thank you all for your kind words & encouragement.
Went for pre-op today. My 1st surgery (carpal tunnel) will be on the 20th & the 2nd one will be as soon as I recover enough from the 1st. I will try to get as much done as I can by then but once the cutting starts it will put my ship building on hold for a while until I am able to use both hands again. I guess I will be keeping up with other logs & planning my next steps for when I can start back again.
Sounds like a perfect time to research and read build logs. Its the perfect excuse.
Hopefully the carpal release will get you back your hands and allow building to be easier then it is now.
That numb throbbing hand feeling isn't any fun, it will be nice for you to get rid of that pain. Plus carpal tunnels are becoming less and less invasive which means shorter recovery times. One of the Dr's where Tam works has been developing an ultra-sonic device for doing the surgeries.
Also I don't know about you Jesse but this should make sleeping better. For me I wake many nights with my hands screaming, which creates an insomnia issue.
Here's the wench assembly....
Putting the bowsprit together.....
Ooops! Meant winch, not wench! :huh: Brain fog........
The instructions show to cut off the bowsprit at the same angle as the deck & glue it down on the deck surface. As usual that's not good enough for me. I'd never get it right & I also know it would not be secure enough. So I drilled & filed a hole for the bowsprit & glued it in. Had to do some minor patching on the deck planking around the hole but the windlass will hide it when it is in place.
 Started adding the rest of the deck housings, figurehead, etc.  Now it's beginning to look like something!
Wow, its amazing how adding deck furniture makes them so different, especially after seeing just a hull for a long time.
Its a fun transition.
I agree with how you did the bowsprit mounting. Kit makers cut so many corners, but it for us to put the corners back in by following the heart.
She's looking excellent Jesse. Beautiful work so far my friend.
Edited by themadchemist
Beautiful work! I can't believe how fast that deck is filling up. Thanks for the pics.
Steve
completed models:
Shenandoah (Corel)
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Arthur: "Sshhh."
Rigged the bobstay
It is really coming to life now. Looks great - fantastic work.
Cheers
Alistair
Current Build -
Most of the deck housing has been pre-built ahead of time so it would be ready at this time.
Working on the anchors. Changed line on windlass to a heavier one. Don't think the one with the kit was heavy enough for an anchor. After studying other builds & researching online I decided to do some extra stuff not in my directions with the anchor assembly.  Puddened the anchor rings, seized the blocks to the rings & tied a clinch knot in the heavier line for the anchor cable.
Nice work, Jesse. Really like the work on your anchor.
"Puddened", huh ?? So THAT'S what it's called !!
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Some of these names for things make me giggle. I wonder why these names were used- some sound strange or funny.
Getting anxious, only 7 more days until my first of 2 carpal tunnel surgeries. Wont be able to work on my model or much of anything else for a few months. Because of how Lyme disease has damaged my body I have to walk with a cane & a walker. The Dr. says it will take a month (maybe 2) before I can put pressure on my hand to use these. Once I can, the other wrist will be done & the same recovery time again. This means 2-4 months of having the use of only one hand at a time. Not looking forward to that. Will try to get what I can done on the ship these last 7 days but it wont be much as I have to get other things ready like cleaning my aquariums before I cant work with them as well.
Edited by JesseLee
Got the anchor rigging finished.......
Sure hope everything goes well with the ops. Before ya know it, you'll be better than ever before.
CaptainSteve
She's coming along so nicely. You'll have a beautiful ship to look at while your hands recover.
Steve
completed models:
Shenandoah (Corel)
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Arthur: "Sshhh."
