Hola Matti:
Indeed Matti, I am in the final steps and have an ambivalent feeling:  it gives happiness but at the same time sadness for finishing it.
About weather, now it is really nice, sunny and temperatures between 20 and 30 °C and our coldest temperatures during winter are usually no less than 10°. (But in summer is really hot: 30 to 45°)
Saludos, Karl
Karl,
Yes nice idea (:-)
Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi everyone:
After countless rigging I finished to place the sails on the foremast.
As you can see the lines are still not fixed because I expect to give them one last adjustment, and mainly because I changed some of the rigging following the pictures of the 1:10 model in Vasa´s museum.   Doing this, it was necessary to change the order of the position of the lines to avoid crossing lines to the belaying pins, and this operation was easier made on progress.
Thanks for watching,
Saludos, Karl
Hola!
Now I finished the main course sail.  In this case I select to have it partially folded for a more interesting view.  At first, I didn t know how to do it because the material in BB for sails is a little stiff and even with water it is not very maneuverable but finally it seems OK.  I also change some of the rigging of BB plans to the more logical 1:10 model in Vasa museum.
In behalf of the interested people I send some detailed pictures:
post-797-0-31192900-1417114977_thumb.jpgpost-797-0-04780600-1417115008_thumb.jpgpost-797-0-65373600-1417115045_thumb.jpg
Thanks everyone for the likes.
Saludos, Karl
Looking great, Karl. This is something I would never attempt to do: restore a badly started ship.
I have to take my hat off for what you've accomplished.
Saludos, amigo.
PS. I saw your daughter the other day. Very fine young lady. :)
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Karl,
Again Beautiful build. Thanks for posting large format jpg.s helps so much in appreciating your excellent level of detail. I have made a folder of your rigging and sail photos, as I plan to use your work as an excellent guide. I hope that you don't mind (:-)  Looking forward to following your next build from Model Shipways.
su construcción es superlativo. Bien hecho!!
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
A sunday update:
One of the main differences I saw between the BB plans and the Clayton´s and museum Vasa pictures are the top mizzen stay and the lines that hold the spars of the main mast topsail to the mizzen mast (braces).  Unfortunately in the pictures is impossible to distinguish how are they fixed some of them.  So, I figured out how to install them thinking in a logical form.  Here you can see my solutions:
post-797-0-82880600-1417377450_thumb.jpgpost-797-0-20655600-1417377466_thumb.jpgpost-797-0-17943500-1417377480_thumb.jpg
Saludos, Karl
Hola:
I just finished installing the sails of the main mast.  As I mention before I made some changes in the rigging, adjusting more to the Vasa pictures than to the BB plans.
post-797-0-01783400-1417983935_thumb.jpgpost-797-0-76997500-1417983963_thumb.jpgpost-797-0-59705400-1417984012_thumb.jpgpost-797-0-32019300-1417984106_thumb.jpg
I haven´t fix the rigging threads yet, and I am waiting to finish all the sails to do that, because:
1) to facilitate the maneuver in putting the new lines,
2) due to the changes in the rigging some of the lines intersect each other, so it is necessary to change the place on the pinracks and this is more easy if you haven't fix the lines already and finally,
3) to make final adjustments to the tension of the yarns
Next challenge: the mizzen sails. I will probably make a combination between the rigging shown in BB plans and Vasa pictures to have a more "logic" rigging.
Saludos, Karl
Dear WASA builders
After nærly 11 month "hard" work my ship hull becomes more and more complete.
I still follow yours and all other Wasa experts progress of this fantasic ship.
Without your help I never couldn't make it because the manual and drawing of Billing Boat is uncomplete and include many mistakes.
Thank you very much for your detailed photoraphs and descriptions
Now my question : How did you fasten fasten the gun ports, only by glue or how ??
I'm living in Denmark and I did seen the Wasa only 6 months after it was elevated from the ground of the Stockholm fjord and before there were build a museum.
Next year it is my plan to visit the museum.
Regards
Werner
Hola Werner:
Thanks for your comments!  About your question, I fixed the cannon ports only with glue (the "universal" type, that's serves to glue metal, wood, plastic, and so on) As an addition you can see my post  #87
Saludos, Karl
Hi friends:
Now I finished the Lateen sail of the mizzen mast, as usual I must to combine the information on the BB plans with the Vasa model pictures.
There were several differences but the most relevant was the way to fix the front of the yard.  According to the BB plan the threads lay exactly on the sides of the upper part of the main stairs (the first behind the main mast), blocking them.  In the Vasa model pictures it can be seen that this lines are fixed to the main mast shroud, as I did.
Additionally I also had to add new belaying pins to fix the lines of this sail.
Thanks for all your likes,
Saludos, Karl
Hi Karl,
Beautiful work. Thanks for doing some of the research on the rigging for the rest of us.
I know I will be spending less of my time "scratching my head" trying to figure things out and more time actually rigging!
Frank
Hi friends:
Unlike the lateen sail where I used the rigging show in the Vasa model pictures, for the topsail of the mizzen I followed the BB plan, especially for the braces, because it seems to me a more logical arrangement. According to the pictures in Vasa´s museum,  the topsail braces are fixed on the lateen yard and in BB plan there are fixed on the main mast shrouds.
Also I have changed the main mast topgallant yard braces a little, due that they were interfering with the mizzen topsail (compare the next pictures, noting the mentioned braces with an arrow):
Before        After
It’s important to remark that is a good idea not to fix the lines of the sails and yards (braces, topping lifts, halyards, downhauls, buntlines, etc.) on the pin racks or belaying pins, because the order they are placed can be modified (as in my case) and it is important to avoid crossing lines.
Saludos and Happy Holydays, Karl
Hi Mates:
After almost two weeks of having all my family reunited for the Holidays and not having enough time to work on my ship I finally finished to place the sails on the bowsprit.  As with the other sails I have not fixed them permanently until I double check the correct tensions and locations of the rigging yarns.  Here some pictures:
post-797-0-77957000-1420847399_thumb.jpgpost-797-0-38697600-1420847411_thumb.jpgpost-797-0-30003200-1420847427_thumb.jpgpost-797-0-89483600-1420847438_thumb.jpg
Saludos and best wishes for this new year, Karl
Dear Friend
Fantastic good work and pictures.
Without you I would be hopeless lost.
I have just started the riggin.
Actually we have very stormy weather in Denmark but fortunately I have my "WASA" to work indoors.
Many Greetings from Munkebo
Werner
Good God, Karl! Your Vasa is looking so very nice. I'm glad you live very far from me so there is no chance we enter the same contests!  :D  :D  :D
Feliz año a tí y los tuyos!!! :champagne-popping-smiley-emotic
Karl,
Your Vasa is as good as they get. Beautiful work !!! Your sails are some of the best scaled that I have seen. Hoping to create some that look close to yours when I "get there", I don't think that will be possible (:-(   -   (:-) But thanks so much for posting such great photos, you are helping many of us, as has been mentioned before.
Muchas Gracias
Michael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Que tal Ulises,
yo make me laugh with your comments. It is really hard to compete with your wonderful work.
Saludos, Karl
Karl,
Fantastic update to your log. I love the look and the job you have done with your rigging and sails.
Looking at the pictures is getting me excited about starting the rigging and sail making on my ship soon.
Frank
Hola Friends:
Yesterday I begun knotting the threads to the belaying pins and after putting some of them I finished with my eyes red and crying.  This due that the difficulty to discern where is the thread you are looking for in between all the web of lines and at the same time not disturbing the lines that were already done!!!  But well, thats part of the hobby.
Frank, thank you for your words and I am waiting to see your work on the sails. :cheers:
Saludos, Karl
PD:  I really appreciated all the likes you give me.  Thank you all.    . :dancetl6:
Your billowing sails look great! How did you do that?
Hola Rich:
The fabric that comes with the kit was already a little stiff, maybe you can achieve the same stiffness using very diluted white glue or starch. Also the billowing can be achieved by the tension of the rigging lines.
Saludos, Karl
