David,
when the GF2 log is done I shall have to switch back to online actual-progress-posting. Unfortunately, when I built the live swedish museum Steamer "Bohuslän" I think Digit-cameras were not available at that time, so no pics from that build except for the last stage Fitting out ones.
David sorry I did`nt answer the first part of your question..., it took me 1,5 years to make
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Awesome Nils..........I'm at a loss for words!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you popeye
enjoy further on...
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 32
Walking Planks at the boat stations, and further vents
funnel, vents, wheelstand, two compas stands, Skylight and rudderposition indicators, the boat is just for checking available space in length
nav light Towers (here still without lanterns)
Forward vents, radar-bar, fog horn and forecastle raft Containments mounted
cradle device for strapping raft containers
navlight containments
Build log part 33 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you for your words Mauro
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 33
nav. light containments
mushroom type vents on the deckhouse top
slowly having all deck Fitting-out placed
front of poopdeck with main wheelstand
two additional raft containers
still lots of space on the welldeck
the White round item is not the cooking pot, its the mother gyro-compas containment
White tipped Ends...
Builg log part 34 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 34
Davits fitted on poopdeck
walking Planks at boatstation
again the wheelstand
portside boat rigged
all boats on...
Build log part 35 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 35
starting the brass railings with 3 hole stachions and 0,4mm wire from the spool
shaping a duct for the potside anchor
...and on towards the boatstations
front mast goes through the deck here
the two boats are hanging outwards but also can be swung inwards
fit in the forcastle stairs (to be soldered with the railing, later on
ropedrums attached
railing continued around the boatstations and up to the liferaft containments
Build log part 36 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 36
the forecastle stairs will not be permanently fixed until the frontmast rigging in that area is done, due to Access Problems otherwise
view without the boats
uncomplete forecastle deck, the portside only bears an nostalgic admiralty type anchor
shortcut Access to boatstations also directly possible from welldeck
portside welldeck Forward view
the stairs to poopdeck shall be integrated into the railing
Build log part 37 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
simply amazing Nils.........I enjoy doing railing work :)   I see you buy in bulk :D :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
So if my calculations are correct 1.5 x 365 x 24 = 13140..... oh subtract a couple hours for sleep and eating (1.5 x 4 x 365 =2190) which leaves 10950 hours
And if it did not take that many hours then you must work incredibly fast.
An absolutely wonderful build it is fun following along.
Michael
Build log part 37
the anchorchain-stoppers
choke type, with spindle
in combination with electric spills and Spill band-brake device
forecastle deck now ready for operation
Crew in Trial positions
because of the Motor there must be an machine telegraph operator
poopdeck railing nearly completed
continous Progress....
Build log part 38 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Michael
Michael,
in total it must have been appr. 1600 manhours, but not continously building, because the Pamir was pulled up inbetween, whilst the Gorch Fock stood waiting, so that both ships nearly had the same sequence Level and I could do common practice withe the sailmaking, etc...
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Popeye,
the railing assembly is always quite a fiddeling session, and when those thin stanchions are bent too often they simply break off. I consider about 5-10% spare when purchasing...
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 38
poopdeck handrail Prior to sanding and varnishing
wheel to auxiliary rudderstand
decks nearly completed
nav sight-bearing devices on pods next to the raft containers
handrails complete all around poopdeck
mizzen mast top shroud wire chords
a few hundred blocks (in total) for all the sail operating running rigging
spanners for the upper shrouds of foremast
Build log part 39 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Absolutely fabulous fitting out work Nils B)  B) I have to keep reminding myself this is 1/95 when looking at the pics.The high quality of your work,at this scale,makes it an amazing achievement!
Kind Regards
Nigel
Currently working on Royal Caroline
Thanks for your nice comment Nigel,
I found out that doing models in finer scale than 1:95, max 1:100 is not so well producable for me, too much fiddeling and fagile parts. A Limit of course is the length of an actual ship...., for example I would love to challenge in doing one of those famous 4-stacker Atlantic liners between 1900 and WW1.
I have already a beautiful plan for Cunards quadtriple screw "Lusitania" in scale 1:200, that could be magnified, I fell in love with the lines...., but still its a beast in model-length, let alone in scale 1:100, would Need an extra room for that.
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 39
mast top
lower top platform
here with Counters for upper shroud spanners
made several mini shackles for Multi usage
Build log part 40 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils 1600 hours that is amazing
I am curious about all the blocks and the way you have fixed the shrouds.
How did you make the blocks and the other question is what metal did you make the small shackles from?
Michael
More fabulous work Nils B) I think in some respects,the 1/100 is one of the hardest scales,as when you go even smaller you can get away from using 3d fittings and start using photoetch railings etc.
In the UK,we have a famous modeler called Jimmy Wood who works purely in 1/100.He works solely in wood and brass and everything is scratchbuilt.
All his models are of offshore vessels,however I give you a link to his 'Seawell' build as whilst your and his models are of very different subjects,your methods are very similar.Enjoy :)
http://www.rcgroups.com/forums/showthread.php?t=524835
Kind Regards
Nigel
Nigel,
many thanks for sharing that link comprising Jimmy Woods work, you`re right, that is very interesting for me as well, and I`ll take myself more time to study and explore that site more intensively.
I love those modelers who build machinery from scratch, modern or historic. I also built a steam river tug with selfmade gas fired Boiler and driven by a self designed and made V-type arrangement 6 cylinder steam engine for RC control. Unfortunately I had a leakage in the Boilers superheater tube coil, and so the model is sitting idle on the shelf for many years already.
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
I am glad you find it of interest,your work just reminds me of his.I too have a fondness for the more 'mechanical' ship as well as what I post on here.One day when it comes back out 'mothballs' I shall post some pics of my DSV build.It has been laid dormant for a while as due to the number of working functions,it is not a 'cheap' build.
I would love to build a working steam plant one day when I have collected enough machine tools to do so.I have plans for HMS Inflexible (predreadnought) by John R Haynes and eventually plan to build a model of her with two working steam engines.
Kind Regards
Nigel
Michael
Michael,
I was already expecting that question related to the blocks already since the Pamir`s rigging pics had been posted.
I once was on search in the web and at Ebay Shops for this type of equipement and finaly found quite a lot of items that with a Little Tuning only would well suit my Needs, an this all at peanuts priceing....
When sighting the articles available at the Ebay sections for Fashion jewelery equipement I discovered Little metal beads of all sorts in diam. and Color. These I use for solderingthe wire chord Ends to the shroud spanners. Criteria is the Little hole through the bead. The beads are very well solderable (clean Ends and sufficiant flux)
For the single sheaved blocks I use metal double-Loop capsule type bead knot covers, which are available in different sizes Colors quantities. As rollers I again use metal-beads that resemble rollers also in sizes to suit the bead covers. Shall enclose a scetch for explaination....
I would though not use These for historic wooden shipmodels, here Chuck has the correct ones in his Sortiment.
For the mini shackles I use an article from the beadsshop made of brass, nickel galvanized, shall enclose a link
cheers
Nils
http://www.ebay.de/itm/20-Stk-Verbinder-Kettenglied-9mm-nickelfrei-H77-/120407595118?pt=Schmuckgestaltung&hash=item1c08da186e
use bead knot cover "blocks" either for hooks, single sheave blocks or blocks with 2 fastening sides
Current builds
-Lightship Elbe 1
Completed
Nils
Thank you for the explanation that is a very neat solution for them.
Michael
